View Full Version : Montana/Montana SV6
Pages :
[ 1]
2 3 4 5 6 7 8
- Oil Pan Gasket change and still leaks
- Finally, Had to Ship Her off to Car Heaven
- ABS Light
- 2001 Montana Brake Lights Question
- Another airbag light situation....
- ABS / TCS on again after dry spell
- ABS / TCS off throwing C1242 Code
- Signal Relay location
- Front Brake Rubber boot things... can't replace them...
- How to Do Repairs to Leaking Fuel lines??
- 04 Montana cooling issue! A little different than most, I think.
- Pontiac
- 1st gear only? - 05' BASE w/99k miles; NO MIL/SES
- 2006 SV6 running out of gas at 1/4 tank?
- Electrical issue?
- Oversize Fuel Tank
- 2006 SV6 Runs out of gas early now?
- Turn Signals Stop Working; - Then start working again
- Water sloshing around at base of windshield
- ABS wire to hub - where is the otherside of the wire?
- clinking noise as going over bumps
- overheating agin
- Radio display jacked up
- Anybody please - Solenoids or shift kit (or both)?
- Programming remote for 05 - not SV6
- montana short impossible to find
- Purchasing advice needed
- ABS wire pig-tale to hub need advice to make it more reliable
- Will shift kit help?
- Brand new alternator, Lights dim at idle, brighten on acceleration
- How I Replaced the Alternator on our '99 Montana
- Scan tool
- 2009 Montana sv6
- 2004 Fusible Links
- Electrical Distribution Question
- AC Vents have condensation?
- 06 Montana clunking
- Program a few keyfob to my 2006 Montana SV6?
- PRND123 Not working 03 Montana
- Evap circuit - CEL
- Interior Trim Panel Removal?
- Fuel Evaporator Circuit - CEL on
- Need help with trans
- Traction Control/Stability/ABS Not working
- Front Floor Mats?
- AWD not working
- Got the P0341 code
- Anyone ditch the shocks and go to gas shocks? Suggestions?
- how do I remove the vents above the radio on a 06 Pontiac Montana?
- 05 montana temp gauge
- Air Bag Warning Light Flashes
- HELP! - ABS, TCS on - Power Sliding Door opening and closing
- Advice please ABS
- Too much oil in crankcase; - CEL on solid
- code 449
- po449
- Heater Core problem
- 2001 Montana Glove Box Lock
- '06 SV6 - 3.5 max rpm under in park??
- What makes the turn signal sound?
- keep getting engine codes p0443 & p0341
- egr valve
- Oil in Coolant
- '06 SV6 AWD - Diagnosing intermittent hesitation/power loss
- Hood Ajar
- Help, are these issues/problems related?
- No 3rd gear after shift solenoid replacement!
- Heated O2 Sensor
- Pontiac Montana is DUMB
- 2001 Pontiac Montana 3.4l Overheating Problems
- SV6 Red Brake Light
- Can the ECM measure Nox emissions?
- Heater hoses and quick disconnects
- Intermittent "Service Traction Control" Message...
- Cooling Fans Running Constantly! Sounds like booster Rocket
- little or no heat when stopped at light.
- Wheel bearings & torque specs.
- 06 sv6 keyless remote programming
- Connector hanging off on front end - Please help
- Keyless Remote Programming - 1999 Montana Van
- Driver window motor grinding
- 99 clunking with left turn.
- 2005 montana sv6
- Multiple codes HERE IS OUR SOLUTION!!!
- Fuel Level sender circuit diagram
- bad computer?
- Water, - Driver's side Montana van
- 2002 montana outside air recirc door
- Heater Core Coolant Hose
- 2006 Pontiac Montana SV6 - What to fix first?
- Antifreeze Leak Solved - Timing Cover Gasket
- Front a/c good, rear not working
- Problems after flood
- Steering Rack Replacement...
- Catalyst Monitor not ready
- Small fender bender... Need to fix a gap on my bumper
- Deteriorated rubber hose under left rear that splits in 2 pieces What is it?
- Refrigerant Charge - Montana van with and without Rear Heating / Cooling?
- 2000 montana blower in front and rear not working
- Starting Question
- Air Ride
- P0304
- 2001 pontiac montana
- Intake manifold vacuum leak? - No Start...
- External Coolant Leak
- Electrical failure UNLIKE other posts
- New Aftermarket Headlights
- Replace Alternator _ what is the real trick
- Battery Symbol Light Intermittent on and off
- cylinder 3 misfire, after intake gasket change
- manual override for AWD on 2006 SV6
- Feedback on How Dealers Operate Today
- 2006 Montana Fuel Filter
- 99 montana alternator good...but not charging battery? Help!
- A/C Heater air flow
- Can I just disable the power sliding doors on my montanna sv6 2007?
- Cutting off rear heater hoses
- engine overheat quick fix... manifold gasket shot.
- Front End Shifting on Right Turns
- 06 montana power steering hard to turn
- Chuggling at 70 mph
- Remote start issues
- Odd electrical problem doors locks.. 03 montana
- Fob is failing
- Vibration While driving
- 2003 Montana - Airbag light on and no seat belt light
- Need help disabling a bunch of things in my montana
- how to fine-tune mpg display
- engine making ticking noise
- Engine misses, occasionally dies, getting worse
- EZ-Pass tags
- 2006 MontanaAWD with no power
- ac clutch just stopped engaging / no ac ?
- 2006 chevy uplander theft lock control module
- Driver Information Center (DIC) - Update
- 2002 Pontiac Montana Error code P0420
- Can-bus or OBDII is the question ???
- 2001Montana Issues again
- Slow moving Drivers Side Power Window
- 99 Pontiac Montana sometimes starts then dies
- Montana with electrical issues
- Transmission filler tube seal.
- 3.4 V6 headgasket job photo's
- Major External Coolant Leak (only at operating temp)
- Easiest way to remove O2 Sensor - Montana van?
- 01 Montana courtesy lights stuck on
- Power Steering Hose
- Replacing Suspension
- Whining sound from transmission area
- Which fan is which?
- 2001 Montana Radiator fans
- 2003 Montana Shifting Slow (More Info)
- 2001 Montana Fan relay
- Bleeding Brakes with ABS
- '99 Montana 3.4 liter - Thermostat Removal?
- O2 Sensor Time? - Fuel mileage has dropped off by 35%
- 4T65E Transmission?
- Loose door lock
- Can I replace the shift solenoid
- My PCV valve is permanently installed? 2005
- 2006 Montana SV6 Running Really Rough
- HELP!: Images of Driver Information Center display (not working)
- Traction Control out
- '00 Montana no fuel, pump is good...?
- 2000 Montana won't start at a loss
- 2006 Montana SV6 air pump problem...
- driver information center displays on and off
- low oil pressure when first started car?
- pressure control solenoid
- 2002 Pontiac Montana Intake Gasket Replacement
- Montana 4t65e hd swap info
- Montana theftlock
- ABS Light Stuck On
- Rocker Panel Repairs - Not Doing it!
- Inside lights on 2004 Montana are out
- Coolant & Misfire
- '00 Montana says overheating but its not
- Need to change brakes on my 06 Montana. Will cheap brake parts do the job?
- Where to buy front door hinges
- Lost all My Keys HELP!!
- diagnose problem with tranny?
- Transmission problem
- paint code for lower fascia?
- self-leveling rear suspension
- help
- tranny removal
- Tranny hitting hard park to drive -- Still under warranty
- Hard Shift and Loss of Power
- Rear Climate Control
- Montana keeps dying
- 2000 Pontiac Montana Transmission Problem
- 2004 Montana loosing Air Conditioning
- Drivers door
- Clearing Codes without a Scanner?
- Lost Overdrive but 1,2,3 still working, anyone?
- Removing Pontiac Montana Brake Drum
- How to get garage to check the intake gasket issue
- 99 Montana shifts hard.
- 2006 Montana SV6 Coolant Crossover Pipe
- Maguiar's Cleans Up the Headlight Lens
- Air hose from rear air compressor for load leveling
- Keyless Entry trouble
- 1999 pontiac montana overheating. Thermostat???
- oil pan bolt
- What is a rommended transmission cooler
- spark plugs
- 2001 Pontiac Montana acts like misfiring or cutting in and out
- Driver Seatbelt not retracting Properly
- 1998 3.4L Engine and Freeze plugs
- Why should I buy a Montana?
- '02 Venture transmission fit in '00 Montana?
- Keyless??
- How much should a Fuel Pump Cost for '00 Montana?
- Heater Hose Quick Connect
- 2006 pontiac montana sv6 starting disabled
- '01 Montana slow upshifts after head gasket job
- Transmission clunk moving from stop
- 2006 montana sv6 cruise surges
- '06 SV6 - HVAC Heater loss while driving.
- Changing door bushings
- 2003 montan slow upshifts after battery disconnect
- 1999 pontiac montana no heat when sitting still
- How to adjust front doors
- 2001 Montana 3.4 127k with "crunching" front end
- Rear Wiper acting wierd
- 1999 Pontiac Montana 3.4 V6 Heat problem
- Hub Bearing Going 'South'?
- 01 overheating
- heater goes cold. frozen coolant?
- Those with ABS
- Low Oil Pressure
- montana sv6 2006 starting problem
- Montana Tail Lights
- Montana 2005 - hard (up)shifts
- Brake line help
- Pulley replacement help
- bleed coolant lines
- Replacing a Wheel Stud
- torque converter problem?
- Bullet shot into van compartment
- wiper motor crank arm came apart!! Montana 004
- Thermostat trouble
- Clanging sound from Belt area???
- vss
- newbee here problem with 01 montana cooling system
- Humidity while running the heater
- Keyless entry for 2002 will operate slider but not locks??
