View Full Version : 4Runner/GX470
Pages :
1 2 3 4 [ 5]
6 7 8 9 10 11
- Head Gasket problem
- 2.4Lt 22-REC 4cyl throttle cable lenght
- Gearing after lifting
- alarm recommendation?
- type of coolant
- 2000 4Runner-cannot manually unlock door
- fill-up problem
- $8 Subscription to Car & Driver, Motor Trend, and Road & Track
- 00' Toyota 4runner fuel filter?
- where is the lock cylinder?
- 1990 Toyota 4Runner Styling Set-Fender Flares
- 2001 auto 4x4 Transmission left me stranded...
- 93 4 runner brakes
- Gas mileage
- EGR Gas Temperature Sensor 1992 4runner
- Can not get steering wheel unlocked....
- any advice??
- 91 4runner -"electronic control unit " or " electronic ignition"?
- 91 4runner
- anyone with advice on my 4runner
- 91 4runner running rough
- Help!!
- A couple of problems and questions
- Seat belt minder alarm removal
- power locks
- 00' Engine light comes on... "System too lean?"
- Looking at buying brand new 4runner, need some opinions please!!
- Changing differential fluid and gas mileage
- Oil Pan Removal
- '86 4runner power window/lock conversion
- Help, 1991 4-runner, loss of power, strange
- 97 4runner auto trans problems
- air conditioning 94 4runner
- Lifting
- Ignition fixes?
- 2000 4runner 5 speed clutch slipping?
- need opinions... rookie 4Runner owner
- Lost Compression on all cylinders, right side
- Fuse blowing for radio,clock,antenna
- 1989 V6 std clutch replacement
- Speedometer Working Sporadically on 92 4Runner
- head gasket / block problem with '91 4Runner 22RE
- cat. converter???
- 1997 radiator flush
- 1999 4Runner Timing belt replacement...
- CA Emission codeP0420
- Rodent infestation...HELP!!!
- 1994 toyota 4 runner owners plz help!!
- '99 4Runner Sputtering and stalling, thoughts?
- speedo weirdness rant
- Help Me Find Parts Please!!!!!!
- delayed start problem
- Fuel filter location on '00 4Runner
- 1999 4Runner shaking during braking/Clunking when stopping
- Headlight Removal 2000 4Runner LTD
- Cruise control not working HELP!
- Gas Mileage for 3rd Generation 4Runner V6
- 00 4-runner
- Rear door interior assembly
- 1992 4runner how to clean the egr valve
- 1992 4runner egr problem code 71
- No dashes lights. HELP!
- car fax
- 1997 v6 4wd misfire cylinder 3
- 1997 v6 4wd-cylinder 3 misfire
- extractors
- Engine removal 3VZE
- 2003 V6 Timing Belt??
- Dash Lights...
- Gas Mileage and General Questions '03 V8
- rear glass won't come up!
- 1998 Crazy Starting Problem - Part 2
- 90 runner with starting problem finally fixed
- 2002 4Runner, warped rotors again?
- 95' alarm system
- 99 4Runner hard to shift out of Park
- A340H 89 4runner
- Qs about Suspension, Torsion, and other French Words...
- 22R-E cold start injector sending unit???
- Crud Build up in engine 2001 $Runner
- no. 4 solenoid, a340h
- 95 4Runner Rumbling transmission
- is there any difference between a 1997 and a 1998?
- Carfax on a 98 4runner, what exactly do these mean?
- 86runner suspension help please
- Rattle under 95 4runner
- 91 4Runner Throttle Body/Intake "Idle valve?"
- Need a new transmission
- 2001 4Runner - Brake warning lights on
- downeys's lsd's and tougher cv joints
- 1987 4 Runner Manifold Glowing Red
- 1998 4 runner fuel filter
- Tranny shifting problems, + misfire
- passing gear/transmission problem
- False Water Pump Idler Pulley Bracket
- Major Electrical Problems
- Oxygen Sensor '95 4Runner
- rough shifting in 4low
- 2003 4Runner rough cold start
- Another Tranny problem!!!
- load sensing valve have any rubber parts inside?
- 94 v6 4runner timing belt replace
- About to replace timing belt.
- Back hatch light not coming on with door open
- 1999 V6 Check Engine Light
- Removing Grille on '94 4Runner
- Compatibility
- Help: 2003 4Runner (auto function) for Power Reset
- 94 4Runner o/d light and transmission probs
- '93 4Runner manual transmission problem
- 1995 4Runner: All power windows stopped working
- Help!!!!!!!!!!
- air conditoning help
- Electrical Problem Please Help
- Optimum Tire Size for my 95 4runner
- Noise under 4Runner
- $ Brake Jobs, Need Help PLEASE
- Squeeky clutch pedal
- not starting??????
- bigger rims
- Chugging when accelerating
- 1988 runner. radiator, or water pump?
- 4Runner Purchase
- Replace side mirror glass..any help greatly appreciatted
- 95 hesitating and grinding into 2nd gear
- radiator flush 98 runner
- transmission filter flush - 98 runner
- 88 4runner psyco electrical issues
- 99 Limited Stereo Replacement
- Thump in tranmission while stopped
- Caliper Noise?
- Length of brake lines for 85 4-Runner (4x4)
- 98 4runner autotrans. problem
- 4" pro crap lift
- front and rear diff for 91 4rnnr
- '91 throttle body issue
- Service Manual
- Removing Emblems
- 05 4runner maintenance light
- 2000 Mileage 3.4
- check engine light (erg problems)
- brake light
- Code 0171 - sets only when cold.
- Alternator Question
- Mysterious Noise-1995 4/RUN-THOUGHTS?
- key program
- Loud screech when I start my engine
- A/C leaking inder dash?
- 2001 4Runner Sport feels like it's going to stall...
- motor feels forced
- Clutch fluid
- Moonroof seal 1989 4runner
- 2002 4runner transmission problem ?
- Paint chipping? Anyone having problems with
- wont start after being ran?
- 90 4Runner Timing Chain repair oil leak
- Rotors
- Tailgate Window
- Center Cap Rear wheel (passenger)
- 4 runner problem-loss of power
- trans/auto
- 99 SR5 idle problem
- 97 Limited Tranny Won't Move From Park! Help?
- 1993 4runner back window problem!
- Low engine knock
- 2001 4runner wont start
- A/T Oil Temp Light and Shifting
- Oil seeping - rear main seal or oil pan
- 87 4runner turbo problems
- HELP...timing chain help needed
- sr5 vs limited
- Head Gasket Question
- 1993 Toyota 4-Runner Auto. Trans. Temp. Light Coming On
- How to change sunroof on 93 runner?
- 94 4runner ac
- very odd please help
- starter 4runner
- 01 4-runner stereo removal help
- Sunroof switch - how to get access or remove the head liner
- My 93 4-runner is slow and sluggish
- Radio light
- antenna motor
- Fresh air vent blowing moldy air, resolution ?
- Antenna
- Easy Accessory Belts Question, '02 SR5
- recall on front ball joint problem ?
- Inside tire wear 97 4Runner, need help diagnosing
- 4runner body on pick up frame
- tail light problems
- Water in Exhaust
- Fuse location for oil pressure/water temp gauge
- Manual vs Automatic
- Whining
- Heating Control Unit
- 91 Toyota 4runner power problems
- Looking to buy a new 4runner need advice
- ? how to remove brake light bulb
- Fuel Injector Question
- steering wheel audio controls
- Major problems W 88 Runner Please Help
- Help - Major fluid leak
- 1990 Low idle
- Leaky Moonroof...HELP!
- 87 4Runner Automatic Tranny Clunking
- 90 manual shift
- freeway driving i dont get it
- fuel pump cut-off switch
- Hilux Surf steering wheel
- 97 4Runner exhaust
- 1992 Front Wheel Removal Bang? Lube? Crowbar? Heat???
- Sound System
- Time for New Tires, Which Ones to Buy?
- 1992 4wd auto trans shift problems - hrlp!!!
- Blowby Gases/ Oil Catch Can
- 90 4runner break issue
- transmission filter change.
- Steering wheel vibration. need help please
- New intake and muffler
- throttle body port "R"
- additive at gas station
- 91 4runner SR5 Transmission Problem.... See if you can help me...
- 2000 4runner exhaust
- 2000 Check Engine Light
- 4 Runner Oil Maintainence
- 1990 4cyl. fuel filter
- ?Best roof rack for 28ft ladder on the 4runner?
- Why does the idle stay up at startups?
- 98 4Runner Trunk lock problem
- new starter, new batt, new cables, still starting prob.(clicks)
- 90 4Runner
- No headlight warning 2003 4runner SR-5
- Gearing
- Deckplate Modification
- New Key for 2004 4runner
- paint for 4runner
- Toyota Recalls 750,000 SUV'S and Trucks
- Recall?
- window seals
- Any previous Jeep owners out there?
- Replaced Starter but still having a problem
- Dohc
- automatic climate control from limited in non-limited (manual) model
- 2001 sport with limited headroom
- Rear Window and Keyless access not working
- Link to 2003 Toyota Factory Service Manual
- 95' Runner feels like a stall?
- lifting a 4Runner
- Need help with 2000 4-Runner O2 snesor
- tailgate window motor
