View Full Version : Engine, Transmission and Drivetrain
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13
  1. bearing question
  2. Oil filter question
  3. Blow Engine....Help!!
  4. New pics need the O.K.
  5. GSX rear brakes
  6. New o2 housing for 4g63
  7. 93 Eclipse 1.8L upgrade to 4G63T
  8. Can I keep my a/c with this intercooler?
  9. water into cold air intake
  10. Need pictures of parts really bad !!!!!!!!!!!
  11. what all do i need
  12. performance
  13. can i put a chevy 283 in my 91 talon?
  14. Expertise greatly needed - 2.4 stroker
  15. Customize my Talon
  16. Replacement Filter for 4g63 Injen Intake?
  17. 02 housing for PTE SC6152E
  18. Where do I start wtih my car
  19. 6G72 in a 1g?
  20. loosing power
  21. Injector Pressure Please.
  22. Cam Gear Adjustment
  23. dyno tuning comment caught me off guard
  24. SAFC tuning??
  25. Downpipe
  26. Cam locks, would these work?
  27. b16's,b18's, etc and 420a
  28. Height issue....help
  29. mounting my AFPR
  30. Air filter
  31. Transmission
  32. Cleaning up my turbo
  33. need some advice
  34. My New Bored/Stroked 7-bolt QUESTIONS...
  35. alphawerks headers
  36. After market??
  37. cold air intake on gs
  38. 99 gs
  39. A few tuning questions
  40. Upgrading 420a engine...
  41. will the srt 4 turbo manifold fir the 420a?
  42. Free or CheapMods For 95' Gs Eclipse...
  43. Free Mods For 95' Gs Eclipse...
  44. MHI evo3 16g
  45. front camber kit
  46. Take a look at my log
  47. installing AN aFC unit
  48. What is in my ESi????
  49. wideband questions
  50. under drive pulley and 30hp gain?
  51. 420a Head Swap
  52. Zex Questions??
  53. porting
  54. New Parts!
  55. Coil on Plug setup Install help
  56. Newbie question
  57. 4g63 or 420a???????
  58. Head Lube Question, again...
  59. Converting My Non-turbo 93' Eclipse To Turbo
  60. Ok I need advice!!! Engine style
  61. Methanol Injection AFR
  62. Reuse MLS?
  63. Turbos;injectors;CFM;lbs/min
  64. camber kit???
  65. 2.5 inch piping?
  66. turbo internal upgrade?
  67. fmic question
  68. gs-t or gs-x
  69. Proper A/F ratio?
  70. Need More speed for my talon
  71. how much does a 420A block cost?
  72. 420A stock internal limits
  73. Brake rotor question
  74. 2g rs fuel/air problem
  75. how to lower my eclipse
  76. Will this work?
  77. bolt patterns
  78. build questions
  79. how do i go about....
  80. Just bought JMFab SMIM
  81. 1g throttle body
  82. Excessive oil pressure?
  83. 16G MBC Tap?
  84. wastegate and boost control
  85. dsmlink
  86. KoDKingVegeta's 1990 Eclipse Project
  87. what parts
  88. engines done for!
  89. Differences in turbos
  90. eprom ecu
  91. Engine Swap
  92. More power!!
  93. Boost potential
  94. What has been your experience with race gas?
  95. 50-trim Swap?!? Different Wheels?
  96. question bout motor swaps
  97. timing belt replacement need advice.
  98. Brakes, Ceramic, Metallic or Semi-Metallic?
  99. replacing 1990 eclipse engine
  100. Difference between turbos
  101. dang hood
  102. Clutch?
  103. External Wastegate Dump
  104. Need opinions on bottom end build
  105. advice
  106. Which FMIC to get
  107. How hard/much money would it be to hit 300whp in my 99 gsx?
  108. I need a clutch...
  109. 2.4 Spyder, One or Two Transmission Mounts?
  110. Do stroker kits on 7 bolts crankwalk?
  111. Help!!!!! 95 Eagle Talon Non Turbo... Want To Convert To Turbo!!!
  112. i need torque specs..4 tsi
  113. Greddy Or HKS?
  114. Fidanza Flywheel thicker then stock
  115. Lighter Flywheel
  116. 1st Gen turbo
  117. Killa Black Eagle Talon TSI AWD Turbo Coming back from the death !!!
  118. gm mas just need some help !
  119. Spring Update
  120. engine swap?
  121. I must be lame, Evo 8/9 fuel
  122. clucth kit questions, and brakes too.
  123. Puck Clutch
  124. 18g turbo ?
  125. Performance synchros?????
  126. need info on what ecm mods a tuboed 420a needs.
  127. i have a precision 50 trim turbo
  128. Cyclone Enging?
  129. I want some Nitrous
  130. engine swap.
  131. Turboback Exhaust Question
  132. learning
  133. code deleating
  134. flamethrower
  135. how do i tell
  136. boost problem.
  137. 99 Eclipse GST Spyder. Need advice for $2,500 build up.
  138. 1995 Eagle Talon Occasional Problem Shifting from 3rd to 4th
  139. Umm, what did I buy ... ?? GT42
  140. Finally Boosting Strong!!!
  141. whats better abt the 6bolt motor then the 7bolt?
  142. Underdrive pulley, new belt or what
  143. pace setter exhaust
  144. engine management
  145. how do i install a autogague tachometer..on my 2g eclipse
  146. need help
  147. engine swap 91 to 92 talon
  148. Yet another top speed thread... *Edited by Mod*
  149. 2G turbo pistons?
  150. Stock 2g Spring rates?
  151. Motor Swap Question
  152. 2G eclipse with a 6 bolt motor
  153. underdrive pully question
  154. Eclipse GSX Turbo Upgrade HELP
  155. Quick swap question...
  156. need a turbo
  157. 1997 gs eclipse
  158. Wideband
  159. 2G Eclipse suspension and plus size wheel combination..
  160. 2.3Stroker almost done, some quick ???'s
  161. Fidanza Clutch
  162. ?'s about xs-power fmic
  163. 97 eclipse gs
  164. smoked-HELP!
  165. electric supercharger? $1600.00 WHAT????
  166. Dumb valve cover question
  167. evo8 swap into a rs eclipse swap?
  168. AWD flywheel on FWD car
  169. what kind of bov?
  170. stock pistons rating
  171. cia
  172. Evap removal questions
  173. 5" Tach install help
  174. Head lube ;-)
  175. 95 awd talon ENGINE REBUILD KIT QUESTIONS
  176. Lowering my car this weekend..
  177. Headgasket... MLS? Copper? Graphite?
  178. 94 eclipse ground wires
  179. Removing the silencer..
  180. Build Stock or get 4g63 motor?
  181. Stock Psi?
  182. eBay intercooler question
  183. Clutch package help
  184. Got my ass kicked installing my BC272's
  185. g-vr4 tranny better...???
  186. Porting my manifold..
  187. Where can I get high quality 6bolt japan engine ?
  188. Test Pipe
  189. any guesses on top speed?
  190. electrical or mechanical gauge
  191. Suspension/Brake/Misc Parts Help please...
  192. Air/Fuel gauge power?
  193. Turbo Timers
  194. speed chip
  195. fuel trim
  196. Stroker, needs some help
  197. Pics of my ported Head
  198. stock turbo?
  199. I need a little information with my engine swap
  200. tuning?
  201. need help
  202. first log, please help.
  203. 97 Rs-t?
  204. KYB.... AGX or Gr2
  205. 420a FMIC and piping kit. Where?
  206. any good?
  207. muffler
  208. Fuel system line size...
  209. new cai
  210. E-85
  211. dont know were to post this.
  212. can my 1993 eclipse GS 1.8L be chipped?
  213. 14b Turbo
  214. motor swap on a 1st gen
  215. evo 3 16g turbo on stock injectors?
  216. 16g Turbo Questions
  217. is there a tuner/chip
  218. turbo
  219. Suspensions?
  220. 4g63 N/A Dreams, can it be done.
  221. Need help with an APEXi Twin Chamber Blow Off Valve for a 97 GS-t
  222. Dogbox tranny any good ?
  223. short ram?
  224. dumnass
  225. short throw shifter
  226. What Next?
  227. Dynoing with SPOOL
  228. transmissions and 6 bolts
  229. Can Someone Find Me A 1993 Eclipse GS Cold Air Intake?
  230. Info help.....
  231. Exhaust plans w/ lots of questions
  232. got a question? any1 got an answer
  233. engine swap
  234. 1993 Mass Airflow Sensor work with 1995-99 Adapter?
  235. turbo down pipe
  236. Installing my shocks/springs
  237. Best way to clean block for a new HG
  238. Lowering Options
  239. safc2 installation
  240. Intake Mani for 420a
  241. will this FPR work on a turbo model?
  242. One quick question about mufflers, help me out please.
  243. Head Rebuild Question Part #1
  244. Head Rebuild Question Part #1
  245. O2 Gasket: 2G or Evo III
  246. BOV questions
  247. Is this a good fmic?
  248. need help
  249. Spyder assembly and Yoke.... help an uneducated man!
  250. 16g turbo help
