83 xj6 heat/ac question
camen
10-31-2007, 08:31 PM
I just bought this jag. I have the internal heat/ac temp control set to 65 but heat is coming through the vents. I'm guessing there must be some kind of a flap that stops air from coming in and/or redirects air some how. any input is appreciated.
Also, any ideas/suggestions about how much $$ i'm looking at to get A/C working?
michaelodonnell123
01-22-2008, 12:02 PM
you need freon. $125 at the mechanic is the charge.
djagman
07-25-2008, 11:52 PM
the most common problem with the ac controls is a thing called the amplifier.its kind of burred on the drivers side but i would find a good jaguar mechanic.or wast time and $$$$$$$$$$$$$$$$$$$$$$$$4
'97ventureowner
07-26-2008, 12:32 AM
Please check the date of the last post in the thread and do not respond if that date is longer than 3 months from the current date.
From AF's Community Guidelines:
POSTING IN CLOSED OR OUTDATED THREADS:
If a thread has been closed, there is probably a logical reason for it. If you feel that the reason(s) for closure of the original thread are unjustified or wish further clarification feel free to contact any member of the moderating team. However, do not start a new thread about another closed thread.
Please avoid posting or voting in outdated threads. It merely clutters up the message board and makes it more difficult for fellow members to sort through the vast amount of information contained on the boards. If you have new and important information to add regarding a past discussion, feel free to start a new thread and if need be, add a link to the original thread.
The link to these guidelines can be found here:http://www.automotiveforums.com/vbul...uidelines.html
Closed.
Closed.
