| Latest | 0 Rplys |
11-06-2009, 07:06 PM | #1 | |
help! fuel injector problem
I had a strong gas odor in the car last week (03 Caravan Sport) and it felt like I was running out of gas. A mobile mechanic diagnosed it...said that the #5 fuel injector was bad. He was supposed to come back yesterday to fix it, but never showed. GRRRR....
Someone at work told me the car would run fine if we removed that injector. I have found directions to replace the injector...but no diagram of WHERE the injector is. Looks easy enough once we find that. Also...what are your thoughts on REMOVING it for the time being...will the car run? Is it dangerous? Thanks for any help, advice! I really need this car up and running asap. While it's down, I can't get to work and I really cannot afford a big mechanic bill OR to miss work! Cheers! |
11-06-2009, 10:09 PM | #2 | |
Re: help! fuel injector problem
it will not run fine, it will still run the same rough, only on five cylinders..its not a hard fix...i would like to know what tests he did to come to the conclusion that it was an injector...
11-06-2009, 10:17 PM | #3 | |
Hmmmm. I don't know; I wasn't there. He just phoned me and said his diagnostics said it was the #5 injector. He said it was an 'electical problem.'
A friend of mine said it sounded like the injector was stuck open. I lost a lot of gas and even had it coming out the tailpipe. |
11-06-2009, 10:35 PM | #4 | |
what size engine??? do you have a basic set of hand tools
11-06-2009, 10:39 PM | #5 | |
6 cyl, 3.8L, awd
11-06-2009, 10:46 PM | #6 | |
if i remember #5 cylinder is in the front...the injector is under the intake manifold...
11-06-2009, 11:22 PM | #7 | |
I found a diagram on autozone, and yes, that's what it looks like.
Should I just replace it, or can it temporarily be disconnected (just for a day or so)? Right now I'm scared to even run it. |
11-07-2009, 12:45 AM | #8 | |
AF -Advisor
I would park it and fix it asap. If the injector is stuck open disconnecting the connector isn't going to make it pop shut unless you can get it to shut by tapping on it. Fuel will still pour into the exhaust creating one hell of a potential of one helacious backfire.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds. **Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual. 07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan |
11-07-2009, 12:49 AM | #9 | |
Okay. Thank you.
11-07-2009, 01:06 PM | #10 | |
2000 Caravan 3.0 41te 120,000 KLM. Tires Michilin P205 75R 14 New tranny at 97,000 |
Tags |
bypass , caravan , dodge , fuel , injector |
