| Latest | 0 Rplys |
03-07-2004, 11:18 PM | #1 | |
1995 lumina apv, wiper problem
I have a problem occasionly with the wipers just stopping, then after a while they will restart and then be okay, any ideas.
03-08-2004, 07:47 PM | #2 | |
Re: 1995 lumina apv, wiper problem
I have the same problem on a 94 APV. However, since I had to take apart the linkage to get at the blower motor, the prob hasn't occured. I think it's mechanical. Even tho' they probably quit while you're on the highway, try pulling over and wiggling them up and down. I'll do that, too, if mine stop.
Jeff |
04-27-2004, 06:56 PM | #3 | |
Hello, Yes I have had that problem. I first thought it was a grounding problem. So I grounded the wiper motor. Seemed to go away for about 2 weeks and then back again. I then bought a wiper pulse board from ebay and problem went away. The pulse board is on the motor and comes out fairly easy. Hope this helps!
01-11-2005, 08:48 AM | #4 | ||
Is this the pulse motor board you bought? http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WD1V I bought one, hoping it would solve the problems I'm having with my wipers on my '95 Transport, but the mechanic I went to told me it will not fit my motor! I posted about this problem in the "Pontiac Transport" forum already. I'm not sure if I believe the mechanic, although he didn't have any motive to lie to me... he even suggested I look for a rebuilt motor somewhere else, because he didn't have any - but he said that the pulse board I bought would not fit my van. |
01-11-2005, 10:01 PM | #5 | |
I really think it's the linkage
Hi, I've had it happen twice since my last post. Both times I pulled up gently on the driver side wiper and both times they started working right away. That doesn't rule out a dead spot on the motor but that would be pretty coincidental wouldn't it? I'd tend to believe a design flaw in the levers comprising the linkage as a more likely culprit. Next I'll lube the crap out of it and see if it ever happens again. Ever's a long time though!
Jeff |
03-21-2005, 08:52 AM | #6 | |
Did anyone notice a "buzzing sound" when it stops?
That's what mine is doing. |
04-26-2005, 06:24 PM | #7 | |
The Lumina '95 (car - not APV) has a recall for BAD connector on wiper motor. Check it out, sounds EXACTLY the same problem.
I have this problem too in my '95 APV. I will take it to a dealer, perhaps they will fix it, hopefully, for free. |
04-29-2005, 09:38 PM | #8 | |
Had this problem with my 1995 apv. One day while traveling on the turnpike doig 75 and my wipers stopped during a downpour...I decided it was time to fix it. I went to autozone and bought a wiper motor. It's a little tight to work on, but after putting the motor in NO PROBLEMS. My neighbor used to be a GM technician and he told me this is an extremely common problem with GM vehicles.
The wiper motor comes with a lifetime warranty so if it does happen again...FREE. It's been 2 years so far with the new motor and the wipers work beautifully. Mike |
04-30-2005, 04:41 AM | #9 | |
Still, to me it seems like a bad contact at a connector than the bad motor.
04-30-2005, 09:25 PM | #10 | |
It's the whole motor assembly. There is a circuit board inside the housing that goes bad.
Mike |
05-07-2005, 09:45 PM | #11 | |
Ok, I fixed it. I took the motor off, disassembled it and right away I found cracked solder around connectors. I resoldered 5 of them, put motor back. Works 100%.
