View Full Version : Galant
- 2000 Galant Keyless Entry Reprogramming Problem!
- Reverse Glow Gauges For 02 Galant
- 2002 Transponder Key
- 94-98 parts
- Eagle / Mitsubishi Trouble PLEASE HELP |
- 91 cylinder ignition lock
- 95 Galant Auto Tranny Problem
- 95 galant intake
- 97 Galant Died, new battery, no start????
- HUGE ELECTRICAL PROBLEM WITH MY 01 Galant! PLEASE HELP!
- 2001 Galant Starting Problems
- Exploded diagrams of front end? (about the radiator support)
- door locks
- Jerk while starting to Move
- 1993 Galant
- 99 Galant hesitates
- Hi, New Galant Supporter wanted to say hello
- 4wd 4ws Gti non starter
- 2001 Galant Fog Light Replacement
- Is my galant having tranny problems?
- What do you think about the 1990 Galant
- Need help with fuel filter
- Coolant drainage valve on Galant 2000
- Turbine Body/Housing YELLOW/WHITE/BURNT with pics
- Buying a VR-4
- 2004 2005 Galant comments
- Weird noise when starts in cold
- '94 Galant SEI ?
- 90 Auto trans
- HELP! Antifreeze in my ISC Motor cavity ?
- HELP! 92 Galant using/losing oil maniacally!
- 95 galant transmission trouble
- 2004 Galant Radio Question
- Side Mirrors with L.E.D.s
- engine swapin
- 1989 Gallant problem(s)
- galant antenna problems.help please.
- this is a bunch of hooey
- Keyless Remote
- 1998 Mitsubishi Galant???
- Both fans not working in mountains
- Failed Emissions Inspection
- '95 Galant Illumination Problem
- Mitsubishi Galant 1994 silver 96k miles - $2500
- 1996 Galant Idle Problem
- greetiings
- Old 1972 Galant
- manufacturers warranty
- speed sensor wire
- Tranny or rebuild kit.
- locking problem
- transmission problems 2000 galant
- 2001 Galant ES "knock sound"
- Wiring diagram for 1990 Galant needed. HELP.
- Leaky sunroof
- Airbag questions
- Brake Problem
- Angel eye/ Projector lights
- any luck shoving different motor in?
- 94 galant transmission
- Bearing Noise?
- 2000 Galant cold start idle issue
- Electrical Problems
- 89 galant timing belt swap need help!
- engine swap info..need help fast
- Mits. Galant & anti-theft alarm & door locking problem
- changing plugs?
- programming a 1996 galant keyless entry remote
- My instrument panel is dead
- 98 Galant, need doghouse, airbags
- Radio/starting car trouble
- Warm-up catalyst error code
- 1990 Galant problems...again
- reving idle, throttle while driving
- NEWB WITH 99 Galant questions
- 1992 Mitsubishi Galant heat not working well in cold weather
- Infinity Audio pieces from 99 GTZ for sale- see ad
- Galant 91 GSR suspension
- Galant A/T late-shifting
- help with drive axle
- 97 gallant parts car $250.
- help
- Body Kit For 97 Galant???
- Galant VR4 Rally Car...
- ECU WIRING DIAGRAM 4G63t
- lights dim-HELP!
- 2002 Galant performance
- clan
- '01 Galant Audio Wiring Colors=?
- Where can I find the GTZ letters from the back of the car?
- moon roof problem
- balance shaft installation
- Dash noise like small marbles
- 99 Galant No lights on the instrument cluster
- 89 Galant starter prices
- Need help...Infinity center channel
- Brake drums too small or shoes too big?
- O/D don't work
- Interference Engine or Not, That is the ?
- Price of Swap for VR4
- Lowering
- anyone know of any galant performance forums?
- got new 00 galant v6, how to speed it up?
- CD Player question
- Suicide Doors?
- 99-03 Galant Custom Grille Or Universal Billet?
- 2004 galant radio question
- Front ECU?
- headlight wiring
- Where to get parts?
- (almost)went down flooded road
- worried about car
- 01 galant dies
- what should i do?
- Radio Code Galant 2000
- 1997 Galant Horn Woes
- '95 Galant - Problem symptoms
- '00 Galant for sale!
- 92 Mitsubishi Galant Auto trans problem
- Passenger Mirror
- galant idle
- Infinity Center Channel
- 92 galant tranny problem
- Transmission Problems?
- Very Wierd Problem????
- widebody
- 94 galant please help can someone please answer back
- Fan Belt Squealing
- Window getting help in middle, need advice :(
- overdrive relay
- How do i install an new system in my 97 galant???
- Noise from front wheel well
- 03 galant LS intake and catback? HELP ME
- A/C pollen filter for 03 Galant?
- Buy a previously leased 2003 Galant-V6 ?
- but what's the difference ?
- Best fit intercooler for a 91' VR-4
- thinking about buying
- question about o2 sensors
- Importing VR-4 to the States?
- Help GDI
- WTB: 94 galant Headlight
- 2000 galant swap details
- 2001 Galant radio swap
- 91 Galant GSX automatic transmission stuck in limp mode (stuck in 3rd) FIXED!
- Factory head unit input adapter?
- Euro headlights
- 98 misubishi Galant ES...NEED HELP
- duplicate keys ?
- Passenger mirror (manual)
- 94 2.4 DOHC low idle
- 91 Galant Tranny prblms 3rdgearstick
- roof leak
- 01 Galant 8G Manual transmission swap
- Remote entry problemm, 2001 ES
- Galant 97 ES problem-thudding noise
- Motorized Antenna
- Gauge Neddles probem Help
- head lights
- galant body kits
- Please help! 1990 galant surges at idle and will not stablize!
- 1990 galant
- 99' Galant V-6
- 2001 Galant remote programming
- Thinking about getting a 2001 es...
- Mitsubishi Galant keyless remote programming
- 2003 needs help
- 2001 Galant ES Fast Bags
- 01 v6 Galant worth putting money into?
- EGR valve
- Replacing Brake Lights on Galant 2002
- 92 Galant dies on highway
- Got any suggestions?
- Making a VR4?
- 2.4 headers
- 99 GTZ...traction control light, or what?
- engine or tranny swap
- 03 keyless entry programing?
- radio code
- 2003 mild accelleration surging
- Galant body kits
- 97 misbitchi galant es v4 HELP!
- Galant VR-4 info
- Car Bogging At 5000 Rpm
- Radio problems Help!!
- Please Help!
- VR4 ECU vs VR4 CYCLONE ECU
- want 2 buy
- Just got galant 2k1 with 130k miles from dad, any suggestions on engine swap?
- After Market Lights Anyone?
- 94 Gs
- Whats wrong with my speedometer? please help
- RPM 3100 at 70mph
- electrical gremlins!!..help please
- speedometer cable
- 96 galant type s for sale or help fix
- 99 Black Galant Paint Problem
- galant 78 wiring diagram
- rims
- Dead battery, or just a short in system?
- Installing aftermarket Stereo....electrical problems
- Trouble with new brake pads on 91 Galant!
- 90 Galant won't 1. start, 2. keep running, or 3. runs fine????
- 2001 Galant ES Braking concerns
- VR-4 4G63 (from nz) in 82 Starion
- '91 Galant VR-4 Body kits?
- Galant repair manual
- engine
- Rocker Arm noise on 97 2.4L
- 97 galant overheating help!!!
- cold start & idle problem
- 2001 Galant ES Interior Accessories
- 1995 Galant problem(s)
- rear wheel bearings
- Wanted: 1990 Mitsubishi Galant GSX with busted engine
- Changing starter in Galant GTi 1990 4WD
- When to change the timing belt.
- Yeah, But....
- 1998 Galant
- left brakelight
- Alternator Exchange
- Reputable Galant ECU purchase site?
- 1990 Galant Overheating
- Cut short of 200K, need new beast
- Speed Chips
- Need master key cut
- Limp Mode and ECU question
- Mitsubishi 1800 GDI
- help?
- parting out 94 galant
- turbo a 99 galant
- 99 galant
- chrome rims
- help again...
- HELP i need info on 02 galant rotors...
- help regarding instrument gauge light
- galant timing belt
- 2003 Galant remote profram procedure?
- What Transmission Fluid?
- newbie here with some concerns!
- WTB: I Need This ASAP!!
- Im new but not that new??
- Concerns about my new '88 Galant
- Ignition Key Sticking
- Brake Job Questions
- Program Ignition Key '03 Galant
- WTB: AC Clutch or whole assembly 95-99 Galant
- I need a Galant Ecu Part Number MD167737
- Alternator Belt Repeatedly Slipping
- Engine Swap
