Nissan
Primera | G20
> Engine
View Full Version :
Engine
Pages :
1
2
3
4
5
where is the 1996 infiniti egr sensor
check engine light after gas tank is filled and ac issues
Nissan Primera 2.2 DCI 2005 lacking engine power
Check Engine Light
p10 det
Fuel filter
ingnition control module problem
4wd/awd conversion
need a photo of and sr20det
engine mounts question
how much power?
Can you turbo a standard 2 litre Engine?
what upgrades ?
ABS LIGHTand CODE - P0325======> whats the connection???
installin a Tach on a 1995 G20
Apexi SAFC
p10 gt performance problems
GA16DS to SR20DE
G20 vs GS-R
1995 g20 overheated
Fast EFI
sr20det engine swap (engine mounts)
engine code for 1993 g20?
help guys!!!!!!!!!
incorrect gear ration 2nd gear
help!!!!help!!!!
Int coil to ext coil distributor swap.
help still a misfire
Replacing the thermostat
Issue: Injector resistors in GTi-R swap!!!!
GTi-R swap. Help!
GTi-R head swap
Detonation
SR20VE question...
92 g20 infiniti??
removal of infiniti g20 starter
engine swap
Looping idle
98-2000 g20?
Engine block respray.....
topspeed or hotshots
Sound from engine freaking me out
stalls..
Car won't start.
SR20DW to SR20DET
Muffler seems to be going bad, does it hurt performance? It seems so, tell me dammit
Check engine light error code P0171
#1 Cylinder Location
A/C system
Engine boggs and hesitates when accelerating from stop
Time ing chain going bad?
Transmission (?) problem
poor acceleration
Idle switch? Bad Gas? or POS?
Conversion Auto to manual..
1984 nissan 300zx nospark
reduce fuel consumption p10
Lookin for a TURBO
high port vs. low port
Cvt
SR20VE Question
93 heads onto a 99 swap
where can i find a cheap manual?
Clutch fitting 4x4 Primera (G20) How?
Audi engine swap
Engine Gone by by
Timing hi/low when engine started after timing belt change.
2.0 GX TD Improvements
SR20DET Swap Misc
steering pump or water pump
How do you remove the fuel pressure valve?
Clutch Fitting Primera 2.0 Diesel...HELP
overdrive
Exhaust system
throttle cable
my car gone!!!!!!!!!!!!!!
1999 P11 Front exhaust section
How to advance ignition timing?
spark plug wires
throttle body
Skyline sr20 engine
JWT ECU Question
Help me
Listen to my Magnaflow exhaust sound!
Japanese sites?
Exhaust and transmission fluid leaks
Breather caps good or bad?
anyone know where...
P11 Dual Exhaust Project
What intake system to buy???
B&M Short Shifters
stillen intake for primera for $67.66
Need two GTI-R DET engines
sr20de vs. sr20det
help choosing parts!!!!!!!!!!!Please!!!!
Different Generations of SR20DE?
Issues with using JDM Gti-R ECU with g20 tranny
'96 G20 aftermarket parts
sr 20 de and sr 20 det
SR20 DET Installation web page
Info Needed
Obscure valve train question
More pics of my G20 turbo on my site
torque and gear box
you'll need these if you are building monster G20
Cams need replacing?
Can you say TURBO???
Oil Level?
engine mounts
What's the difference?
ecotek
Help Now Please
GTi-R in my G20. New link works this time
$1000 upgrade project
engine code
Starting Problems
Primera P11 Gear Ratios????
Pulsar vzr-n1
My replica FMAX manifold
engine knocking
P11 1.6Si
noob question
Ecotek
ECU interface
Radiator options to cure overheating?
Cheep turbo setup
Remus Exhaust for P11
P11 GT induction kits!
1993 g2 flex pipe
HELP! Transmission sometimes wont go to 3rd gear
JDM Sr20de ECU question...
squeeling noise
look at this chip on ebay? haha
Canadian Vs American P10
Need Help with my AAIS
Photos of my Pulsar Gti-R swap
2001 G20 ECU reset
Can anybody get the Unichip Mapping software???
I NEED a complete Engine! ASAP
Intake pipe?
Electric Supercharger
H E L P ! CAI calls for smaller battery?
Need pics of a US G20 fuel rail.
HKS Air/Fuel Regulator ?
Maybe time to get a bigger Turbo.
A/C Woodpecker
Exhaust Replaced for $740 US...am I getting Jacked?
Need oil pump replacement help
UK GT Dyno'd
Whats this Tachtom MDM 100???
Random Technologies Cat converter for P10
Nice exhaust ... WHERE ??
G20 Turbo
Please heeeeeelp with Primera 2.0 TD
Just when o thought i had the upper hand...... IVE BEEN OUTDONE BY A P10!!!
Maf Sensor!!!
muffler mounting
need help fast
Anyone ever heard of Prolong Engine Treatment????
Strange noises...
SR20DET Engine Specs Please!-
HS header?
162 hp/144 lb ft P11 SRi -15.8 1/4 mile.
HS Header/CAI
Where can I get new cams?
enigine light on!!!!
3" Remus exhaust??
K & N really drop-in?
SR20DET Intake
Finally got my HSH/Downpipe on!
transmissions
Which is the best motor oil ?
Cold/Startup Grinding.. Maybe waiting for oil to shoot?
How to reset ecu?
jdm primera motor will fit....?
I have to switch manifolds?
sr20det installation needed
Replace or repair my engine
fuel management on p11
My SR20DET updates..
INTERESTING: Wrong Oil = Poor Economy ?
Any Kiwis Removed Cat Conv??
Check Engine Light on
Resetting ECU
WHERE?!?! Boost Gauge pipe on SR20DE Turbo conversion?
Unhappy with custum Headders !
Aem Bpv Broke!
tHe PaSt Of My CaR FiNaLLy CaUgHt Up To Me...
need help with G20 starter removal
what now?
Engine Oil Weight for the summer?
awesome website
Throttle Tightening My P10... Help!
Clutch/Flywheel
Question about SR20DET
P10 cold air intake pics??
cai for 00 and up g20 (fitment)
Greddy Cat Back System 4 P10
To all you Gurus, Please Advise
air conditioning
HighPort/LowPort Intake manifold swap
Aaah... the motor mounts.....
Going Turbo !!!
O2 Sensor
intke
Red valve cover
The damn Stillen Hi-Flow air intake
Where do you guys get your performance parts?
Short shifter for p11 HELP!!
Greddy EVO vs. Blitz REALIZE TT
Possibilities of a high port / low port head swap?
MIL Code 1203...Overrun Clutch Solenoid
Battery Relocation
What to do with G20
hotshot headers
Does anyone here have a Hotshots Turbo?
How hard is it to change the lifter, I am suspecting a bad one
FRIG! Spun a rod bearing.
Chrome Valve Cover
Manual tranny transplanter, please help
G20 turbo gods help me
engine swap and wiring harness question
K57i Kit + Supersprint
How To: 99' Greddy Evo Install (long, pics)
will this fit our Gs?
Phantom Grip Limited slip differential
valve cover question
2000-2001 variable capacity P11 exhaust on a P10
EGR Block Off and Coolant Line Bypass
Who's running the best cat-back?
Advice for Sticking "lifter" (HLA)
EGR Blocking?
nismo
again, oil pressure gauge questions
Unorthodox Pullies
2.5 inch pipe with exhaust... Do or Don't?
Can you Identify this part?
Hotshot Performance Contact Info
$300 for a sensor?
b&m short shifter group buy
Knocking noice in engine
My engine
you guys think this exhuast sounds good?
Fast and the Furious Exhaust??
Taking apart my spare SR20....need some help...
Put in Stillen High Flow Intake today...Quick HELP
Performance Shops in Texas
Where'd 3rd gear go...
Techtom MDM-100??? Anyone have one?
