View Full Version : Impala | Impala SS
Pages :
1 2 3 4 5 6 [ 7]
8 9 10 11 12 13 14 15
- Loss of power during acceleration
- Washer Fluid Fuse/Motor
- 2002 Impala - Constant noise like a weed-eater while driving.
- '02 Impala 3.4L: Intake Gasket Morass
- 2003 Impala Erratic starting problems!!!
- 02 hvac fan/blower acting up?
- Mirror courtesy lights will not shut off
- aftermarket stereo install static
- 2003 impala gas mileage
- Mystery Coolant Leak
- Classic Impala
- "nugg" sound coming from front wheel areas.
- 01 impala fuel filter problem
- Fan Control - Blower Motor
- Steering Rack leaking Impala 2001
- P0128
- New T47H Torx and T60H Torx.
- Radiator Swap
- Replaced battery and now radio won't turn on
- 2001 Impala P0306 code
- Which is Cyl #6 2001 Impala ?
- Sluggish performance
- Engine Vibration
- PO420 code after installing an aftermarket cat
- Creaking
- Power steering Cap '00 Impala 3.8L
- popping noise
- 2003 Chevy Impala Key Fob
- 2003 Impala Left Front Clicking
- 2004 Impala SS question
- Did the dealership lie to me?
- convert
- 2004 Chev Impala speakers not working
- 01 chevy impala instument cluster
- Heated seat not working
- HELP! 03 Imapala One headlight not working
- help, i srewed up big time!!!!!
- inspection sticker paper slip
- Quality???
- 01 Impala Cluster Replace
- intake/oil leak
- Coolant issue
- 01 Impala coolant light
- Please Help Me Find This Impala Accessory
- no heat
- A/C Tapping 06 Impala
- 2008 Impala radio swap
- Coolant and transmission
- engine noise from front pulley's
- Tuft of white smoke from hood.
- was up
- AC clutch replacement
- Question about the dreaded intake problems.....
- Engine swap
- 2004 oil pressure gage
- 2001 troubles multi codes, gas guage messed up, stalling/lunging
- 03 Impala - engine rattle
- Trans issue
- General Opinion
- tune up
- 2004 Impala code 0102
- heat controls
- Weird electrical problems
- electrical problems/ignition
- Impala 3.8L transmission ECM relearn
- 2000 Impala Stalling And RPM Problem
- impala 03 - no mirror and roof light
- Can I Bypass A/C with smaller belt?????
- Difference between Caprice and Impala
- No heat, plz HELP!!!
- 2002 impala low oil pressure light
- Brake booster or master cylinder problem????
- Small composite elbow leaking Anti-freeze
- IP Problems
- would you sue the dealer?
- 07 impala tire pressure reset????
- Was I ripped off?????
- 01 impala with 3.8 temperature guage goes crazy
- New CD Player Questions?
- Power output?
- Po410
- Transmission Problems
- o4 impala rough idiling
- Do Not Sign Everything Put In Front Of You When Buying A New Car!!!!!!!!!!!!
- owners manual
- 2000 Impala
- My Impala shuts off while driving
- Impala LS 2001 struts and shocks
- F/I kits wanted for 00 Impala LS
- '01 Impala 3.8 Whining Sound When Driving
- 2001 Impala Temp Gauge Problem
- Replacement shocks
- Should I buy an Impala?
- Power Windows Failure not 1 but all.
- 3.4L LIM R&R Problem
- Tranny problem with my 05/3.4 impala 51 000kms
- Imapala 3.4 and 3.8 mpg
- Tire rubbing sound
- I pulled on a wire I shouldn't have, need some help please
- A/C & Heater Power
- Driver's side window
- 2004 impala speedometer problems
- Need help with oxygen sensor
- '04 Impala Heating problems
- rear creak and squeak
- Recurring problems with my Impala LS
- 2005 Impala no heat drivers side only
- 06 Impala LT - Intermediate Steering Shaft
- Changing Doors
- 62 Impala 4 door
- 03 Impala instrument/dash lights won't come on
- Idiot needs help!
- can someone please help
- '02 Impala 3.4l, 97K: Sudden No Start
- Drained Battery
- 01 Impala - Headlights stay on w/ key off.
- Driver's Window
- Tires
- 2001 3.8 pwr steering question
- 01 impala 3.8L Clogged CAT
- abs disconnect how do I turn off the light
- Cooling System
- Throttle valve body leaking
- Interesting article.
- 2001 Impala 3.8 Screech Sound When Starting
- sensor/catalytic converter
- Catalytic Converter
- '05 Rear Brakes....
- How do I know if calipers are bad
- High beams are inop
- camshaft sensor
- rattleing of the dash board
- rotors
- 2005 impala ss starting trouble
- Car Stereo Locked
- Stereo Question
- Hazard Switch Part Number?
- Camshaft Position Sensor
- Rotors
- 3400 Engines
- 5x115 vs. 5x114.3
- Tune up Question.
- Passlock problems
- 04 Upgrade questions (tach and DIC)
- i need major help
- Rear strut mounts
- 2005 Impala - Cabin Heat takes forever
- impala Ex police surveillance button
- 2000 Impala fuel gage
- no controls
- mysterious fog on windshield that won't go away
- strange sound every time I brake
- Fog lights for impala 03 (base)
- need help with rh rear door handle
- wheel spacers on 03 impala LS
- '07 Impala SS Wheels
- 4 way flasher/turn signal problems
- i need door panel and floor carpet for 1965 impala low price
- M15 tranny issues
- Help...trying to add a tach to 94 Impala ss
- '67 Impala convertible for sale, 327 ci
- 2004 Transmission Bucks between gears
- camshaft position sensor
- Passenger Wiper Arm / vibration in steering
- FYI Intermediate Shaft Lubrication
- location
- Key in ignition alarm
- Radio dimming out
- impala
- A/C Vents Not working properly..?
- help
- Fast Idle problem...Help, no hair...
- 2006 impala A/C quirk question
- Clunking problem in 2001 Impala
- 2000 impala dies
- Trouble with remote entry...
- 01 Ls Message Center (canada)
- problems shifting gears
- 2003 impala 3800 engine seized
- 03 Impala LS ABS/Traction Off ligt stays on.
- Front speakers?
- Replaced the battery, car stalled after 2 seconds and won't crank
- Impala 9C1 strut/shock replacment?
- '03 Impala LS Check engine/service light
- shock probs/what to do
- Over head information center 2000 Impala
- 2002 Impala Brake Lights
- just curious
- 2001 Impala temp guage and a/c
- 2003 Impala engine knock
- 2004 Impala Brakes, Carpet, Paint
- Radio Issue
- 2000 3,8 impala misfire
- 2002 Impala LS no start sometimes, passlock?
- P1811
- Oh boy....
- wheel skins
- G.M front pads
- 2004 Impala CD Stereo Question
- impala 2000
- Radio Can not Turn on
- Ac issue/black smoke
- 2000 impala LS
- 2001 Impala Mirror
- 01 Impala auto lock not working
- 2001 Impala shifting issues
- 2004 blower motor won't turn off-battery being drained
- Remote Control Buy & Programming
- impala/caprice
- 2002 Impala keyless programming problem
- 2002 Electrical Issue
- A/C Vent
- Hard Starting 2005 Impala
- 2000 impala Headlight Issues
- ABS Kicks In While Driving
- 2003 Impala- Skid maybe transmission problem!
- Problems starting w/ key after tranny replacement
- 2001 LS fuel gauge problem
- 2000 Impala LS A/C Fan Problem
- Wanting to install Nav system
- proper rim and tire size
- Clicking in the dash board?
- impala keeps quititng
- Rotors for my 2003
- Impala A/c trouble
- Disconnection of daytime driving lamps DRL
- Stearing not locking, With a no start
- 2006 Impala LS
- 2001 impala overheating
- 2003 hums
- 2002 Impala Settings Menu
- Lt-1
- AfterMarket Radio Diagram
- 02 ImPala Over Heating
- A/C Coil 3.8l Impala 2001
- 02 Impala battery drain
- air bag light
- Service manuals and books
- Help with Belts?
- Impala hesitates
- Heater motor wont work
- Oil Pan Gasket
- '02 Impala (3.4l): Intake Manifold Gasket Replacement Q's
- 2000 impala LS stalls
- A/C problem 2001 Impala
- Hard shifting when a/c is on
- Changing The Tire Size On Impala's
- 2000 Impala LS wont start
- Tire size for 05 Impala
- 2000 Impala throttle issue
