Chevrolet
Cavalier
> Cavalier Problem Diagnosis
View Full Version :
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
2004 Cavalier 2.2 OHC (EcoTec) Alternator
96 2.2 cavalier temp gauge
Fog Lights, 2003 Pontiac Sunfire
Battery Lite & ABS Lite Coming On & Problems....
switching computer and BCM from a 99 to a 00
97 Cavalier 2.2 P0301 code
Oil pressure light 2001 2.2
Belt Squeeks!!!
Rear defroster
98 Cavalier 2.2 Cooling system nightmare
tork converter clutch
heater fan
Idle issue
a little bit of white smoke from engine
2003 Cavalier Horn Problems
Gauges, Stereo, Electrical, Error
Power when off, no Power when on
phantom gauges
Help Tranny
1994 Cavalier - Did I bust a timing chain?
1989 Cavalier-Where is the flasher unit?
Temp gauge
very high idle
extracting the tie rods 99' cav
94 z24 heat problem
1998 Cavalier Z24 Fluid leak at water neck?
97 Power Steering Problem
no power until check eng.lite comes on
1990 Cavalier No Headlights
Dome Light Not turning on
blower motor resistor balogna
Steering wheel off center? This bugs me
1996 Cavalier Clutch problem
1995 sunfire stumped
97 Z24 - 157000 miles
98 Cavalier - Stalling, crank sensor, codes
ugh...more problems...more headaches
Intermittent Oil Light 96 2.2L
03 cavalier, getting shocked exiting the car
05 Cavalier Temp gauge
01 cavalier gas gage not working
1997 Cavalier Check Engine, ETS Off, Intermittant Start Problem
cant figure out idle
1999 Cavalier stalls when running at low speed
[ cig ] fuse blown.
Cavalier low compression
96 Cavalier, new owner...old problems
weird idle and stall and abs light
2002 Cavalier No Start Problem
96 Cavalier 3rd Alternator in 2yrs
02 Cavalier - Electrical Issues
2004 rubber muffler hanger
Unintentional braking
'killing' 91 RS Cav
2000 Cavalier Trouble Code (C1232) LF ABS
96 Cavy..No Start
Need some help
97 Sunfire GT noise help
02 Cav. Electrical Problems and thumping in the front tire
98 Z24 valve cover gasket
97 chevy made a pop and quit
Installed used BCM- Won't start now
Turbo/Blow Off Valve Question
91 sunbird 2.0 temp gauge
Post 2002 Cavalier Serpentine Belt Change
Brakes
my clutch went to mush...
Mystery noise?
91 z24 engine problems
96 cavalier cranks but doesn't start
96 2.4L manual transmission problem
oil pump 2.4L
car sounds like a tractor
'02 Sunfire SE (2.2) Dead, and I mean Dead. Help!!!
Manual Transmisson Problem!
96 cavalier clutch problem
2000 Chevy Cavalier..Coolant Overflow
PGR Valve...
2002 cavalier wont start HELP!!!!!!
Window Alignment
Trouble Code (P0118)
Service light on
96 cavalier rattling at front passenger side
Transmission won't shift into any gear
P0758 Boys, not lookin' good...
Weird A/C issue
03 Cavalier Transmission Question
Wheel bearing & "tire noise"?
02 Cavalier headlight assembly
tranny slip? Misfire?
Injector problems??
Random/Multiple Cylinder Misfire
HELP.. Need help 96 Cavalier Auto Can drive forward but no reverse
swap sunfire 2.4 junk for reliable 2.2 with getrg
2003 Cavalier...BCM Problems??
02 Cavalier no start
engine missing and i am stumped
minor clunk
Plz help me in my 96 Cavalier ...
Tensior pulley assembly
95 & 98 2.2 vacuum line help
wiper problem
HELP!!! 99 cavalier 5spd 2.2 stalling
2500 rpm idle when getting off highway.
UHM...HELP! 01 Sunfire shifting problems!
Halfshaft question
01 Cav no start
2003 Sunfire Bogs down in 2nd and 3rd Gear
1999 Auto Cavy shift prob
both daytime running lamps don't work
96 2.2l cavalier starts, then dies
1992 2.2 Cavalier only fires on 1&4 cylinders
96 sunfire misfire
How do you adjust 1-piece halos......?
03 cavalier engine surge, high idle when getting off highway.
lower ball joint
99 cavalier
2000 Sunfire Possible Alternator Problem
Signal Light Replaced But Still Not Working
p0440 error
92 Cavalier rear brake keep tighting up
2001 Cavalier won't start & the BCM/RFA clicks
Help! 2001 Cavalier won't start...
98 cavalier overheating. please help
96 Exhaust Manafold
91 cavalier...dies after getting warm
Brake Pads
1999 Cavalier Brake fault indicator
1999 Sunfire problem
Unlock a BCM?
I Need Sunroof Help!!!
00 Cavalier Died and Won't Restart
tranny slipping.....bad!
95 chev cav speedo goes up in reverse new vss
94 Cavalier signals won't flash.
Battery problems
Help me!!! Needed a boost now keyless remote not working
96 Pontiac Misfire... I mean, Sunfire
Trouble with 5th or Reverse
1998 Cavalier Clutch Problems
oxygen sensor after the catalytic converter
Brake problem
1995 Cavalier NOT CHARGING!
2002 Sunfire Transmission Cable
Sunfire 96 hesitate/jerks problem ?
manual trans shifting issue
The wobbly shifter
Airbag related issues in removing steering wheel?
97 Cavalier LEAKING COOLENT.
Problem with 2000 Z24 water outlet going bad.
Brakes Squeal Just Before Stop
1998 Chevy Cavalier Clutch Issues
Are there tricks or traps in replacing Cavalier starter?
Crankshaft Position Sensor
how to drop 96 fuel tank
95 Cavalier Won't Start 2.2l
2003 Pontiac Sunfire won't start
rough idle...help!!!
power window problem
95 cav wont start sometimes
Steering wheel yanking 97 sunfire
Cavalier 2002 4 dr sedan engine repair light on? and problem when starting
Air Conditioning
dying car and dummy lights
Oil Gauge Acting Weird
Battery posts & radio...
Rear Defogger Not Working Chev Cavalier 2003
Transmission Noise?
98 cavaliar loud nose from rear end..
Cat converter problem please help
:::1996 Pontiac Sunfire Overheating:::
high engine temp? and no oil pressure
96 Z24 engine problem
not sparking properly
more wiring problems YAY
steering wheel removal
Struts and Spring
96 Cavi 2.2 Crankshaft Sensor
ETS is a pain in the ass.
Help!!!!!!!
98 Z24 interior lights and power mirrors
cavalier
'96 Cavalier stalling at stops!!!!!!!!!!!!!!!!!
Oil in Coolant on 2.2 L. 95 Cavalier
94 Z24 Problems
cavalier fuel filter
Timing on a 1998 2.4 L
98 Cavilier won't start
96 Cavalier - Heater Blower Only Works on High
Still with the poping noise passenger side
89 Z24 rpm too high @60MPH
Hissing When Brake Applied
2000 sunfire won,t start
Sun roof trouble
Replaced fuel pump, still no fuel ??
1993 Chevy Cavalier Turn Signals Don't work.
sorta rev limiter
Engine overheated and wont start at all
Finding the elusive 'back-up switch' on a manual transmission
1999 2.2 5speed Starting Issue!!
Car is running really, really, really rich.
how to replace the wheelbearing on 2000 chevrolet cavalier
96 cavalier stalled, will only kind-of start
Poor gas mileage
03 Cavalier temp & Fuel Gauges Way out Of Wack
2000 chev z-24 blowing fuses
lost head light to a deer. Now i can not stop lights from lashing.
mid 90s ECU wiring diagram
96 ECU Conversion
95 Cavalier
cooling fan problems 98 cavalier
90 cavalier won't start
stalls in gear
1998 sunfire gt 2.4liter
Valve cover gasket
Light alarm
Factory Alarm
Oil change ecotec 2.2
97 cavalier misfire, engine lite blink
03 Cavalier oil in air intake
'98 cavy wouldn't start after dying battery
97 Sunfire stalled and won't start
99 Z24 power windows
trunk latch
Door Panels
2200 head gasket
2000 z24 odometer problem
Tranny Swaps for a 2000 Cavalier
Z-24 air conditioning problem
Quick EVAP question
97 Sunfire Coil Problem?
2000 Z24 check engine light
Engine probs, 92 cav
Ugh code P0108.
2001 Sunfire Won't start
93 Sputtering and backfiring
Sunfire stuck in first gear
2001 Z24 won't start in mornings.
windows and convertible problems
Coolant Leak
2000 z24 front left noise
Aftermarket wheel on, but how do I HORN?
03 Sunfire Rear defrost don't work
LED Indicator
Engine Running Problem 95 2.2L Coupe
Code P0440
