View Full Version : LHS
- 97 LHS crank no start
- Eng. Starts at 3500 rpm
- LHS Rack Pinion broken - Junk it or fix it
- Dash fan blower stopped working after bump
- Chrysler lhs turn signal diagram
- 2000 LHS blower issues
- Need Location of Sunroof Drain Tube End on 97 LHS
- 95 lhs blinkers
- Gear selector in park and dash shows reverse
- Water on floor of 95 lhs
- 1994 LHS low pressure switch location?
- 2000 LHS infamous knocking, not timing belt, backfires when starts
- 96 LHS-need wiring schematics for the AC
- 97 Chrysler LHS In Limp Mode! Help!
- 1999 lhs
- New LHS owner
- 1997 LHS No Start
- Issue with LHS 95 not running right
- '97 Chrysler LHS ignition switch
- '97 LHS Vibration When Accellerating
- 99 Chrysler LHS 3.5L V6 with multiple engine faults
- what is this sensor called?
- 94 lhs rack & pinion
- 94 chrysler Lhs code 41
- Fan Problem
- LHS 99 shocks from Strutmasters
- 95 lhs the 1&4 does not fire
- Shaking and Wobbling in Front End of 94 LHS
- overheating
- code 66
- code66
- Engine Mounts
- RPM Drop and dieing 94 LHS
- RPM drop when stopping
- 94 chrysler LHS - rich fuel code?
- 1994 chrysler lhs
- I need help bad!!
- extra condenser fan
- Programming remote on 2001 LHS
- would you re-buy the lhs
- car shut off after engine reach normal temperture ?
- 96 LHS electrical
- blower motor resistor
- Starting Problem
- red oil light when key in on position
- Weird axle(?) noise
- flood damaged engine and tranny Is it rebuildable?
- idle control valve
- 98 Chrysler LHS overheated and died
- find drain cap on radiator
- Help!! whats this part called?
- 2001 Lhs Leaking Antifreeze
- 1999 LHS fuel pump
- 99 LHS stuck in limp mode?
- 2001 LHS Overheating
- 99 Alarm system malfunction!
- 99 LHS no heat
- Chrysler LHS letters
- 99 LHS Ignition Issue
- 96 LHS rack & pinion
- Fan wont blow and windows wont roll down.
- 1999 Chrysler LHS 3.5L 2 problem, Interior light keep flasking and engine noise
- Strange Noises under hood 2000 LHS
- 95 LHS 3.5lt
- 94 LHS BIG loss of POWER
- 1994 LHS 3.5 OBD1 Data Connector location?
- 1999 LHS idles hard at startup
- 97 LHS customization
- 94 3.5L Transmission issue?
- Replacing front wheel bearing on 95 LHS
- Occasional miss on a 96 with a 3.5, and does anyone know where the IAT is?
- 96 New Yorker No Start
- 97 LHS Cylinder 5 Miss Fire
- 97 LHS Rough speratic idle
- 1999 LHS fuel filter location how to change?
- Want to intergrate laptop with my Chrylser LHS. Any suggestions on how to do so.
- plz help with overheat problem
- Replace Center Dash Speaker
- 94 LHS 3.5 No start
- 96 Lhs 3.5
- Intermittent horn problem 1995 LHS
- 95 new yorker/Lhs is down - high idle
- 95 LHS no start when engine warm
- 97 LHS fuel injectors/rough idle???
- LHS shakes at all speeds
- 96 lhs Front end problem
- iat
- repair
- 97 lhs won't start Help !!!
- Chrysler LHS 2000 Heating problems
- need some advice
- PLEASE HELP Battery wont keep a charge
- Cam Sensor
- 2000 headlight needed
- I think my tranny literally blew up
- 1994 3.5 V6 PART NEEDED: Intrepid Concorde LHS 1994-1997 FUEL RAIL
- 95 LHS Trunk Spring
- 95 LHS overheating and no heat inside now
- '97 LHS with Check Engine Light Code #43
- 95 LHS stalls
- 1994 LHS 3.5 V6 Fuel Pressure Regulator FUEL LEAK!
- 94 lhs ? stummped
- car wont start
- LHS to 300M transmission swap
- 95 LHS Fans Loud
- HELP!!! 96 LHS no more start!
- 1994 LHS Whining noise from front of engine...
- coolant system
- 95 LHS Intake Gaskets
- Fuse Box
- Strange burnt smell and smoke - 95 LHS
- 95 Lsh
- 01 lhs tie rod end
- 97' LHS shuttles at high speeds
- 94 lhs tranny clunk??
- Car unlocks on it's own?
- Gauge Cluster on 94 lhs
- Idle on 94 LHS
- 94 lhs fault code 54
- chrysler99
- 1996 LHS Electrical gremlin grrrrrr
- 1996 LHS idling at 3,000 RPM
- 94 Chrysler transmission problems
- Most likely result of timeing belt falure during normal highway operating mean specs.
- 94 LHS AC clutch not working
- 95 LHS/New Yorker- ELECTRICAL NIGHTMARE (NEED HELP)
- '97 LHS proportioning valve leak
- 1995 LHS Timing Belt/Water Pump
- Mill code 96 LHS
- 96 LHS Wipers
- 94 LHS runs suddenly bad while cruising
- Chysler LHS 94 burned coil ignition
- speaker problems
- '96 LHS front wheel bearings
- car jerking and stumbing at idle or 45mph ?
- 94 LHS: Won't idle, misses like crazy
- 96 LHS Cruise Control
- 95lhs Problem Ergggggh.
- 93 Chrysler Lhs
- '95 LHS suspension related
- Side to Side Shake @ 30mph
- 96 LHS Tie Rod Bushings
- Replacing power door lock latch motor
- check engine
- 99 LHS heat/AC digital display not working properly
- 1994 Lhs Headlights Wont Work
- '99 LHS Heated Driver Seat not working
- 94 LHS not starting
- heater whine
- 95 LHS: Hard starts when cold
- Still no Start, Puff of smoke, and raw gas!!! WTF#$%
- 1999 LHS seat setting
- 1999 LHS overcooling
- front end noise
- Trasmission requires 3500 rpm to shift at cetain times
- code 12 and battery is good and connected
- 94LHS, Cranks,Starts, Miss,Ping, Puff nasty Fuel Smell
- 99 LHS Heater blows cold air
- IAC and idle problems
- How do you get past the anti-theft system?
- "97 Intrepid gauges drop to 0
- 2000 LHS Electrical gremlin?
- 2001 LHS mystery
- Surge/low speed
- 01 LHS: Engine dies and then fires back up in 1 second
- how to tell if LHS FRAME is cracked or broken?
- Filling COOLANT Alot
- odd no start 96 LHS
- LHS FRAME bad? Other problems/questions
- 99 LHS- A/C problem & Belt/pulley (?) problem
- 95 newyorker no start
- ac compressor
- 94 Lhs, Won't Start
- 95 Chrylser LHS AC
- 94 LHS transmission
- 97 Chrysler LHS electrical FUBAR
- 95LHS, fuel pump?
- ATC problem on '94 LHS
- Step by Step Tune-Up instructions/3.5 94 LHS
- Removing center counsel & shifter
- No Shiftup
- 1996 LHS Knocking Noise
- 1994 chrysler lhs radiator fan issues
- OBD II drive cycle to turn off readiness monitors??
- 95 LHS limp mode problems...here's the fix I paid for
- 95 LHS Sun Roof...problems
- Thinking about buying a '99 LHS...
- 96 LHS stuck in limp mode
- Code 33 A/C Clutch Relay, Anyone know how to fix?? please help!!!!
- What are syptoms of a bad EGR Valve??
- Wierd RPM Fluctuation and Vehicle shuddering
- tran acting funny after a swap.
- Compass Wiring Diagram???
- Help with lhs engine noise
- 99 Chrysler LHS occasionally won't start
- car probs
- Heater Hose tube leaking @ Lower Intake Manifold
- 95 LHS engine knocking/rattling
- 97 LHS loose in the back end
- looking for service manual
- no heat
- Wiper Motor 96 LHS
- 95 lhs overheated,then died
- 99 brake problem
- 1996 LHS COld Start Problems
- tranny issues
- 1995 Lhs Cold Temperment???
- 95 lhs starter problem
- 1996 chrysler lhs dies
- Healdight / fog light change
- ABS, Airbag Lights On, No PW or ATC - Help
- engine swap
- 1995 Lhs
- 1995 LHS Tranny Problem
- Cannot lock the door. Manually or with keyless????
- Reflex Wiper Blades
- Junkyard Engine no start
- battery dies
- 96 LHS; no oil registering on dip stick
- Radio question.
- 1999 LHS Radio-no reception
- 1996 lhs spoiler?
- No WIpers Or steering wheel controls
- No Wipers or Steering wheel controls
- 96 LHS Wiper Issue
- Climate control box
- Bad sound when turning the wheel
- 94 LHS intermittent starting problem
- 1995 LHS /Starter Location?
- 1995 Chrysler LHS 3.5 V6 24v - Flexi Fuel ???
- LHS has a power surge while driving at various speeds--scary,
- 94 lhs won't start
- aaaggggghhhh help anyone
- Service Engine Light
- 95 lhs trouble codes
- keyless entry
- Aftermarket fuel rails?
- No display on 95 Chrysler LHS CD Stereo
- 1994 LHS engine fuse block wiring diagram...
- 94 Lhs frame straightened now it won't start?
- Door Locks on '95 LHS
- LHS Rough Idle
- 95 chrysler cirrus <starter>
- 99 LHS- Wont shift into Park
