View Full Version : Lumina
- Intake Manifold Gasket
- 92 lumina 3.1 running BAD HELP
- 98 lumina
- Weird noise from front end
- o2 sensor check engine light
- lumina steering
- Need Codes for 97
- overheated but fans didn't turn on
- batterty issue
- Vacuum Modulator line Boot?
- Lumina APV 95 engine won't start
- 90 3.1 coolant bleed
- 99 lumina oil capacities
- tranny slipping?
- 1991 lumina auto fuel shut off switch?????
- 96 Lumina with misfire problems
- 1997 Lumina LS (3.1L) Jet Chip
- 1997 Lumina 3.1 won't start
- Monroe or Gabriel
- 1993 APV 3.8L TCC Location/Problem
- 1996 Lumina APV keeps blowing fuse
- '91 Z34 question.
- restoration in WI
- 94 Lumina Z34 Master brake Cylinder Replacement
- hesitating and stalling
- Lumina turn signals switch inop?? Here's the fix
- 1997 Limina Won't Start
- Parting Out 97 Lumina
- 92 Lumina Fast idle problem, starting problem
- lumina 93 a/c
- Help me with my 1990 Lumina Euro
- How do I test the oil light on 92 lumina 3.1
- WHERE IS FUSE BOX - 1996 lumina
- Where Is Fuse Box - Brake Lights Broke
- tornado
- 91 front rotor help
- Exhaust - Cat-back pipe upgrade
- Junkyard motor
- no spark
- Im going to buy a '91 Z-34, what are the common problems ?
- Hesitation On Aceleration
- Help or something
- 92 3.1 Sedan possible oil pressure problem
- 92 Lumina 3.1 help
- Please Help Me With My Lumina
- I need help with my 2000 Lumina HELP!!!
- 91 Lumina - how to check codes?
- 96 Lumina A/c Bypass
- carbon in intake
- A/c
- A/c
- spark plugs and wires
- stutters, stalls - 1993
- 1990 3.1L Lumina - My Problems
- Confused about AUX button
- temp light comes on sometimes
- Cruise Control
- 95 lumina struts
- 95 Z34
- lumina 1995 camshaftsensor and p1670 code
- dummy question: Cruise switch
- Can't access trunk.
- power issues
- 1991 Euro 3.1 Torque Strut Question
- 90 Lumina needs to "rest" between starts!
- Power Window Issue
- chevy lumina van
- How do you re-program the keyless entry
- P0401 '97 Lumina
- '97 Lumina Vacuum Leak (Diagram Req.)
- do a valve job or not?
- felpro head gaskts writing up or down?
- police center caps
- economy
- balancer removal advice
- Location of the ECM?
- electric mystery
- 90 dashlight problem revisited
- I need some help
- very high idle
- 97 Lumina dies, won't start (for a while).
- rear dics brakes
- 90 lumina wont keep a charge
- 95-3.1 HVAC vacuum problem
- No brake lights
- no tail lights
- 1997 Lumina 3.1 has fast idle after starting
- need info on 3.1 police edition engines on '97 Lumina
- ABS brakes
- A/C electrical?
- Please Help
- siphong gas from 91 Lumina to replace fuel pump
- 95-3.1- EGR Valve
- '93 Lumina -- *sudden* jerking @ ~ 45mph, *please* help
- vacuum diagram
- Curious
- lumina apv has no spark
- K&N intake kit for 90-00 Lumina's (Sweet)!
- Rpm
- 90 Lumina tachometer wire?
- Check engine light and weird excelleration?
- 90 Lumina Euro Turn Signal.
- RPM's rising too fast at little speed
- Does anyone know how to fix this?
- 93 lumina euro running hot.
- help with replacing 1990 lumina battery
- noisy a/c when off - clutch?
- Please help me with my electrical problem
- '92 3.8 APV Oil Pump???
- my car hates me
- Ignition
- 97 3.1 surges on take-off and has massive torque steer
- Lumina sedan turn signal working intermittently
- RE-Advice
- Advice Again
- "Sawtooth" rev pattern when I gun it.
- Thnx to cadgear and all
- Now What?
- advice
- flickering lights
- Coolant leak/dead battery...connection?
- newbie trunk question
- 99, 3.1L, Won't shift to 2nd gear when cold
- 90 Lumina Auxiliary cooling fan problem
- 95 Lumina LS 3.1 Speedometer Issue
- 99 3.1 lumina slow out of first
- WOW! (and I need some help)
- several problems w/ 3.1
- Will my Chevy make it?
- check this out!
- '93 lumina overheating
- Loud groan in reverse?
- 99 lumina 3.1
- Ticking Noise
- 97 probly lifters
- Drivers Side Mirror
- O2 sensor after cat
- Torx Screws
- lumina trans for dummy
- Outer Tie Rod
- '93 regular Lumina CAI, a real improvement????
- 92 Lumina Stalling
- Remote Start
- 93 Lumina with 3.1L 1st Gen wont start
- '93 won't start, then starts - continual problem
- how do i set the clock?
- check engine light help
- 24x crank sensor
- tranny question
- Performance?
- stuck accelerator pedal
- 92' won't downshift
- cars cars and more cars
- newbie has dome light trouble
- 91 3.1 stalls
- Pictures of amplifier install, MP3 and speakers
- P/W switch illumination
- factory fog lamps and CAI for a '93 chevy lumina
- Aftermarket Stereo wiring
- a/c problem
- shakin' when brakin'
- lumina gague cluster
- Another brake issue thread
- 93 Lumina Power Window Problem
- '93 chevy lumina 3.1 tranny slip quick fix?
- 1992 Fuel Pump Wiring Diagram?
- 1995-3.1 & 2002-3.1 Engine Swappable ??
- gm wheels
- Help w/oil in water
- noise unknown source
- Trans slipping in 1st; can VSS be bad if odometer is working?
- car shakes when braked
- 1998 Monte carlo a/c problems
- exhaust questions
- 1994 lumina apv shorted
- 2001 Chevy Lumina Tranny
- 1997 Lumina tranny gone
- How to remove 98 lumina dash?
- Help identify the part from the pictures
- Should I clean it with a spray?
- Dash Light Ground.. where? 95 3.1 Lumina
- 3.1 liter engine for sale
- 93 lumina rough running problem solved
- DOHC injectors
- 98 Lumina how to remove back seat?
- 91 Euro Alternator issues
- 96 Turns on but when gas pedal is press it wont accelrate
- Signal Light Possesssed !
- 96 Lumina sucking air through oil fill
- 2001 Lumina keyless entry programming
- 93 Lumina won't downshift when hot
- 98 has poor braking ? =
- squeak.
- 99 replacement engine
- Oxygen Sensor
- New Stereo Receivers not working
- Transmission won't engage from standstill
- Tranny fluid / filter chage
- iridium Plugs
- 2001 Chevy Lumina Sedan Hesitation
- muffler fell off!
- Must press accel hard to start off 97 Lumina 3.1
- 97 Lumina Drive Belt Tensioner
- Oil light reset...
- Tranny neutrals on hard left
- 99 Lumina, 3.8L #6 missfire
- Transmission Change
- Oil Pressure Drop Van Cuts Off
- 1993 euro just stopped on the highway
- Transmission fluid change/TCC on 95-3.1
- transmission
- 92 Lumina 3.1 having trouble running
- '91 Z34
- Problem with 95-3.1 "transmission" solved!
- 93 3.1 lumina intermittent rough running
- Static from Radio
- clear a computer code
- Where is crankshaft position sensor?
- WTB:lumina 3.4
- looking for Rear door window molding
- How to check codes
- Power Lock Problem
- Battery Removal 2000 Lumina
- 92 Euro door won't open
- lumina 97 miss fire
- Information on a 1991 Lumian Euro 3.1
- Airbag Light. Help Plz.
- No cold air
- Transmission, lost second gear
- 96 Lumina Instrument cluster
- 1990 APV steam engine?
- '95 Lumina APV, need timing BTDC number
- 95-3.1 Drivers side door lock switch not working
- 90 Lumina 2.5L Won't Friggin Run revisited
- 98 Lumina issues
- shaking loss of power '97 Lumina
- Water Pump on 92 Euro
- 98 Lumina Sound Woes
- 1993 APV Lumina 3.8 173,000 miles
- heater return
- 1994 lumina
- 1990 Chevy Lumina V-6 question...
- 1990 Chevy Lumina Starts fine but dies right away
- replace heater core
- 96 Lumina engine blown after transmission flush
- Police issue Recaro seats
- 1990 Chevy Lumin Engine/Tranny Problem?
- A word of Advice for my car brethren...(about brakes)
- 93 Lumina Euro won't start
- 3rd time this week my 97 broke...help!
