View Full Version : Cirrus
Pages : [1] 2
  1. 99 cirrus engine issues
  2. 98 Cirrrus - Power Door Locks Not Working
  3. Cirrus Transmission Problems
  4. Rear brake line won't bleed
  5. Lower Control Arm Removal
  6. Steering Grinding noise, Cirrus
  7. 95 V6 - transmission cooler lines
  8. 96 cirrus LXI sometimes hard start
  9. 95 V6 - PCM/ECU w or wo firm feel suspension
  10. Rusted rocker panels
  11. 98 Chrysler Cirrus ABS Problems
  12. 97 2.5 liter power steering bracket removal
  13. 98 Cirrrus trans shifting wierd and no speedometer/odometer
  14. Car occasionally smoking blue
  15. 95 chrysler cirrus stalling everytime it reaches 3000 rpms
  16. Cirrus 98 acting up every so often
  17. 96 cirrus 2.5 liter 190000km
  18. rear passanger brake running hot
  19. Right tool???
  20. a/c
  21. Horn Stuck
  22. Car won,t start when raining
  23. 97 Cirrus - Bad Hub Bearing or CV Joint
  24. 97 Cirrus - Bad Hub Bearing or CV Joint
  25. 97 Cirrus v6 LXI Transmition metal Alloy problem
  26. 95 cirrus alarm problems
  27. 2000 Chrysler Cirrus Lx Heater Intermittent
  28. Overheating but the Thermostats Good
  29. No bus problem
  30. timing belt marks
  31. 97 chrysler stratus 2.5 v6 promblem.
  32. 97 cirrus loses power above 3500 rpm
  33. Oil leaking into antifreeze, engine shuts off, and bad idle
  34. 2000 cirrus Coolant gurgling
  35. wheel bearings?
  36. 1999 oil in spark plugs
  37. rear defroster button switch
  38. Horn fuse on 99 cirrus keeps blowing
  39. 1999 Cirrus 2.4L, No Start
  40. wheel bearing or tie rod????
  41. missfire 99 cirrus v6 2.5l
  42. stripped nut, please help
  43. 99 cirrus 2.4 miss fire #2 and #3
  44. Check engine light and starting (95 Cirrus)
  45. how to change tie rods?
  46. ticking/knocking
  47. 2000 Cirrus 2.4L, spark plug hole stripped!!
  48. Dealer declared car unrepairable
  49. 98 cirrus starting issues
  50. spark plugs
  51. 95 Cirrus Starts then shuts off.
  52. no belts!!
  53. 1994 chrysler cirrus HELP!!
  54. Battery Light Possessed
  55. Starter for a 2000 cirrus
  56. A STRANGE PROBLEM w 98 Cirrus (not even my mechanic can figure it out) HELP PLEASE!
  57. need help!
  58. need help!
  59. stalling when shifting into reverse or neutral
  60. Fuel filter replacement?
  61. 96 cirrus 6cil
  62. 1995 strut spring removal
  63. Looking for Chrysler stratus LX export parts
  64. a/c noise
  65. 97 lx 4 cyl , stalls
  66. Battery location 95 cirrus
  67. OBD question
  68. '95 Cirrus acts like it's flooded since left side hit
  69. 1998 Cirris 2.5 coolant leak
  70. 96 cirrus BCM
  71. Power Locks Motor
  72. 1999 Cirrus car alarm
  73. O2 Sensor
  74. 96 chrysler cirrus break light on help!
  75. 95 cirrus hard start , rough / no idle
  76. '00 Cirrus Falling out of gear
  77. 2000 Cirrus Coolant Leak
  78. 2000 Cirrus - Dies when driving
  79. 1999 Cirrus No Start Cold
  80. 95 cirrus firing diagram
  81. 95 Cirrus Help
  82. 1995 Cirrus, Catalytic converter gets red hot
  83. alarm system stuck on!!
  84. 97 , pcm asd fuse no start
  85. Could it be the Battery or worse?
  86. Programming a new key fob
  87. Reading the Check engine light
  88. Heat problem
  89. '95 Cirrus here we go again!
  90. 97 chrysler cirrus code 11
  91. Car shuts off every time it rains and then won't start again!
  92. Oil light
  93. 98 Cirrus Overheating
  94. 95 Cirrus fixed at last!
  95. 2000 Cirrus, Steam comming from behind the block
  96. Seeking Chrysler/Mitsu V6 Guru, Los Angeles area?
  97. Can I change the transmission myself?
  98. 99 Cirrus guages work but no lights
  99. water leak
  100. '00 Cirrus - is there a lights-on chime?
  101. 95 cirrus engine kill problem?
  102. 96 cirrus lxi computer location
  103. NEED HELP LOCATING BATTERY cirrus 98
  104. 97 Cirrus
  105. 1998 Cirrus Clock Question
  106. 96 Cirrus No spark
  107. need help with my car plz SUPER CHAGERED CIRRUS!!!????
  108. '95 Cirrus gas filling problems
  109. Why Won't My 97 Cirrus Start?
  110. 2000 cirrus trys to start by it self
  111. '00 [Stereo] -Now lows in everything but radio
  112. '96 Cirrus rocker panel replacement...
  113. 98 Cirrus Cruise Control... This is intresting!!
  114. 95 cirrus quitting
  115. oil leak
  116. 95 cirrus runs rough when humid or raining
  117. Valve cover gaskets on 95 cirrus 6cyl
  118. Chrysler making noises...freaking out.
  119. g/f's car, need help
  120. 95 CIRRUS NEED some help
  121. Transmission fluid leak
  122. Car STALLS whenever it wants, runs fine when cold
  123. Electricial weirdness please HELP
  124. what could have caused my 96 cirrus from not starting
  125. Lifter Noise In My Wife's Cirrus
  126. 1996 cirrus engine noise.
  127. 2000 cirrus code p0720
  128. help, coolant leak!
  129. 99 Cirrus should i buy?
  130. 96 cirrus won't start
  131. 97 stering squeak
  132. 1995 Chrysler Cirrus Instrument Panel
  133. 96 cirrus
  134. 99 Cirrus
  135. Loud grinding sound on 95 Cirrus
  136. keyless entry?
  137. 2000 Cirrus Cruise Control Problem
  138. Chrysler ABS Help me PLEase
  139. problem with right passenger brakes
  140. I'm In Chrysler Hell!!!
  141. 95 cirrus lxi oil question
  142. 95 Cirrus No Spark
  143. 95 Cirrus burns oil only during idle and city driving
  144. 2000 Chrysler Cirrus Alternator Adjustment bolt
  145. Chrysler neon remote
  146. Please HELP with Chrysler Cirrus 95 lxi
  147. car shaking after replaced alternator & dispensor
  148. Purchase '99 LXi?
  149. This Site Sucks!!!!!!!!!!!!!!!!!!!!
  150. Check engine light will not come on
  151. Cirrus turns over but will not start
  152. Stalling and idling rough
  153. 95 Cirrus Power Windows
  154. Air Conditioner
  155. Help!! My A/C isnt blowing cold
  156. Koni front and rear struts for sell on ebay, Dodge Stratus and Chrysler Cirrus
  157. Tune Up On A 95 Cirrus
  158. lower pulley nut? clockwise or counterclockwise threads?
  159. Air in right brake Caliper
  160. how to remove timing belt on 99'?? Confused and in a rush
  161. water pump
  162. 1996 Cirrus the ABS Light wont go off !!!
  163. I need a wiring diagram for a 96 cirrus
  164. 96 cirrus door chime help please
  165. Sold my 98 Cirrus
  166. 99 Cirrus Wheel Bearing
  167. diagnostic codes for 99 cirrus
  168. How to Check engine failure codes on 1996 Cirrus
  169. On my Cirrus ´96 the batterry light is on
  170. Clunking sound
  171. reprogramming keyless remote for Cirrus
  172. tcm -95 cirrus
  173. automotive repair manual
  174. why cirrus why?
  175. why cirrus why?
  176. 2000 Maxima
  177. 1995 cirrus key stuck
  178. 99 Cirrus Transmission problem?
  179. 2000 Cirrus 2.5L V6 24V Coolant Issue
  180. tranny sensor???
  181. 99 Cirrus won't start
  182. 96 ing fuse blows
  183. battery light lit up on instrument panel.
  184. 95 Cirrus Help in reading codes
  185. FUSE: 95 Chrysler Cirrus 2.5L 6V
  186. Possible Cracked Flex Plate on '97
  187. car shaking
  188. Oil Check light flickers on/off when i brake/in idle
  189. 96 Cirrus misfire. help please
  190. 96 Cirrus shutting down(Help)
  191. Fuel filter. helllllp
  192. 99 Cirrus Check Engine Light Stays one..
  193. buying a 95 Cirrus
  194. 95 cirrus 2.5 shuts down at any time
  195. 1995 Chrysler Cirrus tranny shifting into 2nd
  196. turns over but no start
  197. Rear brakes diagram
  198. No Heat
  199. Another frustrated Cirrus driver
  200. 95 cirrus fuel filter
  201. 1995 Chystler Cirrus
  202. Stereo...AHHH
  203. 1996 Chrysler Cirrus Oil Light Problem
  204. 1995 Cirrus Chime and Power Locks Malfunctioning
  205. Wierd Brake problem
  206. Removing crankshaft bolt problems
  207. possessed cirrus
  208. 98 Cirrus LXi Headlamp washers? Where can I buy them?
  209. Steering belt keeps snapping
  210. 95 Cirrus.
  211. 1995 crysler cirrus nightmare
  212. FSM, spare parts dealers?
  213. 99 cirrus dying while driving
  214. 99 Cirrus Tie Rod End
  215. 95 Cirrus alarm problem won't stay running
  216. 97 cirrus alarm problems
  217. 95 Cirrus Amp problems
  218. A/C switch
  219. 2000 cirrus - remote keyless entry
  220. Gauges don't work
  221. '96 Cirrus hard starting
  222. Power windows and Blower moter will not work
  223. Factory amp in 95 cirrus
  224. maxima man myself, but want to work on my mom's cirrus
  225. Chrysler Stratus Export Edition (i.e. Cirrus) Remote Keyless Entry RKE
  226. ABS problem
  227. Engine miss
  228. 95 Cirrus, lots of problems
  229. Battery wont stay charged
  230. Broken Motor Mount
  231. electrical problem help!!!!
  232. RPM and GAS consumption
  233. Air Conditioner blowing cool air intermittently
  234. A604 in limp home mode (41 L/R sol. circuit)
  235. 1996 cirrus cd player
  236. 95 Cirrus Alarm Help
  237. No air out of eyeball level outlets
  238. Cirrus Lx 95 Die For No Reason
  239. 96 Cirrus Door Chime
  240. Now my 95 Cirrus won't start
  241. burning up rear bearings and brakes on 95
  242. Fuel pump help!!!
  243. '95 Cirrus Shuts Down
  244. BCM (Body Control Unit)
  245. air conditioning switch problem!!!
  246. Mods and upgrade help!!!
  247. 1997 Cirrus LXi
  248. 1998 cirrus audio upgrades...
  249. 96 cirrus wont start or jump
  250. custom interior help
