View Full Version : Tercel
- Auto to stick conversion my95
- 1997 Toyota Tercel - San Francisco Bay Area
- 97 Tercel/Corolla trans swap
- Is there an easy way to put on the A/C compressor belt?
- Clutch Slave Cylinder Replacement?
- 1990 Toyota Tercel won't start
- And now my speedometer/odometer don't work
- Where is the water pump on a '95 Tercel?
- Clacking 1999 Tercel
- OBDii driving cycle
- 1992 tercel relay
- 96 tercel random misfire
- Alternator(??)/electrical problem. Help needed please.
- 1995 Airbag Sensor Assembly Fitment
- 1984 toyota tercel sr5
- air idle control valva
- Leaf Springs Going Bad?
- 95 Toyota door stuck shut!
- Does anyone use hub centric rings?
- 94 Tercel Need Bolt Information
- Problem with '91 Tercel
- Knocking under load
- 1993 Tercel Idle & Acceleration Issues
- 1993 tercel dies when accelerating from idle
- ignition coil problems
- 96 Tercel weak engine and vibration
- Blower fan working intermittently
- Do your door handles break like mine?
- A/C Compressor Issue
- 1988 Tercel Engine Won't Turn Off
- 92 3EE : What's the ball behind the oil pump?
- In case your horn quits working
- low idle/shuddering
- Barely any heat coming from heater
- 1997 Tercel alarm resets when battery disconnected
- help my wife messed up my dashboard PLEASE!
- Speaker wires
- Help! 1995 Tercel won't start
- popping out of gear
- trans wont shift
- 1993 Tercel Engine Swap
- need help 95 t tercel engine swap
- 1992 tercel ac problem????
- 93 Tercel surges at idle
- bought a 89 tercel my first car
- 1995 Tercel A/C Problem...Pushbutton switch?
- Toyota Tercel just up and died
- PCV Valve 96 Tercel Stuck
- 96 Tercel
- I Really Need Help....Engine swap Tercel 1996(japanese) with Tercel 1995 American
- 1991 tercel shifter cable
- engine stalls with clutch in when i come to a stop in 1st or reverse.
- factory wiring harness
- 1996 Tercel Code PO401
- 91 Tercel Harmonic Balancer question
- engine
- Re: Manual gear shifting problem
- Sounds like tin cans when turning
- no headlights, emergency flashers or horn
- body panels
- 88 Tercel Problem, Any Help?
- Timing
- '94 Toy Auto 4 cyl
- Installing an auto start - 1994 Tercel
- toyota tercel 1999 1.5 turbo disiel greddy type rs dump valve help.
- need help with tercel... badly
- Can Someone Please Look Under There MANUAL 91-94 Tercel For Me?
- Prob. with removing Transaxel from engine!!
- need full ac kit for 99 tercel
- Bad EGR valve?
- info on a weber carb swap for a 88 tercel 3e
- 94 Tercel missing on 2 cylinders.....
- How do you know if your tie rod ends are bad?
- 88 tercel Vacuum diagram
- 1993 Tercel 3ee 1.5L Manual 30MPG Normal?
- 93 Tercel- Will Bad o2 Sensor Trigger Check Engine Light?
- toyota problem
- Toyota Tercel 99 door panel removal
- 96 toyota tercel starting problems
- Stripped coolant drain plug
- 87 Tercel needs Freon???
- Ceramic brake pads compatible with '94 Tercel?
- park lights and radio questions
- Are the 3EE problems only from the factory? Or even if rebuilt?
- Please Help: Axle Hub Nut
- 1993 Toyota Tercel NO SPARK...
- HELP please timing gear marks
- 87 Toyota Tercel starts rough and stalls HELP
- 87 Toy Tercel starts rough and stalls
- Idles fast & Slow by itself
- 1994Tercel Starts Hard / Won't Start
- Help - my '91 Tercel is dying
- 95 Tercel Rear View Mirror Replace/Repair
- '82 Tercel Carb replacement
- 91 Tercel 5-Spd Thoughts Wanted
- down, 96 tecel-need help
- Worrying noise from timing belt
- 1985 motor swap
- 1985 upgradeable?
- EGR Valve 1993 tercel
- 1993 tercel dies
- 1995 tranny?
- 1992 Tercel, few questions..
- Door light and dome light won't turn off
- 1995 A/C Problem
- 94 Tercel Valve Adjustment
- after market headlights
- 1991 tail light problem
- 1992 tercel alternator
- 95 tercel speaker size?
- Spark Plugs
- headlight adjust
- 97 Tercel Radio wiring
- 93 toyota tercel engine
- 1990 Toyota Tercel Timing Belt Replacement
- Firing order
- Hot smell from AC
- need A/CA COMPRESSOR
- 87 Toyota Tercel Carb
- Weird Problem with Tercel
- 84 tercel 4x4 rear Transmission mount
- alarm plz read
- 1995 Tercel Upgrade
- Tercel 92 - Vibrations - Alignment or engine problem?
- 1997 Tercel dash lights
- Toyota Tercel 1996 billowing white smoke only when humid and only on start up
- 93 Tercel CV Shaft removal Driver side
- 93 Tercel starts warms up won't start again?
- 85 tercel carb swap ??
- 91 Tercel Electrical
- Tercel boby sag
- Belts
- mileage help 1991 tercel 1.5 auto fuel injected
- stripped engine block coolant plug
- Electrical Problem, any advice appreciated
- engen swap
- 92 Tercel...SSSmokin'
- 92 Tercel Dies, need help plz!
- Dropped cyl. in 92 Tercel
- 1988 tercel carb swap
- '97 - '98 Tercel Extended EVAP Warranties
- 1994 Toyota Tercel Wiring for audio
- 1983 Toyota Tercel stalls -Help
- wiring diagram for 86 tercel
- my 89 tercel
- 1995 Toyota Tercel
- light on warning buzzer
- help--ignition timing, i think
- lights on warning buzzer & battery buildup
- 84 dropped dead ? Which wire? PLZ HELP ASAP
- 95 tercel auto trans
- 96 tercel help w/ clutch
- CV joints replacement 91 tercel/how difficult is it?
- loss of power and shaking
- 91 TERCEl Will not Start
- 1992 Tercel Manual Transmisison
- 85 Tercel Engine Surges
- I Need Help
- 89 Tercel not starting
- 1984 toyota tercel wagon help
- how connect tachometer to 94 Tercel
- 1994 Tercel Cooling System Diagram Help
- 95 Tercel Check Engine light
- 90 stem seal replacement
- 3100 rpm @100 km/h- too high?
- 89 tercel1.5 1 brrl
- Door handle and door lock unlocking issue
- Tercel Seatbelt
- '91 Tercel - Wipers work on high only
- `93 Tercel DX 2DR 4spd. A few problems.- Kinda lengthy-
- My problem
- Ceased wipers
- 95 tercel front brake rotors
- 94 Tercel HTR/AC fusebox
- 96 tercel check engine light
- 93 Tercel 5SP - Post engine swap timing check ?
- 93 Tercel 5SP - Post engine swap, transaxle "clunking" ?
- 1994 Toyota Tercel, Help!
- Vaccum Line Diagram
- Body Kits and Body Kits for Tercel
- Need '83 heater console; need Dallas,TX mechanic
- Torque specifications?
- how connect tachometer?
- '93 clutch master cylinder replace?
- Burnt Valve
- Rocker Arm Springs?
- vibration problem 92 tercel
- Passanger mirror
- 96 tercel idling high
- 83 tercel fuse box....i need help..
- engine swaping?
- 94 tercel missing on cyl #2
- Few Problems with my 1995 Tercel
- 91 Tercel 5-speed
- 1988 Tercel Brake Issues
- 97 Tercel timing belt interval?
- Need some minor help. 86 tercel idling rough
- leaking oil=
- Tercel Automatic Transmission
- Running on 3 cylinders
- seat swap
- Haynes or Field Service Manual for a '95??
- 91 Tercel Back Up Light outage
- Funny Business- Silly STRUT Question
- Clutch- Dying here, please help!!!
- Air Conditioning 93 Tercel..Upgrading?
- intake cam
- E-Brake light stays on
- toyota after market parts =
- Goodbye to my 85
- 92 tercel ,not starting=-
- coolant disappearing
- door latch on tercel 91
- 87 tercel???????????????????????????????????????????? ?????????????????????????
- 95 dx not starting
- Help with idling issues
- Funny noises!
- The Official 2006 Group Buy for Carbon Fiber Hoods
- "steam/smoke" coming from vents
- Where to place floor jack?
- engine swap
- God help me before I get the gas and matches!
- Dead Cylinder
- steering wheel
- Dual exhaust
- transmission swap?
- Check Engine on in my tercel 93
- somthing odd
- Coolant leak
- Toyota Tercel 84 engine Help
- electrical/voltage spike problem
- 1985 Tercel HELP!
- anyone rebuilt a motor?
- 1995 rear window
- Breaks, HELP!!
- 95 tercel!!!!
- 1994 Tercel broken door handle
- 95 tercel
- Charging System Proplem
- Best Repair Manual?
- 94 heating problem's
- Code 71
- ahh can't shift
- water pump replacement 90 Tercel
- Window being stupid
- 91 Tercel Thermostat
- 80 tercel swap
- people help
- people help
- Rear Suspension Damage - Looking for Opinions
