View Full Version : Cavalier Problem Diagnosis
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19
  1. looks like cooling problems are popular
  2. 89 cavalier heater problem
  3. 1995 cavalier dies, and doesnt pick up speed
  4. Here is another coolant problem for everyone
  5. Another Coolant Problem
  6. Foglight Hell
  7. ABS code 1261, what does this mean?
  8. Leaking coolant resovor cap ?
  9. 97 Cavalier High Idle P0507
  10. smokes like hell
  11. my 90 z 3.1 wont idle when cold
  12. my 90 z 3.1 wont idle when cold
  13. problem idling when cold
  14. 1999 Cavalier Convertible - HELP!!!
  15. 96 cavalier
  16. Crazy Electrical problems
  17. 1999 z24 cavalier head ligh chimes
  18. Rough shifting
  19. '99 Z24 Cavalier Convert. - blower motor resistor
  20. '98 2.2 idling problem plz help
  21. Electrical Problem
  22. 1990 Cavalier leaking coolant
  23. 96 Cav Convertible Z24
  24. 96 Z24 Auto Tranny Pulls
  25. Engine cooling fan, problems?
  26. Headlight problem, Need HELP!!
  27. possessed 96' cavalier, 2.2 ltr. all lights flash and rough idle,die
  28. 2003 cavy idile is to low and jumps. Please help
  29. OK I'M BACK and i need to know EVERYTHING about catalytic converters
  30. cav. won`t start
  31. 2003 Cavalier Engine Light
  32. Need help on ABS light is always ON!
  33. Wierd Cooling Problem
  34. 97 Cav "Microprocessor Unit" ? ! ? !
  35. Not Your Average Keyless Remote question
  36. 2000 cav wont start
  37. 92 cav z24 3.1L
  38. Wtf!!!!!!!
  39. Intermittent Light/power failure
  40. Gear Shift problem
  41. '98 2.4 problems
  42. 2.2 ECOTEC Idles but cuts out when gassed ???
  43. Wheel Bearing
  44. 98 cavalier Cooling fan circuit P0480 DTC
  45. Replaced Starter Now It Doesnt Start
  46. Girl who's car won't start
  47. putter
  48. 2002 Z24 - No Turn Signals or Hazards Lights
  49. 94 V6 3.1 Idle
  50. Airbag light is on after installing remote start
  51. Got Code 440 now what
  52. Help Me Please
  53. oil pump problem
  54. '96 Bonneville engine cuts off
  55. bad gas mileage?
  56. Idels between 1100 and 1500 rpms
  57. 2000 sunfife rear brakes locking up when brakes applied
  58. 1996 Cavalier-What could be causing this strange sound?
  59. sunfire clunk
  60. Electrical problem??
  61. Rear Brake Cylinder Replacement Problems
  62. turn signal on 90
  63. 94 engine problem. help
  64. 2000 Cavalier Z24- electrical malfunction
  65. Stalling
  66. TC light, ABS light, Service light
  67. Partial Loss of Power
  68. P0441 Code and Stuck Idle??
  69. Cavalier Brake problems '94'
  70. Warped front rotor
  71. Front Brake Bolt Size 2002
  72. Cavalier Keyless Remote Problems
  73. Random Dieing when Braking, Laggy/Stuttering Takeoff.
  74. odometer out!
  75. 94 cavalier RS trans filter.
  76. Wind noise 2002 cavalier LS
  77. 96' cavi won't start Please help
  78. popping/clicking
  79. oil light comes on
  80. Trunk Leak 2nd Generation
  81. oil leak
  82. Chevy Cavalier starting battery alternator problem??
  83. Alternator electrical probs weird noises
  84. I have no idea what's going on.
  85. power window?????
  86. 2001 cavalier
  87. Oil Pressure Gauge drops to "0"...
  88. 97 Z24 Dome Light Stuck On
  89. jerking motion?
  90. cat. plugged or missing?
  91. 1998 cavalier 2.2 wont start
  92. '93 Cav RS Strut / Knuckle Bolts
  93. Loud Hummin Sound
  94. Bright Lights don't work
  95. 96-98 cavs seem to have the same problems
  96. Car wont start...
  97. Best Cavalier Repair Manual?
  98. Fuel Pump/Electrical system problem...
  99. 2002 pontiac sunfire..engine light on
  100. 1988 cavalier-new starter-good battery-won't start
  101. 98 z24 2.4 motor mount troubleshooting
  102. 1996 automatic cavalier ignition problem
  103. Headlights Wont Come on Amymore
  104. Which came first? And Why???
  105. oil in throttle body and intake
  106. oil in coolant fill bottle
  107. drivers side windows fog up esaly
  108. rear defroster switch buzzing
  109. No Start
  110. 98 Cavalier hesitating/bucking
  111. No high beam lights
  112. 98 Chevy cavelier acting like it's running out of gas
  113. 98 Chevy Cavelier acting like it's running out of gas
  114. 95 Cavalier Heater
  115. 1999 head gasket change
  116. 1997 Pontiac Sunfire airbag lights?
  117. 1993 Cavalier Trunk Problems
  118. 2000 z24 check engine light steady on
  119. Abs+ets+svs 2
  120. Abs+ets+svs
  121. '94 Sunfire blown head gasket????
  122. Won't start when wet
  123. 95 cavalier heater air flow
  124. 95 Cavalier 2.2L 5speed Trans problem
  125. Women
  126. 1999 Caviler Alternator 2 small wires disconnected
  127. 03 Cavalier-Is the auto trans shifting right?
  128. idle
  129. Trans has only 2nd forward gear
  130. Transmission Jumping When Changing Gears??
  131. ECM Location
  132. Pontiac Sunfire gas mileage
  133. clutch problems...
  134. rpm's fluxuating problem
  135. Hellllllllllllllllp
  136. Hellllllllllllllllp
  137. 1997 transport won't take fuel
  138. pontic transport 3.8ltre 94
  139. how do I purge my system
  140. whats evap line???
  141. Hesitation or miss under moderate acceleration
  142. 1997 Firebird heater problems
  143. wipers and theft system
  144. intermittent headlights 97 cavalier
  145. loose BOLTS!!!!!
  146. 1992 Cavalier ABS light staying on
  147. Reading computer codes
  148. 1997 Sunfire won't stay running HELP!
  149. questions about new replacement radiator
  150. Driver side power failure
  151. 1999 Cavalier ABS + BRAKE ! Light
  152. Smoke coming from the steering column
  153. dimming head lights??
  154. newbie with questions!!
  155. 1991 Cavalier Check Gages Light
  156. service light on not sure why
  157. Gauge Cluster lights Help
  158. 98 cavalier transmision problems
  159. Low idle problems
  160. 2000 Sufire misfiring
  161. need an alternative to driver side airbag
  162. buzzing noise from front speakers
  163. 95 cavalier overheating
  164. dukeboy
  165. Flywheel
  166. car won't start, think its the ignition switch
  167. 2003 Check Engine Light on...
  168. Check Engine light is on and i have the codes
  169. stalls when making slow left turn
  170. / cooleant leak on top of resover?
  171. 96 Sunfire Overheating only in winter
  172. 2003 Sunfire Headlights
  173. 95 Cavalier Intermitent Starting problerms, and check engine light
  174. Need Help With 91 Chevy Cavalier RS
  175. 99 Chevy cavalier problems im lost help!!!!
  176. 98 cav will not start
  177. vapor comes out of the hood on my 91 Cavalier
  178. Possible Blown Motor
  179. no air flow
  180. Weird electrical problems; Domelight not working HELP!!!!!
  181. Radiator/Fan Problem '94 cav
  182. Headlight indicator
  183. Getting to the spark plug will on the coil pack 95 Cavalier
  184. 95 sunfire spark problems
  185. Serious Problem
  186. How to install RKsport FPR???
  187. 98 sunfire wont warm up -- confused!!!
  188. 2 WEIRD problems with 96 Cavalier!!
  189. I crashed my 2000 cavalier and now need to remove airbags
  190. Need some advice
  191. 98 cavalier stalls when ever it wants
  192. Heater Problem
  193. headlight Problems
  194. monte z34 overheating in one cylinder? perplexed
  195. 1994 chev.cav.electical problem
  196. third time belt change >a week
  197. car died---hard to re-start--code P0506
  198. Where to mount clutch res. ????????
  199. Fuel Filter Problems
  200. 97 Cav Z24 Dies Over And Over
  201. 92 calvalier 3.1 MFI
  202. 01 Cavalier..turns,but doesnt start...
  203. Oil Light pops up when rough Idle and acceleration
  204. check engine light is on and.......
  205. 1995 blazer 4x4 doint engage
  206. 2002 sunfire GT 2.4 no headlights
  207. Sudden drop in Mileage
  208. Cold weather idle
  209. 98 that's burning through gas extremely quickly
  210. 03 rear dash problem
  211. 95 cavalier, QDM Circuit problems.
  212. 99 Cavalier - Intermittent Rough Idle
  213. 89 that runs like crap
  214. replacing 2003 sunfire backup lamps
  215. I have NO idea what the problem is.
  216. surging idle mysterious stall????92 cav
  217. valve cover..
  218. Blower Fan
  219. Driver side head light on z24
  220. 99 Cav ABS Light
  221. electrical problem!!!!! I think????
  222. 02 Cavalier Horn won't shut off airbag light is on
  223. hard starting and theft light is on...
  224. Cooling system nightmare
  225. Temp sensor
  226. Headlights are wacked...
  227. my car will not start
  228. 92 Won't start?? Been searching......
  229. 98 Cav 5spd problem
  230. Access to Front End
  231. PCV Valve Location
  232. no upshift
  233. 2003 Cavalier Thermostat
  234. 2003 Cavalier Thermostat
  235. 98 sunfire rear window defrost
  236. Check engine light
  237. odometer light
  238. 95 Sunfire sucking juice
  239. IgnitionSwitch
  240. 2004 cavalier How to install Instrument cluster
  241. Fuel Problems with 2001 Z24 Cavalier
  242. ECM problem
  243. uh oh again
  244. 97 Pontiac SunFire Ingition Switch
  245. Air Mode Knob Broke?
  246. 96 cavalier no fire to blower motor???
  247. Hit a curb, HELP
  248. I think it maybe possessed
  249. Igniton Problem
  250. Pontiac Sunfire - NO HEAT
