1997 VW Passat Wagon GLX-NOISY ENGINE
crmass1
11-03-2004, 07:36 PM
Help!
We just got the car back (2 weeks ago) after the dealer fixed the Ck Engine light (EPA Airflow sensor), oil leaks (found oil cooler seal leak), and a worn ball-joint tie rod(replaced).
Now the car makes a loud humming noise when I shift from 3-4-5 th gear both up and downshift.....Also noticed that the engine RPM in 4th and 5th gears moved up from 2700 to 3000.
Any clues would be appreciated. Thanks.
