View Full Version : Maintenance
- Please help so frustrated rite now
- i need sum help forum!
- 95 Infinity G20 Dead Cylinder
- Ignition switches
- P11 primera steering pump pulley wobble help
- Whistling noise
- Starting issue when engine is warm
- Back suspension/shocks
- Gears not workin
- p10 92 primera gt auto trans
- beeping when indicating left
- Looking to replace fan regulator on a '96 G20T
- 92 G20. Gross Poluter!!!! Heeeeeeeeelp!!!!!!!!!
- Looking for: vacuum pump for P12 2.2D 2002
- fuel pump
- Air Conditioning
- headlight adjustment
- does the Primera have a fuel filter?
- Headlight won't go out.
- Car won't start..told it might be Timing chain
- Power Window Problems
- G20 squeaks at low speed
- Help with Brake Lights
- sensor
- Abs Sign On A 95 Infiniti G20. Help!
- Check Engine Light
- Is it my battery???
- Nissan primera diesel lacks responsiveness
- Electric cirquit principal scheme for Nissan Primera 1996
- emissions
- Nissan Primera CV Joint Removal
- weird thing with the ventilation
- reprogramming fob - primera 95
- Can someone help me ID this part?
- It Starts, then Dies, then starts again...(Engine)
- Primera GT Clutch help
- Primera Sr20De Wiring Diagram
- Rough idle in Reverse when A/C is on
- Brake caliper seems to hang
- Primera/P10 Remote for Central Locking not working? Please Help
- Fuel Quantity Adjuster Position Sensor P11 TD
- Car wont start, and then will start - Alternator?
- I HATE CARS!!!!(not starting)
- my g20 is running hot
- EGR system trouble
- tranny problems
- Stupid emissions
- handbrake issue
- '94 G20 remote prob.
- '94 G20 AC/Heater Fan
- Question about codes!
- engine light
- Room Light
- Power Steering dead
- No heat!!!
- replacing power steering belt hp10
- Heater only works on setting mumber 4
- Changing belt - how often?
- Stuttering at Idle
- P11 headlight level motor change?
- Line Pressure Solenoid
- crankshaft position sensor location
- Check engine light
- 1993 G20 runs rough when idle
- Primera SVE P12 2002 Immobiliser help ???
- Power Locks
- New spare parts for P12
- help running on 3 cyl
- 92G20-acts like it's hitting on 2 or 3 cylinders only!
- Taking A/C Condensor
- Do I need to bleed brakes?
- Questions concerning the replacement of front/rear rotors
- trunk lifts/struts
- Primera P11 1.6 power loss
- 94 G20 auto p0705 code
- Weird Fuel Filter Replacement Question?
- "tail lamp" fuse blowing
- 1994 Dodge Dakota Transmission problem
- Lots of problems
- trany doesn't want to upshift
- code p1126 on 2000 P11
- High rev on shift into top gear
- Changing Motor Mounts
- window regulator question
- Infintit G20 Alternator
- 99 D abs noise
- ABS coming on at standstill. Please help.
- Getting this dang Alternator out.
- headlights gone strange!
- gearbox problems
- Odometer On The Fritz 96 G20
- Engine Rattle when driving, idle, etc.
- How hot is your stock G20 running.
- Clutch Adjustment
- Car won't start!!!!
- Does anyone know ?
- removing the power steering belt
- 93 G20 cruise problem
- Mixed Up wire's
- fuse box layout
- Starter problem. Where is it?
- Question..
- blowing 10amp ac fuse
- Tranny control unit fail-safe mode??
- Jeep keeps leaking coolant Any Help pleaz
- Blown head gasket
- HELP!!! How to remove the window motor???!!?!?!
- removing door panel
- abs pump/motor
- shifter clicking after brake pad change
- My heat doesn't work, A/C blows lukewarm air
- 95 G20 - can't find ECU -
- Removing factory 99 civic ex ehhaust
- revs high but takes time to get going???
- No electric except engine/starter/headlights
- starting problem
- little help here?
- rear o2 sensor
- Anti-Lock Brake Fuse Location
- Fog light problem
- help! retire it?engine mount,emissions,tran,etc
- Start problem
- Problem- must pump brakes
- Problem with Air Conditioner
- code 43 on a gmc jimmy
- low rpms/dies at idle when warm
- progressive brake light failure
- Location of Starter...
- Primera Central Locking/Rear Demister
- messed with the ignition key wires, now car wont start!!
- Water Pump replacement
- shaked engine !
- air bag dash lite
- Removal of vacuum pressure regulator valve
- "Lighter" outlet too small for adaptors
- Engine Problems
- Squealing in rear of car
- gas Padel too sensitive
- idle / stalling problem
- Shaking Steering Wheel
- Another one for the electrical geniuses!
- warped rotors on 2000 Maxima
- Questions about changing spark plugs
- My fan switch only works on setting 4 but not on 1,2 and 3. What's wrong with it?
- Strange Problem with the Speedometer.
- New motor... Belt problems
- 1993 G20 advice
- The good..The bad..&...The ugly
- fan problems
- How do I replace a wheel hub?
- O2 sensor and reset check engine light
- does anyone know where to buy zip-up CV boots (or good split boots)
- Sun roof not moving - But motor runs
- Rear break prob ... ?
- Clutch pedal question
- Replacing valve cover gasket?
- P10: Car stays "on" even when key is out
- Rear air bleeder on 94 G20t
- Driver's side window regulator shot and more.......
- Visual HOW TO:fix your blower motor resistor
- Window Painzz
- abs light on
- My G20 has turned into a buzz box
- HELP..!? turn signal fuse blowing...
- One for the Electrical Whizzes...
- cold stall/erratic idle
- power problems
- Stabilizer link!!!!!!!!!
- the noise getting louder from engine
- Best place to get valve cover gaskets?
- Transverse link bushing is leaking
- Strange turn light electrical problem
- replacing alternator and water pump....is it TOO hard??
- Replacing Oxygen Sensor
- disabling ABS
- dirty filter!!!!!
- transmiss'n
- Fuel Consumption .....
- Oil Level?
- Weird Beeping Noise
- Tranny
- Juddering P10 1.6lx
- clutch quibble
- hard shift into 2nd on auto trans G20
- oil change vs. warranty
- cruse control & horn
- Drive belt tension
- Tranny Problemzz
- P11 Turbo Diesel-ECU/Electrics Problems
- cruse control
- When I turn the car battery on, there is a loud squeal noise
- What Did Your Head Gasket Job Cost?
- Scraping sound when coming to a stop...
- AllData web site
- A brief on ATF
- Rust on boot under spoiler mountings
- cam shafts
- Power steering fluid gone a funny colour
- Battery Light AND bRake Light
- Clutch/Throwout Bearing
- Transmission hard to shift to Park
- Ac Hot
- Strange code
- Removing right fender...Help!
- Oil level
- power window failure
- Rotor Replacement
- EGR valve replacement, HELP please :(
- weird ratteling noise???
- What is the best ATF ?
- Some kind of electric problem help !
- blower resistor
- Power Windows / Electric Windows
- Can't shift on cold start
- BOTH driver side windows D E S T R O Y E D ...HELP!
- faulty Service Engine Soon light?
- oil pump replacement help ... please.
- Whistle?
- Outer CV Boot Saga Continues
- Money Money Money, Here We Go Again!
- Car tuning
- Wheel Bearing Nut/Can't get it off
- Replace CV Boots or Half Shafts?
- Squeaks?
- clutch saga continues.......
- Engine block drain plug??? Help!
- Sunroof rust
- HELP!! replacing fog light wiring harness
- clutch replacement
- Window guides on a P11
- Are all of the motor mounts fluid filled?
- Updated Transmission Problem Solved
- ATF oil in manual transmission?
- changed thermostat but still overheating
- Strange sound from rear suspention, what is it?
- thermostat housing removal
- any ideas about ...
- What went wrong?
- Effects of poorly grounded MAF
- Check Engine lite
- ECU ODBII Diagnostics
- Transmission
- Any more ideas?
- Tachometer
- Dynamat Any Good ?
- Sudden aut0 Tranny failure..94 G20..questions
- security alarm problem
- Blower Switch went bad ---- ideas?
