View Full Version : Malibu
Pages :
1 [ 2]
3 4 5 6 7 8 9 10 11 12 13 14 15
- 2003 Malibu Electrical problems :(
- grinding noise when picking up speed
- 2005 classic engine shakes w/ ac on
- Whats up with our LZ1 mileage?
- 2003 Malibu whining noise
- Malibu from the depths of hell Help please (transmission/sensor)
- 2011 vs 1999 Makibu
- 05 MAXX LT P0449 Code
- 98 Chevy Malibu
- 2001 Chevy Malibu Overflow Tube
- Replaced PCM
- Adding factory keyless entry to 2000 Malibu?
- 2004 Classic replaced passlock cylinder
- 2008 Malibu w/ clicking A/C & Heat.
- 2005 malibu p0449 codes
- 2004 Chev Classic chiltons/haynes manual?
- Malibu LX9 3.5L Coolant change
- 98 malibu wheel n front drive ruff
- power steering hose ??
- Abs cel lights and gas gauge
- Gold Edition 'Bu
- 2004 Classic 2.2 Ecotech
- Power Door locks not unlocking
- Camshaft position sensor
- 04-05 Malibu Classic General Thoughts?
- af news video: 2
- RPM's go up but no acceleration
- Thermostat going up and down
- verify crank bolt torque spec 1999 3.1
- Oil pressure light never come on
- 03 Malibu Crank Position Sensor
- 05 malibu gas problem
- 2000 Malibu no heat or a/c
- EGR cleaning/diagnosing
- 05 2.2 ecotech p0826 andp0026
- P00300 - Any ideas on how to solve that?
- Theft-proofing vanity plates
- 2005 Malibu classic overheating
- 2000 malibu no oil to rockers
- 1999 ls Find Ball joint boot
- 2001 Malibu won't start after head job..
- 2006 Malibu Starter Wire Hookup
- 2002 malibu radio disable lock out
- Car shakes when stopped in drive.Which Mount?
- Clogged converter ruined engine?
- 02 malibu stalling
- Making silver cars more noticeable in stormy weather
- Emissions Test( Readiness Monitors )
- 2001 Malibu overheating/brakes issue
- malibu issue
- theft light on consistantly and car still runs fine???
- air conditioner electrical issue
- Body Repair
- 2007 Maxx Remote Door Lock
- 2005 Malibu 2.2L Catalytic Converter
- Mal Maxx KS
- help! 97 malibu engine removal problem
- 2000 Chevy Malibu Electrical issue
- malibu 3.1 fuel rail reassembly help??
- 2000 chevy malibu start car but shuts right off
- malibu 3.1-just changed head gaskets. now it just cranks and backfires??
- 1999 Malibu 2.4 Running Rough
- 2005 Malibu LS V6 - Scrub radius
- Radiator Fluid Leak???
- AC question
- ignition switch???
- 2006 malibu ss HU replacement
- Cooling Issue...Please help
- any ideas??
- ABS light, no codes
- Just got the heads off, now I have some q's
- Third Coolant Reservoir Cracked and Leaking
- Is it possible to put a 350 rocket in a chevy?
- 98 Malibu LS won't start
- Malibu Maxx dvd lcd
- 98 malibu 3.1 hard starting
- High Idle and Trans Shifting Problems
- Considering buying a 2000 Malibu with a few problems, is it worth it?
- ABS scan
- All turns lamps out, fuse fine. Any thoughts?
- Correct ABS resistance reading
- Really Mad Malibu!
- 99' Malibu PLEASE HELP
- 00 malibu leaking coolant
- Radio problems
- Humming/whining noise from front end
- 03 malibu hubcap with plastic lug nuts behind cover
- passlock or cylinder 98 Malibu
- 2003 Malibu heat on full?!?
- A/C Noise
- oil in head valley please help
- 2000 Chevy Malibu, Won't go over 4k RPM
- Fuse Box?????
- 2001 malibu wierd noise from dash
- 1999 Chevy Malibu starts up, dies, then starts fine
- 02 malibu theft system problems
- 2001 Malibu pass power window problem
- 98' w/3100 - no spark, randomly starts
- 2005 door lock issues
- Need to replace front passenger door actuator 2002 Malibu
- no fuel (pump, filter, fuel pressure regulator?)
- 2000 malibu no fuel gettin to motor
- no fuel to motor
- 1999 chevy malibu fuel filter disconnect broke?
- 1999 V6 Cooling fan issues.
- 1999 malibu rear 3 spark plugs, best way to change
- A/c hot
- a/c problem
- 2010 Malibu headlight
- 2003 Malibu wont turn over.
- Half of HVAC lights out?
- Need advice on EGR Valve
- RCDLR location on 06 Maxx
- 0442 code and vacuum leak
- Coil Packs on 2.4?
- 99 Malibu 2.4 Bad Cylinder???
- 99 Malibu EGR
- 2003 won't start
- 2005 Malibu 3500 Eating Oil
- 2001 Malibu Power Steering Gear
- Park/Neutral saftely switch
- Check engine light
- 2001 malibu 3 problems
- Help with trouble codes
- Tire wear
- 2001 radio security light
- 05 Malibu Maxx VIN# question
- 05 Malibu Maxx LS rear wiper arm
- 05 Malibu Maxx LS sunshade won't retract
- 2003 Chevy Malibu...Can't turn key
- intermittent heat
- 2004 Drivers side low beam doesn't work hi beam does
- 99 malibu speed sensor
- DexCool gunk in the reservoir.
- 1998 malibu transmission question
- What are the torque specifics for a 2001 Chevy Malibu 3.1 V6 Model J?
- need help with 2001 malibu battery drain!!!
- 03 malibu
- Rpms fluctuate when slowing down
- 2001 Malibu will not fire
- 1998 Malibu rough starting
- classic forces to speed up
- 2006 Malibu Maxx Door Locks and Alarm
- Front end noise??
- seatbelts tensioners?
- 08 Malibu Headlight problems
- 99 Malibu - blower motor only works at startup for 3 mins, nothing else
- 2002 malibu rear wheel bearings
- 1999 Malibu rear speakers problem!
- 2004 malibu doesn't go into gear....
- Malibu Maxx Color
- Ticking sounds
- Remote stopped working
- 05 Malibu 3.5 fuel gauge fail
- 99 Malibu 3.1L-major tuneup
- How do you reinstall an ashtray in a 2003 Malibu?
- 2.4 or 3.6 in new Malibu?
- 2003 Chevy Malibu fuel pump fuse question
- 2001 Malibu - No Oil Pressure
- Electrical Problem?
- 2006 with 405,000 and only one repair
- Windshield washer fluid pump-06 Malibu
- Intake gasket fixed, but now the car
- 2005 malibu trouble code po455
- Sounds like a bearing going bad...
- Malibu wont start when cold
- cd player swap
- 2000 malibu 3.1
- 2005 classic = cabin drafty=-
- rear window regulator 99 malibu
- car wont start.....?????
- 2010 2.4 oil filter location
- possesed right directional
- El camino frame on a Malibu?
- theftlock question
- 2011 Malibu(USB IPod connection)
- 2005 Chevy Malibu Wipers
- 2006 malibu
- 99 Malibu no brake pedal
- 2002 malibu heater switch or fuse or relay?
- 2008 Malibu Brake Job
- 98 Malibu LX 2.4; dies after few miles ; will start again after about 1/2 hour
- classic malibu
- Buzzing? No - Sounding like a moped
- 2010 Malibu headlights
- 2003 Malibu EVAP Purge valve location
- Need Advice 99 Malibu- Timing chain failure 2.4L
- 2006 Chevy Malibu Maxx Rear Wiper Removal
- Replacing Serpentine belt
- 1999 Malibu stalling out with codes.
- '02 Malibu 4T40E Trans Noise
- no start
- 99 Malibu Headlight Repair
- malibu 2003 passlock?
- Torque Specs: Upper Intake manifold? lbs/per bolt?
- 05 Malibu cruise control steering wheel light out
- 99 3.1 V6 coolant loss overflow tube
- 2000 No turn signals no flashers
- MY BLINKERS! urgent!
- Body Control Module location
- Malibu's must be improrving...
- 04 maxx blend door location?
- could use a little help please
- 2000 Ambient Air Temperature Sensor Location
- 2006 Malibu Maxx AC Low/High side values.
- The 2010 chevy malibu
- 2002 front motor mount
- rust just below tank fill up door
- 2001 Malibu
- rear brakes 2005 malibu
- 2009 Malibu Hybrid Retrofit to Standard Ecotec?
- 98 malibu, head gasket replacement, now no start
- break problem
- 1999:engine knock
- P0420
- 00 Malibu 3 issues
- 2000 malibu overheating stumped
- 99 3.1 auto malibu, Dies at highway speeds.
- 2002 power window problem
- 2005 chevy malibu
- 2005 chevy malibu
- outlets not working-possibly others
- 2003 malibu coughing start
- 99 Malibu hard steering question
- problem bleeding the brakes
- pass key 3 or pk3
- Passlock Issue - 2001 Chevy Malibu
- 2004 Chevy Malibu instrument light problems
- Failed E-check
- 2004 Malibu Ticking
- buzzing door
- 1999 Malibu - Intermittent missing
- Airbag light stays on when car is shut off
- whats your operating temp on 06
- Tail light help please
- Malibu '07 knocking noise when turning..
- Remote start install
- 99 Malibu ABS light
- will a '98 3100 V6 fit in a 2000 malibu?
- got the correct CPSensor but it will not slide in..
- A place to buy weatherstripping for 03 malibu
- Intermiten A/C
- can you change transmissions from 98 to 01 malibu?
- 2005 engine type
- 2005 engine type
- 2005 engine type
- 2005 engine type
- 2001 Malibu Engine Light
- How many bolts in the oil pan?
- 99 Chevy Malibu Overheating PLZ HELP
