View Full Version : Blazer
- Test
- Right wheel play
- 1993 S10 blazer starting, (and running probs)
- looking for new shock recommendations for 96 Blazer
- Tbi without oxygen sensor
- Noise when shifting to reverse and accelerating
- Problems Starting When Warm
- Fuel Filter
- Still having problems?????? Help!!!
- Wheels...
- help! losing coolant.
- EGR Valve
- Secondary Air Pump Replacement
- 2004 Blazer fuse box
- gear ratio's
- Starting Problems
- s10 groaning noise
- Blazer VS Yukon ? 1998 - 2000 Issues ??
- ???supercharged 1995 4.3 BLAZERS
- 4.3 Vortec Needed
- black plastic trim replacement 95 blazer 2dr
- 92-94 4.3vortec swap in 91 blazer
- polishing a/c lines
- 99 Blazer Idles High, SES light on
- 98 Blazer flasher noise
- 86 S-10 Blazer
- FS: 89 s-10 blazer 4X4 $650
- Foam in transmission question
- '93 S-10 Blazer stalling:Need Help
- Fender Flares
- Installing CPI Unit?
- Thanks For The Fuel Injector Help
- 4-Lo Light Flashing
- bad off road experience, water damage please help
- fan clutch
- a/c problem
- a/c problems
- Fuel Cutoff Relay?
- 96 for $5,000 Worth it?
- S10 Blazer Cat
- 89 S-15 Jimmy 4.3L Overheating
- Interior noises
- 1998 blazer rear window alignment
- Gurgling / srinding noise when braking
- lookin for brush guard
- 1992 Blazer Starting Issue
- 1997 Blazer LT AWD transfer case 4x4 switch
- 85' 4x4 checking transfer case
- '97 blazer with gurgling water noise
- 88 S10 Electrical Problems
- who's for the older S10 Blazer rear window wing?
- new noise
- oxygen sensor replacement
- electrical problem straight from purgatory
- 1992 Blazer 4x4 4.3 Vortec wont start
- A/C Problem
- K-Blazer Fuel Economy
- 1991 Blazer 4.3 Oil Leak
- 1997 Service engine soon light, need help
- 93 Full-size Blazer - gurgling noise in dash
- 1998 Chevy Blazer Brake Lights Stopped working.
- Side Mirror Vibration
- go to turn engine over.........nothing happens
- Engine sounds low on oil but is full
- No Heat!!
- Xenon Fog Lights
- 94* 4.3Li Vortec S-10 Chevy Blazer Engine Needed Seattle Wa
- oxygen sensor question
- 97 s10 blazer cant remove ignition key
- 97 s10 blazer rear window washer hose drip
- Ethonal
- 97 Blazer Mystery leak
- electrical problems
- 96 Blazer - camshaft sensor?
- AIR System
- 95 Blazer missing and rough Idle.
- Fuel Injector Voltage Question
- Hello
- OBDII Reading (Part 2)
- replacing brake caliper
- 2000 Auto 4WD
- freeze plug, coolant loss....
- burning rubber smell
- removal of oil cooler lines
- Rotors replacment
- 89 Blazer 4.3L performance
- 2000 ZR2 rattaling noises on every bump
- Full Size / 2 Door
- Fuel Injector Help Needed
- 97 blazer - anyone have a flowmaster????
- 1998 no power?????
- 1998 Blazer Shifts Hard only 1st to 2nd????
- New here, '95 Blazer Questions
- 1996 keyless entry programming
- 84 blazer HP
- 98 Blazer-Oil leak at rear of engine-ideas??
- Spark Plugs
- 1992 S-10 Blazer For Sale....Cheap!!
- 89 balzer not running
- Head Gasket Blew
- Is it normal for oil guage to drop at idle?
- bumpers
- Pulling to Right when braking
- Transmission slip and cycling; slow selector
- 97 stock stereo removal
- water in passenger floor and sloshing sound behind dash, HELP
- '98 S-10 Blazer 2WD offset?
- 93 chevy 10 blazer 2wd tranny question
- 85 S-10 Blazer Problems
- 78' blazer push gas but no go then stalls
- 89 350 TBI Code 42 Assistance
- Stalling after Fuel Tank Installed
- average life
- 2001 Blazer ZR-2 Taillight Removal
- axle oil leak?
- Tires
- Oil consumption
- Hard to start
- Low beam out
- 1993 blazer steering column replacement
- 50 weight motor oil in a 4.3?
- '93 blazer electric 4wd question
- need some help!!
- Various Problems w/ my 1995 Blazer
- 96 Blazer worth 2,800??
- Oil cooler lines 1998 Blazer
- Blazer Foglights
- OBD II reading for Emissions problem bay 1 ???
- full size '91 blazer FS in chicago
- Auto Lock-Unlock on 04 S-Blazer
- another thing to fix
- ok THATS IT!!!! (TRANSMISSION!!!!) AHHH!
- Power Seats Not Working?????
- please help me!!!
- need some advice
- Crummy ride quality...2000 Blazer LT 4WD
- 20" rims 4 sale
- No Four Wheel?
- grease fitting locations
- front wheels tilted
- kreaking sound in the steering
- i need help with a 95 blazer
- performance air induction?
- body lift kit?
- 95 Blazer probs. just replaced EGR valve...please HELP!!!
- Hello, newbie! HEADERS WANTED!
- 87 blazer
- Pin Stripe Remover
- 1996 s-10 blazer Pushbutton 4wd problems
- 94 Jimmy: autom transm. 3rd&4th gear
- pilot bearing keeps getting chewed up
- mini overhead console
- Multiple Starters for '88 S-10 Blazer
- rough idle ,vibration
- 96 blazer power seats quite working??? help
- Need some help findin some parts.
- rattling noise on startup
- 1997 blazer suv fuel guage stuck on 3/4 tank
- Starter won't disengage
- heater
- Air cleaner inlet hose grill attach point
- Grrr Electrical Problems
- 96 S-10 Blazer rear traction
- New Member, ?DTC 83
- 97 Blazer wont stay in park!
- still have starting problems!
- Check Engine Light On Please! Help.
- coolent temp gauge inop
- Help Please 1996 S-10 Blazer Low Engine Heat
- Rattling noise coming from the engine
- help.....
- remote keyless entry
- Power steering hoses bad too?
- Replaced Brake Pads squeal and getting hot
- Daytime Running Lights
- dash trim
- Interior Lights won't shut off even though the switch is OFF and DOORS are fully shut
- Questions
- Carpet sux!
- Help! Transmission ???
- 98 Blazer turn signals intermittent
- Need Brake Shoes
- reprogramming new keyless remote
- 4 X 4 automatically changes
- i GIVE up !!!!!!
- what to do w/ a '94 blazer?
- Pro Comp tires
- 97 Blazer..Truck dies for no reason
- oil sprayin
- phantom check engine light
- Emptying and removing gas tank
- front drive shaft 87 blazer
- secondary air injection
- acceleration/gas pedal problem? - 85 Blazer
- Slight Grinding Noise
- 98 Blazer v6 How to remove fan?
- 96 blazer rear brakes sticking
- Electrical problems '97 blazer
- What brand of oil and viscosity does everyone use ?
- looking for a k5 blazer
- Valve Taps!
- LS1 or Work on the 4.3L??
- a question for merlin from another tech
- Max Speed for 98 Blazer with Hypertech Comp.
- Lowering kits?
- Emissions problem??
- electronic 4wd on 93 blazer doesn"t work properly
- Blazer GFX Edition?
- 95 Blazer 2.8 timing question...
- 93 BLazer Starter Removal
- 91 blazer with hood that does not open
- FRONT suspension squeaks ~ !
- Starter Motor Wiring Problem???
- Replacing egr valve
- Need help on what to do/look for 4.3L
- Has anyone heard of CFM-Tech's High Flow GM Throttle Blades?
- temp. speed control
- 1993 Won't Go Into 4WD?
- odd wetness problem on driver/passenger
- truck runs bad at idle
- Installing water pump '98 Blazer
- 97 blazer shifts hard
- New Additions to my K5
- Passing Thru the Firewall?
- 96 blazer heater core removal
- 97 Blazer Rear Right Axel
- Clicking on start up
- Dual exhaust in the newer body style?
- 350 in 92' S10 Blazer?
- Fuel Pressure Not Maintaining
- 94 V6 Bell Housing Removal
- Something about air ride suspention??????
- 95 w idle problem
- Instruction: Heater Core Removal - '80-'87 K5 Blazer
- To buy, or not to buy?
- 2000 Blazer...Lousy gas mileage....
- Parts '97 Blazer
- 88 blazer bleeder valve for cooling system
- 1990 S10-Blazer
- Brakes
- Programming keyless remote 1995 Blazer
- Need Blazer Help???
- 96 blazer-black soot and lack of power on steep inclines
- fuel injector cleaner
- Noticed Seal between hood and engine compartment...bent/broken...
- Water coming in from dasH?
- dash lights dim???
- Gas Milage Reports
