View Full Version : XJ6| XJ8| XJ12 | XJR
- New Member Dave
- 1994 XJ6 NO start
- Car won't start please help
- grille removal
- 99 XJR S/C won't start, compression ok
- Timing Shaft
- 94 jag xj6 starting problems
- Dodgy Kick Down
- Jag help
- third brake light
- repair costs
- ECU+Jaguar 1987 xj6 series 3
- 1988 Rough idle.
- Jaguar XJ
- 96 xj6 rough idle
- 1989 Jag Xj6 Starting problem
- Replacing rear view mirror XJ8
- 93 Xj6 rear door latch broken
- 1990 xj6 soverieng problems
- xj8/1998 handbrake shoes re-fit.
- 94 XJ12 Keyless and Alarm Question
- Need advice on buying '94 XJ6
- 1995 XJ6 repair info needed
- 1996 xj6 will not start with key
- New website feauring Jaguar parts
- Need Jaguar JEPC AND JAGUAR SOFT
- 1999 XJ8 Door Module
- I need some info please :)
- Grey smoke when starting.
- Knocking noise on 1994 xj6
- 93 XJ6.. sometimes starts.. sometime dont.
- 1999 XJ8 Needs juice
- New to the forum and already have a question
- FS: Jaguar factory XJR rims 19" $400.00
- manufacture's recommended fluids
- 89' xj6 alternater problem HELP ME PLZ!!
- 1999 XJ8 Died...
- 1993 Soveriegn - O2 sensor wiring - tracing
- 89' XJ6 Jag Electrical Prbs Need Info/Help
- advice on a xj6
- 1995 Jaguar XJ6 Door lock problem
- Fuel lines in trunk. 85 XJ6
- 95 xj6 fuel line to filter
- over riding radio security
- underhood relays 1994 xj6
- I just bought a 1987 XJ6
- 96 Electrical problem
- Fluctuating oil pressure
- 1993 XJ6 Dashboard light question
- 1975 XJ6 Repairs!
- 1999 XJ8 dashboard Lights going crazy
- dash info needed please:)
- how to clean wire wheels
- 83 xj6 heat/ac question
- timing belt or chain
- 87 XJS won't start!
- 91 Sovereign (xj6) Fuel Pump
- xj6
- side marker lamps stay on
- dash board language
- Looking at jags many custom performance questions
- auxillary fan function
- replaced a sunroof tilt/slide mechanisms.
- When should I replace Tensioners
- 1990 Sovereign console cover
- Air Bag Light On Intermittently 99xj8
- 1994 Jaguar XJ6 - No Start - No Ground to Relay
- rusted frame at control arm
- ABS and OFFTRAC
- 1989 XJ6 Need help
- P1000 How do I clear it?
- XJ8 Drivers window not working
- Cannot get rid of codes Help
- <<<jaguar tranny problem?>>>
- xj8 performance parts?
- Just had a thought
- XJS V12 Performance specs question
- CD Player Radio Combo For '99 XJ8
- 99 XJ8 Wiper comes on when car starts
- New owner--Little Info
- 1990-1996 Jaguar XJ6
- xj coolant question
- 91 Jaguar XJ6 Sovereign
- 1987 XJ6 engine running rough
- Aluminum 2007 XJR Portfolio for the UK market
- 1989 XJ6 Where do I start?
- xj6r
- xj6 window winders
- New Jaguar Owner...Hello
- HELP!DFW tx alternator?newbattery!
- HELP speakers
- Fuel Vapors and possible leaks
- biggest wheels ?
- 1000 piece puzzle missing 2 please help!!
- jag xjr black
- 1988 XJS V12 Engine
- 1996 XJ6 misses at idle!
- What warning lights mean what
- fuel and oil specifications
- Shop Manual
- Using 100 LL as additive to XJR
- 1998 XJR CD changer in trunk
- remote programming
- XJ8 Vibration
- Power Locks/Interior lights
- Heat on floor and rear, not along dash?? Please help!!
- 2002 XJR 100 15,000miles for sale
- Jaguar xj6 electrical
- Question on Display screens
- 1994 Jag xj6 vdp Fuel pump? starting problems
- Jaguar Super V8 Portfolio
- No fuel past fuel pressure regulator
- 2004 XJ8 stuck on Valet Mode
- Power Folding Mirrors Malfunction.....please help
- Loud 88 Xj6
- 1971 XJ6 trunk
- Xj-6 91
- 88 XJ40 - fuel odor in boot
- purchase or not?
- Transmission Light Question
- cd changer installation
- Water Damage- Please Help!
- parting out
- Engine Troubles - Please help!
- Advice on ABS post fitting new discs
- Check Engine light/other
- XJ8 'Restricted Performance' Issue, Urgent Help
- 1987 XJ6 production totals
- 87 XJ6 wheels
- 2000 XJ8-Knocking noise in dashboard
- problem starting 1988 xj6
- 76 XJ6 Heater/AC Work
- 1989 XJ6 How do I know if
- 90 xj6 for sale
- XJ6 1995 misses over 3000RPM
- question
- Engine swap on 1989 xj6
- Need help to program remote xj6 1993
- 1986 Xj6..to sell or not to sell
- XJ12C by Broadspeed
- drag racing an XJR
- 1988 XJ6 reverse going going gone
- 1986 xj6 body kit?
- xj6 1991 radio
- No oil pressure at low RPMs
- F/s 91 Xj6 Front End
- 1995 xj6 Starting issues Help please
- 98 XJ8 VDP - Valet Mode
- conversion FORD 4.6 DOHC
- 1984 xj6 questions
- New aluminum XJR
- New aluminum Jaguar XJ
- XJ6 starts and Cuts off when in gear
- memory seats
- fast start
- engine swap
- 1992 Remote programming
- XJ6 ?s
- Daimler soverign V Jaguar XJ6
- Slow crankin starter
- FS: winter tires + rims
- 1989 XJ6 Brake actuator?
- 1997 Xj6 Good Car
- where can i find a supercharger?
- 1990 XJ6 Problem hoping to find some answers
- Heat turned on -strange smeel - no heat
- Revive the XJ12!!!
- 1989 XJ6 Loping
- 1997 front disc brakes
- 1995 Jag XJR supercharged for sale!!
- check engine code reads multiple miss fires.
- Starting Issues (Sensor?)
- parting a 84 xj6
- xj6 modifications
- XJ6 starting problem
- Headlights on - Dashlights go out?
- Need advice on '83 XJ6
- 1991 XJ6 won't fire- any suggestions????
- Dash Lighting
- Jaguar For Sale
- Selling 84 XJ6 with approx 45,000 miles!!
- Advice on 1998 XJR
- brakes
- ceased engine
- Shock Bushings?
- Jaguar Concept Eight
- Wanting an XJ6 for Fiancee
- Starter relay
- Janspeed Jaguar conversion help
- XJ 40 Diagrams
- XJ8 - Wire path: trunk to passenger area.
- Questons on XJ6..
- Questions on XJR....
- Problems with the XJR
- XJ6 with 22" Wheels
- xj6 water in gas tank
- Need maintenance info on xj8
- I just bought a 94 XJ12, alarm, no key fob, only one key
- ? about XJR mods
- '83 Jaguar XJ6 headlights in an '85 cougar
- Hey all, new to the neighborhood !
- 1995 XJ12 No Heat!!
- Drivers seat inop - well, sort of... 1995 XJ12
- Programming sequence for automatic door lock
- supercharger for xj6
- XJ8 proclaims an even run to 60 with Ws6
- 1997 XJ6 Radio Problem
- Keyless remote reprogramming
- Northwest Jaguar XJ6 Vanden Plas For Sale
- My baby!
- XJ8 power door locks
- How much
- PLEASE HELP Instrument Gauge cluster DEAD
- Pic of my 1996 XJ6
- How do I remove head rests in a 1980 XJ6?
- Keyless entry programming question
- XJ6 Nightmare
- I now have two XJ6s...
- Buying an '89 XJ6
- Remote keyless entry programming
- Looking at a 1988 XJ6
- Wanted: Jag XJ6 in new england area
- What is this switch for??
- V12 Dual Fan Shroud
- 1984
- Xj12
- Wake up XJ6 forum!
- The bargain of a lifetime?????
- A bit of history of this saloon.
- Just to get the XJR forum off to a rolling start....
