View Full Version : Tercel
- cam
- battery light on but still charging
- 92' Pulsates while accelerating
- 1991 Thermostat. Anything else?
- obd scanner
- 95 randomly jerks when going high speeds.
- oil leak
- Clutch messed up?
- 1982 Tercel swap
- Best Way To Increase Heater Output?
- engine swap help please!!!!
- all wheel drive conversion
- oil leak at valve cover
- EGR Valve
- 91' Tercel Warning Lights
- Steam from exhaust but not all the time
- 93 Tercel Coolant Leak
- heater core
- rear axle nuts
- motor swap
- Failed SMOG. I need to sell the car. What to do now?
- car heating up at idle 94 toyota tercel
- 95 Tercel ..slower and slower to start!
- Different headlights on a 95 Tercel?
- loud squeeling noise
- Removing a radio 1994 Tercel
- no tail lights, 2 wires left. Need help ASAP
- Coolant in cyliner and vacume lines question
- heater/defrost fan with intermittent speed
- 86 Tercel Carburator trouble
- Exhaust Probz...94 Tercel
- camaro ss vs mustang gt
- Breaks
- Tercel 94 smoking blue
- 1991 Tercel - miss #4 cylinder
- If you did a Swap, Help me !!!
- Main Drive Pulley
- wont shift back to 2wd
- 95 tercel dx hesitation on acceleration
- Tercel 94 Starting Problems
- power steering and ac belt
- Trecel '99 Headlights relay problem
- I Have a GT Turbo Starlet in NY
- 93 Tercel Head Bolts
- '87 has Shaky Steering
- Turn the Key, Click....nothing...
- 1990 to 1994 3ee engine differances please help!!!
- 92' not running right
- battery and brake lights on
- OUTRAGEOUSLY EXPENSIVE exhaust pipe?
- 83 Tercel overheating
- Removing interior door trim
- Break Light and Battery Light on
- Will these rims fit?
- Rubbing Grinding Sound, what is it?
- Pinking, pinging, timing adjustment
- Help. How do I remove the door lock
- Air intake and muffler questions
- 91 starter problems
- big obd problems 94
- 93 tercel 17mpg....running awful
- tercel 1992 model
- Bumping in front end on 85 hatchback
- 91Tercel - No Headlights
- 1991 Tercel Questions from a clueless owner
- Matchbox or Hot Wheels Tercel?
- high beam flickers w/left turn signal
- 92 vacuum line help please
- 87 tercel clutch job
- 91-94 Dashboard removal
- Struts And Cv Boots
- 91 Tercel rear Strut issue
- 1991 tercel...where is the fuel pump relay??
- Engine swap 1990 to 1991
- Engine Swap
- Help, '94 Tercel with Starting Issues...
- Problems with 88 tercel
- 94 Brake Problems need help
- I was installing my deck: out went the lights, clock ext.
- 93 Tercel headlight changes help!
- 40 amp buss fuse "CMH" code
- '85 tercel brake problems
- f/s custom turbo manifold
- getting a 93 or 94 tercel needs head gasket?
- Engine light is on
- repair manual
- rear side window replacement
- Master cylinder kit?
- 1995 Tercel Timing Belt Change FYI
- Celica Engine in Tercel ??
- Where to buy aftermarket corner lights?
- turbo tercel
- Tail lights won't go off....AC blows my fuses
- lug pattern ?
- Paseo tercel automatic trans interchangeability
- 1990 Tercel
- turn signals not working
- '90 Tercel NO SPARK
- First post, 1985 Tercel question
- 1996 Toyota Tercel Wiring Harness Diagram
- newbie wants help
- Strange electrical phantom...HELP!
- 92 Tercel rear seat removal
- 5efe head-3ee block
- Suspension ripoff in progress?
- Tercel brakes
- Noobie questions
- 1994 Toyota Tercel Engine Swap ??
- comaptible parts between '85 and '90 tercel?
- 93' engine replacement options
- Finally had to rebuild
- 96 tercel reciever wiring
- Strange A/C Problem
- Loud noise from motor
- 91 Tercel - erratic surging idle
- 95 wiring diagram
- toyota tercel 1988
- 92 Tercel woes
- Help, car problems
- 4efte
- 5E-FE Timing Belt Change
- Smoke coming out when starting
- 1995 Toyota Trecel
- 1983 tercel sr5 4x4 wagon clutch
- '91 Tercel - problem(s)
- 89 2dr tercel questions
- 82 trecel engine upgrade
- 1988 TERCEL >TIMING QUESTION??
- Kill Switch
- cant get the exhaust pipe off the manifold
- 94 Toyota Troubles..help!!
- 91 tercel wiper motor replacement, Need HELP!
- Radio and dome light
- Toyota stereo wire harness diagrams
- 94 Tercel Electrical Short - No Dash or Tail Lights
- 93 tercel wont start
- Aftermarket sunroof installation?
- '92 no lo-beams
- Motor problems with a 91' Tercel.....?
- Toyota Classified Thread
- 95 Tercel Repair Manual - woohoo!!!
- 94 rattling when stopped, started, parked, reverse..??
- 1982 Engine Swap?
- subwoofer + 4 speakers
- Coilovers
- Tercel stereo cross-references
- 95-99 rear spoiler
- Window tinting
- '93 tercel headlights won't turn off.
- 4wd
- 97 Tercel Valve Adjustment
- Removing paint from threads
- Chirping noise
- 1991 engine rebuild
- Replace solid rear seat with fold-down seat?
- Transmission problems I think
- Oil Leak trouble
- 95 tercel dx good car????
- How to remove headlight
- 95 Tercel dashboard clock
- 93 Tercel engine Swap
- 96 tercel 5efe -low oil pressure warning light ?
- 84 toyota tercel 4x4 trans problem help
- 1991 Toyota Tercel + Engine Swap
- '85 trecel, bad idle, no power, loud banging
- What Engine /performance Swaps 91 tercel
- Swapping Engines?
- 93 tercel oil leak bad
- 87 Tercel. Shift Problems
- rear suspension on 1985 Tercel sedan
- 1987 Tercel dies electrically....
- Idling HIGH
- 4efte swap
- 95 Tercel Fog Problem???
- Heat Selector Cable?
- '84 Tercel 4WD shifter
- 1990 Tercel questions
- EGR valve
- 1990 tercel kick down cable adjustment?
- replacing windsheild washer pump???
- 91 tercel died
- locked keys.....
- 95 Tercel Bucking?
- 1982 trans swap
- 99 tercel
- 93 Transmission Problems
- Good auto repair shop in Tucson??
- 93 tercel heads
- 97 tercel won't start
- Dash mounted clock
- 86 tercel
- 86 Tercel Transmission change?
- 90 tercel would not head up??
- 91 Tercel
- 96 toyota tercel-charging problem
- Best motor for price??
- 92 tercel 2dr coupe specs
- Check Engine Light & Heater Core
- 95-98 Swap of 1ZZ-FE or 4A-GE
- tercel won't start
- emmissions help
- stereo installation
- Carb Problem??
- tercel 5 spd swap help
- 94 tercel want help!
- Transmission Failure Need Help ASAP
- 83 Toyota Tercel Sr5 Wagon
- Hesitation and poor acceleration 96 Tercel
- Brake / Tail light cover
- Fifth Generation Changes
- Driver seat broken! (96 Tercel)
- how much hp does a 92 tercel have???
- how to...???
- Replacing starter on Toyota Tercel 93
- Tercel4WD Community
- Rear seat removal help!
- 77 Celica
- 83 Tercel Sr5 4wd Wagon-exhaust Manifold
- Thought I knew what I was doing
- '83 Tercel Engine Dies After Start
- Strange Caliper Trouble
- missing conector
- How To Change My Brakes
- Accelration Problems
- Power Steering leak
- speedo
- Couple of questions:)
- engine replacement
- squeaking noise on startup and bad gas mileage
- my 83 TERCEL wont start aT all...HELP!
- shuddering Tercel on the highway...
- 96 headlight question
- Engine Swap a 3a-c with 4a-c 85 wagon 4x4
- 1998 Tercel w/ a blown engine
- Blue Book Value?
- tercel
- Runs, but will not move?
- Heater no go
- SO MANY QUESTIONS Trecel 95
- RH Side View Mirror with remote
- Does a repair manual for 96 tercel exist?
- 1990 tercel troubleshooting tips, my story...
- engine needs replacement
- Hard Starting
- any difference?
- key won't turn
- check codes 97 Tercel
- Brake Question
- 1997 tercel od/off
- How much hp does a '96 Tercel have?
