View Full Version : Durango
Pages : 1 2 3 4 [5] 6
  1. Fold or remove 2nd row Middle Seat
  2. 99 dodge durango problems pcm, gauges, etc.
  3. 1998 durango guages cluster
  4. high revs and hard down shifting when driving
  5. Trans not shifting properly
  6. 02-4.7 durango oil pressure question
  7. 2000 general questions
  8. Keyless Remote/Start Question
  9. heater and higher RPMs
  10. check engine light
  11. No more MOPAR!
  12. What's the best clear coat to use?
  13. Anyone know where to get cheap fender flares?
  14. loose steering wheel
  15. Wierd heater/temp guage actions
  16. Just bought a 2002 Dodge Durango with a 4.7 magnum v-8
  17. No heat
  18. Easy fuse/relay diagram???
  19. Durango Accessories?
  20. Gas gushes out of tank after auto stop...
  21. Dead door lock
  22. Cant Start (cold Maybe)
  23. 2004 Durango 4 wheel lock problems
  24. 1998 5.2 Durango Won't start
  25. squeaking noise
  26. Infinity stereo sytem speakers
  27. 2004 Heating noise
  28. 2004 Durango Heater Problem
  29. new engine
  30. Durango 2004-2005 side steps for sale
  31. Help! My 2000 Durango 5.9L will not Idle!
  32. IAT sensor
  33. 2000 Durango Starts, But Won't Idle
  34. trouble with 99 durango
  35. MPG low on 2000 SLT+ 5.9L
  36. Vibrations, rattling and decreased gas milage HELP!
  37. 2003 durango - need sirius satellite radio help
  38. Power Windows
  39. Recomended Fuel Octane level??
  40. Dodge Caravan Heat
  41. 98 Durango - No brakes lights
  42. 98 roof rack
  43. backup lights
  44. need more heat
  45. how much oil?
  46. programming keyless entry
  47. Headliner removal
  48. WCM module defective in 2004 Durnagos built before May 17, 2004
  49. Remote Starter
  50. 2004 Durango - Steering Lock up
  51. How Do I Disable My 02 Durango ABS ?
  52. Access Panel For Spare Tire Is Locked Or Broken
  53. more speed
  54. Code P0132
  55. 1998 Dodge Durango starts hard then runs for 1 second
  56. dodge durango performance numbers
  57. input sensor
  58. No Floor Heat, we're broke from previous repairs and it's getting cold out!
  59. 2001 Dodge Durango Heater & AC Problem
  60. Positraction
  61. heating problems
  62. Durango Accident
  63. 2000 durango PCM? No bus
  64. 4wd Light On
  65. Turns over but won't start
  66. abs,brake light on back brake lights not working humming noise when moving
  67. Hesatation When starting out
  68. '99 stalls- help me?
  69. Computer code P1596
  70. Performance parts
  71. Dtc #1- P0720
  72. 98 Durango starts, but won't idle
  73. All steering wheel controls DEAD on 01 Durango
  74. Speedodometer starts working past 35mph
  75. o4 hemi intake? noise at 2000 rpm
  76. Durango Computer
  77. 2001 Durango Is Skipping
  78. 2000 durango/check engine light
  79. DriverPassenger Side Power Window/Door Lock Switch For Sale
  80. 2000 Durango Repair Manual
  81. recurring overheat problem
  82. P0456
  83. 04 Durango Exhaust
  84. Engine Sludge (auto-rx)
  85. Injector Circut Malfunction (P0206)
  86. ABS/Brake Light 1999-BIG THANK YOU TO ALL...
  87. 2002 Engine codes Hard Start
  88. Emission Check
  89. buzzing auto door locks
  90. Engine Check Light, Code P0440, and Clearing/Fixing
  91. my durango will not start
  92. No ABS on my 99
  93. 1999 Durango hard to start after sitting overnight
  94. Reset HVAC
  95. heat not coming out of vents.
  96. Help replace brakes.
  97. fishy smell
  98. engine overheats
  99. OBD II P0720 Code
  100. Need help with stock speakers in durango
  101. lowering kits
  102. Front wheel bearing...need help!
  103. *Want to Buy!* Stock Stereo!
  104. transmission
  105. 2000 durango starts but wont stay running
  106. Water Leak under passenger dash???
  107. Temperature gauge always reads lowest
  108. heater fan only working on high
  109. remote door lock
  110. water pump nipple
  111. 2000 Durango Idle Problems
  112. noise from purge solenoid
  113. 99 durango abs
  114. 1999 5.2 starter problem
  115. Move along...no solutions to see here...
  116. 2001 Blower Motor Resistor Location
  117. HELP w/ my front brakes!!!
  118. '98 heater blower issues
  119. Noise, can't find souece
  120. Wild Temp Gauge
  121. 98 Durango with electrical problems
  122. `01 Durango, got an exhaust question...
  123. Need advice...electrical is haywire
  124. 99 durango I hate it!!
  125. Need help from the experts...
  126. weird vibration
  127. 2002 Durango will not turn over!
  128. '04 stereo removal
  129. Heater Problem
  130. 2000 Durango - Infinity Speaker System
  131. Door won't even manually lock!
  132. Engine knock
  133. 2000 Durango Infinity wiring diagram?
  134. Lights have gone haywire...
  135. My old Durango Performance stuff on e-bay
  136. 04 durago airbags
  137. 1998 Durango Starts , but will not stay running
  138. 2004 limited features
  139. 2004 crazy horn
  140. ABS and Brake Light- 98 durango
  141. Need keyless remote programmed HELP ME
  142. Having Problem with starter, overheated?
  143. Engine Sputter Help!
  144. I need some advice peeps!!!!
  145. check engine light
  146. MOPAR PCM for Durango on e-bay
  147. Can't Start Vehicle...Possibly Alarm Problem
  148. 00 engine nock
  149. 1999 Slt
  150. Durango Overheat
  151. Starts but wont stay unless I hold the gas
  152. 1998 Durango
  153. 2004 Durango 1/4 mile times?
  154. 2001 Durango shift to low 4wd
  155. replacement insurance
  156. Remote Keyless problem 2001 Durango 2WD
  157. Durango A/C problem
  158. 2000 Durange Idle surge at startup and stops
  159. CruiseControl Problem
  160. High Oil Pressure
  161. 1999 dodge durango overheating
  162. No Resale Value! Whats Up?
  163. supercharger question
  164. heat and air only workon high
  165. 2002 Durango-Engine Malfunction Light issues
  166. Anyone know who to reset the computer?
  167. Durango Front Brakes Sticking
  168. Squeak noise coming from drive shaft or rear end
  169. Durango Mods
  170. No Turn Signals,
  171. my turn signals wont work,
  172. Build Yourself a "Home Brew" 3" Intake System
  173. First Dodge"loveit!"
  174. Throttle Body Spacer
  175. The SSBC Rear Brake Conversion Group Buy Is On!!!!
  176. Brake light and abs at the same time?
  177. Gas Milage and Engine Sputter Questions
  178. 04 Durango Exhaust noise
  179. 2000 durango caliper bolts
  180. 2004 Dodge Durango
  181. PCM 'no bus' mystery.... '99
  182. Durango Spare Tire GONE!!!!
  183. Durango Security,ABS,Airbag lights lit
  184. Attention Durango owners!
  185. Evaporative Emission Control System Leak
  186. Low washer fluid warning light
  187. Front A/C blower
  188. 2004 hemi a/c hot
  189. Hey CA. Members, better keep your,...
  190. Wiper problem on 2003
  191. need codes for 99 durango
  192. more pcm info - please?!
  193. I am getting tired of this already
  194. motor shutdown on highway
  195. Hypertech?? Worth it?
  196. 2003 Durango a/c problems
  197. 99 Dodge Durango Idle/Power issue
  198. 2002 dodge durango
  199. A/C Problems w/Durango 2001
  200. Cooling fan not turning off.
  201. Getting rid of engine ping, odd exhaust smell
  202. just wondering?
  203. Durango is Broke
  204. Brake Pedal Goes Almost All The Way Down
  205. 180 degree thermostat
  206. Remote Control Programing
  207. Help! Vacation in 2 days!!!
  208. Lower 4X4
  209. PCM Connectors are bad...
  210. will 265's fit on a 2000 durango with no lift?
  211. Addison, TX gettin 2004 Durango's
  212. 92 ford explorer
  213. 1999 Slt
  214. 2000 SLT for sale
  215. High RPM at start/ surges
  216. Durango Help
  217. New To the Durango
  218. engine performance lags at low RPM's???
  219. Check Engine Light (nobus)
  220. ac problem
  221. 98 durango keyless remote programming
  222. 1998 Durango Tranny Clunking Sound!!!!!
  223. durango rear end options
  224. STP Fuel System cleaner
  225. 1999 Durango SLT 4 SALE
  226. Durango-cool air intake
  227. Getting Rid of the Sludge
  228. Durango intermittenly dies while running
  229. AC unit 2001 durango
  230. Loss of Oil Pressure
  231. Reasearch
  232. Door Lock problems
  233. honda civic roughj idle
  234. 2000 Durango Cold Start Idle Problem
  235. water pump replacemet
  236. $20,000 Durango Yard Ornament
  237. options list
  238. need advice on installing amp in 2004 durango
  239. 2004 durango sounds
  240. bushings
  241. superchips for durango
  242. Help No power to headlights.
  243. New Exhaust System
  244. rear disc brakes
  245. ABS module
  246. Check Engine p1698 after remote start install
  247. 2nd gear thump
  248. 2004 Durango...who owns one?
  249. Shocks question
  250. Anti-Freeze smell
