Go Back   Automotive Forums .com Car Chat > Chevrolet > Beretta
Old 07-10-2011, 12:23 PM   #1
jklatik
89 Beretta 2.8 fuel injector ohms?
Hey all, it’s me again. after thinking i fixed the problem it still dies after getting to operating temp. So I decided to check the fuel injector ohms. Injectors 1, 3 and 6 are reading 12.4 ohms and 2,4 and 5 read 6.5, 7.3 and 8.9. Would this cause it to die after getting to operating temp. i took the reading warm and cold. When warm the only injector to maintain a 12.4 reading was #6 the rest were between 6.4 and 8 ohms. This is getting old! Also the wire harness seems to be hard and brittle, with one plug spliced, so that i will replace since the plenum is off. Thanks for the help.
jklatik is offline   Reply With Quote
Old 07-10-2011, 02:07 PM   #2
jdl
Re: 89 Beretta 2.8 fuel injector ohms?
How long since a tune-up? Any applicable trouble codes? Replace injectors. You can do amp test, injector ground at pcm, key on. Should not be more than .75amp.
jdl is offline   Reply With Quote
fuel injector cleaner RidingOnRailz Engineering/Technical 8 07-04-2011 07:46 PM
Trying to find the Fuel Injector CyborgGold Celebrity 7 06-11-2011 07:49 AM
help! fuel injector problem Suzannes Caravan | Voyager 9 11-07-2009 02:06 PM
1988 Beretta 2.8 wont start?? ndoerr Beretta 2 01-24-2007 05:23 PM
1997 2.2 litre fuel injectors 231turbo S-10 0 07-20-2004 09:00 PM
