View Full Version : Engineering/Technical
- what do you think....liar?
- question about a turbo f22
- installing a Hornet Remote Starter
- 460 Police Interceptor Opinion and Other
- front crank oil seal compose of?
- Front crank oil seal removal.
- How to reprime deisel?????
- is it possible to put a spoon chip on a odbII?
- Why doesn't my remote start work properly?
- Need Help..Poked hole In Gas Tank..
- Installed short shifter...problems!
- frankeinstien lsvtec
- Spoon exaust...is it as good as everyone says
- 2001 celica gts V.S. 1999 integra gsr
- auto to manual wont start
- help with remote sensor
- resleeve vs. block guards
- R.o.n.
- Voltage surges
- b20 with type R head question
- mufflers??
- catalytic converters
- Engine Angle
- Need Radio code for 03 civic?????
- How do I remove/replace the passenger headlight for my 91 integra?
- How do I replace the headlight for my 91 Integra?
- What do I look for when buying a muscle car?
- What's going on with GM's 3800 ??
- where to buy built engines
- ????transmission??????
- Engines
- need early 70's 455
- possible motor swap in my civic suggestions?
- Exhaust system, strange things?
- hydraulic clutch in a civic w/JDM B16
- strut bars?
- How do I set Top Dead Center (TDC)?
- need to know if trans will work
- $1,000 to spend on parts, what to buy...
- tuning d16 pointless?
- Gsr question
- LS/v-tec help needed!!
- tranny swap
- stock 94 honda civic hatchback.
- I need more consistant voltage
- SOHC ZC Compression
- carb question
- Raw gas exiting through exhaust? What the hell!
- dash illumination lights
- Head Gasket
- CAFE Reform Is Coming - You Need to Participate
- F22 parts will fit F20a?
- Prelude Turbo
- Need help with head swap!!!
- B20 Honda CR-V
- how do you fix a 1991 honda accord's transmition?
- Transmission Slippage
- b18 injectors in a zc?
- A 1st gen b16a problem that will make you go nuts!!
- popping noise from power window?
- Is there a website????
- heater and defrost on 1988 silverado
- more hp, more mpg?
- b18 question
- crank sensor??
- Head swap on a F20A
- 91 accord heater problems
- HELP my '94 civic wont START. Its not the fuses or the starter.
- D15B7 Upgrades.....
- B16a speed sensor for SiR cluster?
- "Tak Tak Tak Tak" sound on morning start
- SOHC ZC/VTEC and NOS
- rim polishing
- Can someone help me out please?
- Another Newbie! Hello All!
- B18C5, really worth it?
- HELP! Got new clutch installed and SMELLS! also a clutch technique ive never heard!
- 350 Chevy Engine Problem
- Repair your own STARTER
- trans axle? stupid ques.
- Rebuild your own alternator
- Valves Making Noise
- Engine swap gone bad HELP!!!!!!!!!!!!
- field sfc-d (not vtec)
- B20 complete
- Wrong fluid in wrong place... help
- suspension mods for b18c5?
- please help with speed sensor on b16 swap
- For Sale AEM Tru Power Pulleys 94+ GSR
- You Can help save the Camaro!!!
- how do i install a flowmaster
- brake replacement
- 2004 GTO - What do you think?
- What would be more Expensive...???
- D15b/vtec
- all i need: 1/4" snow & an e-brake
- Remus Exhausts
- Another Ebay Item...
- new guy, new car!
- 77 Impala 2 Door Value
- H22a LSD Transmission
- aluminum blocks
- Paris-Dakar: The Ultimate Rally
- Lies About SUVs
- '88 Civic runs great for 30-50 minutes, then hesitates and stalls...
- What's wrong w/ my car?
- help slamin D15b in 89 hatch
- High Compression SOHC CRX
- LS/Vtec
- converting ECU
- SRR cam gears any good ?
- Obd2 to Obd1 Converters
- D15B Timing
- vw solid rear suspension????
- exhaust question
- wierd racing question please answer
- autocross
- import tech coilovers?
- what does "seasoned block" mean?
- alarm keeps messing up!!please help!car cant start!
- removing the rev limit
- AEM intakes vs.. Intercooler...
- 92 1.6 GSR motor?
- 89 F250 front axle & hub lockouts
- Help with Exhaust choice
- Tachometer installation help
- 1970 Cyclone GT
- how to tell year of tranny for dohc zc?
- does this sound good....
- b18a1 with b16a head or b18c5
- b18 motor for sale
- B18c5
- Where can I get some weatherstripping???
- Need some help w VAFC-II
- Hatch versus Coupe Cat Back Exhausts
- Just a quiz question that not many people know...
- b18a1 vs b18b1
- B18A1 Components
- Question
- I like all kinds if raceing
- 5speed vs 6speed
- mugen chip
- BOMZ mufflers and Spoilers
- The Crossover Sport Van
- B20 progress
- How hard to install new brake lines?
- windshield wipers going crazy
- eBay Header/Intake/Exhaust
- what does "sst" stand for?
- 93 Prelude H22 into a 92 Civic LX
- Rocket boosters
- Help Need A Part!!
- Front Wheel Speed Sensors
- Brake Booster
- bosch KE Jetronic pressure actuator
- Small Question
- Question on 93 Accord...Adding Hp
- Best brake rotor design?
- The age old question
- 92 Integra GS Engine Swap
- Blew up b16 w/50 shot...getting LS long block
- Questions for 90 crx Si
- 92-95 civic jdm front fenders
- Will ECU work
- going the other way 93 prelude
- Regal/Malibu/Cutlass parts for sale
- Rotory engine efficiency
- Properly using nitrous
- B18C1 to what???? Have a 97 GSr, ready to upgrade to ???
- Oil & Gas, whats the real truth
- APC Mufflers
- HELP !! Hard start with 89 Camry - Only when COLD !!
- Heres something new
- How tell a JDM H22 or USDM H22
- 93 accord cruise control problem with H22 swap
- Heads
- toyota 3s-gte into a 96 honda civic ex
- intake manifold
- I'm in the midst
- 6th Gen Cat?
- For those that like to argue
- 2001 Honda Civic Idle Adjust?
- Why America is the best
- 65' Plymouth 273 FS
- Clutch Problem
- Engine seized
- b20b or b18b
- B20 in a few minutes! a few ?'s tho.
- Noisy D16Y7
- code ques.? 23?
- Nobody will
- 89 prelude h22 swap?
- Rear disk brakes 88 legend
- Jdm Motors With 30 Day Warranty.
- V10's?
- Speed Sensor Removal on 1999 Mercury Sable
- Survivor, what do I do with it???
- I will always be an American
- short shifters
- Car Is Dead Please help me revive it someone please!
- emissions dilemma
- What U guys think about this?
- OEM style
- There really is no point to this.
- prelude swapped
- Bore/Stroke question
- Fiberglass Door Panels
- 1963 Buick wildcat parts
- air suspension
- Violence in Cheboygan
- Hunting Controversy Over Proposed Nevada Off-Road Regulations
- The Minivan Comeback
- K24 Block K20 Head
- Turbocharged b16 engine
- B16A2 in crx hf
- USDM B16A2(99-00)SI in 91 CRX Hf Question
- B16a Shirts
- Zdyne Software
- open headers
- Dry Sump Oil System
- Which spark plugs for mini-me?
- Where can I find a b16 engine for my '93 civic hatchback?
- Motor swap questions...
- b16a --> b18c1
- Project Car: 1986 Toyota MR2
- gas mileage
- Annoyed
- eek!!! help me
- Honda swap with mitsubishi..?
- How can i make my CRX faster and faster..
- New to site Need to know about B18C1
- The Ideal Engine
- Engine sizes
- What should Chevy's next step with the Camaro be.
- want to swap d16 to b16a2
- motor swap
- extra hose in throttle body
- how much work for a b-series into a 7th gen civic?
- h22a4 OBD2 into 88 Prelude OBD0
- Wiring Diagrams for JDM H22 OBD1 Distributor???
- H22 Need Help With Jdm Distributor
- An explanation of "JDM" for newcomers
- front clip swap
- Broken Clutch
