View Full Version : Lumina
- richtazz or Jeffcoslacker
- 95 Lumina temp/no heat
- please help
- dash battery light on
- Doing my LIM, a couple ?.
- overheating while freezing outside?
- Cylinder Head Removal
- no brake pressure
- 97 Lumina spraying antifreeze
- Frozen cooling water...
- whatchya think
- 91 Lumina dead
- 97' loosing antifreeze
- Some guesses?
- Replacing Fuel pump
- 92' 3.1L - Battery draining but alternator and battery test good...
- Light roar coming from AC/Heat
- 92chevy lumina stalls
- something burning while warming up
- brake problem
- install manual fan switch=
- 98, p/s fluid question=
- 90 Lumina 3.1 AT Issues
- 93 Lumina Z34 pucking bubbling dash any suggestions?
- 97 Lumina will not start
- How do you replace the front wheel speed sensor?
- Can I adjust toe out?
- Airfilter Box loud noise
- 96 Lumina brake lights and dash lights
- Rough Idle
- 96 Lumina no oil pressure - Camshaft issue?
- 1997 chevy lumina abs question
- Lumina Fuel and sensor problems
- Rear Defogger -- Stumped
- 95 Lumina, Speedometer erratic and car wont shift
- bad tracking. alignment?
- 91 Lumina rear brake caliper won't adjust
- 1998. replacing carpet =
- 93 Lumina Shift Selector Console Shift
- 93 Lumina Z34 heater control no lights
- 93 Lumina Z34 Anti Lock Brake Light Just Blinks
- brake shoe stuck onto the rotor
- Lumina 93 - V6 3.1
- disable "low coolant' light on 98=
- stalling at stops loud
- Location of sensors
- 93 Lumina problem
- auto door locks
- Hood lock?
- brake conversion?
- replacing shoes on drums
- 95 Lumina Short Circuit
- 97 Lumina coolant not circulating
- 96 Lumina "Anti-Lock" light
- 97 lumina 3.1 fuel pump
- 95 chevy lumina is not getting any fire from spark plugs
- 92 lumina - rear disc brakes
- Fixing trunk pop
- need HELP ... ASAP !!!
- Brake light switch wiring
- spoiler
- 99 lumina won't start
- SeaFoam?
- 97 Keyless Entry question
- Oil in Coolant - Head or Intake Gasket?
- Stepped on the brake and it died
- 97 lumina 3.1 o2 sensor and egr valve problem-help!
- jump start created problem
- 97 lumina 3.1l thermostat
- help getting amp wiring through firewall
- Aftermarket performance suspension parts
- Low amount of heat from upper vents
- Rough cold weather starts
- 1992 Chev. Lumina 3.1 L
- Transmission tuneups
- 98 Lumina 3.1 - P1671 Driver 4 Line 1, code?
- 98 Lumina Won't Start Sometimes
- Bizzaro problem-clock on all the time
- Lumina Just Died
- 91 3.4 Z34 Heater Core Removal Help
- 98 Lumina heads
- 1990 Chevy Lumina Shuts Off when engine warms up.
- 90 lumina speedometer
- 96 lumina ignition switch pin diagram
- No Ignition power
- 99 Lumina full urethane suspension kit
- A new toy
- 1999 3.8 Spark Plug Thread size
- Buying a Lumina tomorrow
- "97 Lumina won't start - NO power
- Exhaust swap on 00 Lumina
- 97 lumina/monte carlo po141 o2 sensor???
- quick tire question
- 99 chevy lumina
- 98 Lumina 3.1 Loses Fuel Pressure sitting. New Pump/Filter/Regulator!
- 96 lumina temp gauge not working help!
- Lumina'97 - dashboard "Brake" light is on, then getting dimmer
- The dreaded Unibody Repair...Trailing Arm (Stab.bar)
- 1999 Lumina 9c6 car.. MINE!!!
- 1992 Lumina Euro NO Spark #6
- cylinder # 5 dead at idle
- 96 Lumina Brake lights illuminate intermittenly
- 96 lumina pulls to the right
- 92 lumina crank position sensor location
- Damn aftermarket
- hard to start after sitting
- 1992 Lumina Euro Fuel Filter Question
- Renaming the Lumina: POLL
- #5 Cylinder Dead At Idle
- hard starting, dead spot, and bogs down
- engine code 24 lumina apv
- 97 Lumina remote trunk button
- doing the PCV valve in 3.4L v6 (/94 Lumina)
- removing the instrument cluster
- Electric Fans always on
- water pump???
- 1994 Lumina Euro - Wiper and windshield spray not working
- 1990 euro speedometer help please
- 3800 Alternator Replacement Guide!
- Shifting Malfunction
- 2001 Chev Lumina 3.1 v-6
- Can '96 transaxle be removed without pulling engine?
- Help! Car Died, Mechanic says computer went out
- What the hell color is my /94 Lumina?
- 91 3.4 Tranny Slipping in 2nd gear i think?
- 1992 chevy lumina
- 96 lumina temp guage problem
- '98 Ltz 3800 power steering
- 96 Lumina intermittent heat
- 96 Lumina Hesitation during acceleration
- '97 Lumina stumbles and stalls when hot
- 91 Lumina sudden death problem
- 98 (base) brakes *&_#@
- 97 lumina 3.1 belt problem
- How do I change the Oxygen Sensor? /94 3.4L v6...
- Egr?? Need Help!!!
- Idle speed for 1995 3.1L Lumina
- Help! Front vents won't work
- will it work?
- wher to find?
- Crankshaft Position Sensor Variation Learning Procedure
- 1996 Chevy Lumina won't start
- E-fans on 1995 3.1L Lumina
- 1995 Lumina 3.1L Backfire at 2000-3000 RPMs
- Still overheating!
- 1991 lumina, front strut assembly
- Gas Tank Rattle
- 4T65-E Pressure Control Solenoid fix
- Transmission losing gears
- 93 Euro: fuel pump and EGR valve
- 1997 chevy lumina abs light is on
- 93 lumina euro 3.1
- 3.8 Harmonic Balancer Removal
- speed sensor 90 lumnia
- 91 Chevy Lumina Euro
- cold mornings: hard to start, rough running, low idle, stalls out
- Speedo Stopped Working
- 95 Lumina Humming Noise
- Install universal remote...
- 91 Lumina PLEASE HELP
- 2001 Air Pump full of water!
- Clicking when touching brake
- Tune up Parts (OEM or AutoZone/Pep Boys)
- what turbocharger can I use on a lumina ss 2003 ?
- 1998 lumina LF wheel bearing trouble.
- 99 Lumina Defrost Problem
- Oem Spark Plugs ???????
- 92 lumina reverse problem
- Rear Struts/shocks /94 Euro w transverse spring - How to / Help
- I have had enough!
- Need some help.
- starts but stalls
- About engine identification and ignition control module ...
- Chrome tail light trimming
- 98 Lumina - Radiator water disappearing / leak ?
- 93 Lumina failed emissions NOx
- 97 Lumina EGR Code
- Replacing dashboard gauge lights
- Where is the PVC Valve Located????
- 1995 Lumina gas Mileage
- 95 ls lumina ac not getting cold!
- 97 chevy lumina
- Whats the punchiest powertrains in lumina's
- Intermittent Code 42 w/ more info on 3.1 Lumina Euro
- Pls help: complete loss of acceleration, now won't start
- reset change oil
- Intermitent Code 42-91 3.1 Euro
- Just Curious
- Serious Help: Clicking Noise When Slowly Moving
- Replacing brake pads on 91 3.1L Lumina and EB ?
- Can you mix Dexron 3 with dexron 6?
- chugging/rumbling then dies
- This is why you should change your tranny ATF. Tuneup stuff.
- Knocking noise suspension
- Fun with SLO: Under Doors: Special Treatment!
- cruise control out
- Fixing Front Grill - 94 Lumina
- Fixing cracked and warped Front Plate-Holder
- Drove with -1.4 Qts. Tranmission Fluid
- 93 Lumina euro front end issue
- Lumina Idling Problem
- No heat
- 96 Lumina Idle Problem
- Heater core
- Vtech vs. 3.4 liter engine
- Emergency Brake Warning: Update with photos
- Can I use high-heat engine paint on the exhaust system?
- Hunting down Relays - 94 lumina 3.4L v6
- Sawing off nuisance battery bracket
- Fixing Window Trim - black goop
- Replacing Transmission Fluid lines to Rad. How?
- Removing the Stupid and Dangerous Rear Spoiler
- Tire Rim Corrosion - partial solution
- 1990 lumina 3.1 quits running
- 1994 lumina, intake manifold gasket
- 96 Lumina Throttle Hesitation
- How can I get error readouts on my 1994 Lumina 3.4L (PCM = Monte Carlo 95)
- Crazy turn signals
- Rattle In Drive
- Replacing engine coolant,1999 Lumina
- Why would someone steal a vehicle owner's manual?
- 96 lumina o2 sensor
- How do you tell how much life is left on your car?
- Fuel line question...
- 1997 chevy lumina catalytic converter replacement
- 97 Lumina runs bad after moisture
- 97 Lumina stalls at stops
- 95 Lumina bucks at 50mph after driv 10 min
- Chunks of metal in Trans. pan
- 94 Euro 3.1 misses
- Just pulled engine
- 1993 Lumina won't shift down into first gear.
- 98 Lumina... buzzing noise?
- 97 3.1 to 3.8
- Need Ideas On what to do with my z34
- help brakes wont work
- Back Bumper: needs replacement - how do I remove it?
- 91 Lumina Z34 won't Start.
- Lumina z34 Coolant boiling/bubbling
- 1997 chevy lumina DTC: P0420
- Saving the lower door panels for $3
- Keyless entry wire question
- 94 lumina 3.4L "Engine needs Servicing" Light OBD-I
- 97 Lumina thinking about pulling tranny...need advice
- Euro Instrument Cluster for Lumina
- 10% Gas saving with an undertray...anyone try this?
- Shift solenoid error causing misfire
- 1997 lumina 3.1 trys to start and stalls.
