Pontiac
Grand Prix
> Tips and Maintenance
View Full Version :
97-03 Front Drivers Side Window Power Window Switch Bezel
12" brake upgrade
Best way to clean 1999 Grand Prix GT headlights?
2004 & Up Grand Prix-How to diagnose a stuck rear parking brake, and replace caliper
Replace The Front Door Handles w/ A Sedans Rears
My version of a Throttle body spacer/coolant block.
Possible Tip on grill inserts.
Oil filter review on the ST3387A
MAP Sensor Seal For NA SII 3800 engine
GM OBDII DTC Master List
1997-2003 Grand Prix Remote Start Install DIY
Fog Light Lamp Specs for '05-'08 GXP
1997 - 2003 Pontiac Grand Prix GTP Rack & Pinion Replacement.
FAQ: Does my Pontiac Grand Prix GXP have a PCV Valve?
'05-'08 GXP Engine Control and Transmission Control Modules Location
1997-2003 Grand Prix Trans Mount Replacement
Heads Up Display (HUD) Dimming Fix
Keyless Remote Programming - UPDATE
'05 - '08 Pontiac Grand Prix GXP Oil and Filter Change
Crank Sensor - some other tactics
'05 - '08 Grand Prix GXP Polished Aluminum Wheel Specifications
Replacing rear window actuator in 2000 GP
Remote Keyless Entry Programming for '05 - '08 GXP
rear strut assembly replacement proceedure
Spark Plug Tip Diagnosis
how to change rear speakers 97-03 Grand Prix
1997-2003 Grand Prix Standard to Auto-Dim Mirror Conversion
1997-2003 Grand Prix Intermediate Steering Shaft Replacement
Clearing Flooded Engine (3100 and 3800)
Door Lock Replacement
How Do I Drain the Radiator Mystery and Cooling System Flush for '97 - '03 Grand Prix
Pulley Boys M90 Supercharger Pulley Tool and Instructions for Use
1997-2003 Grand Prix Outer Tie Rod End Replacement
1997-2003 Grand Prix Fog Light Switch LED Conversion
PRNDL (Neutral Safety Switch) 97-00 Grand Prix
Hard Upshifts, P1811 DTC, PCS (LOOK HERE)
Front sway bar replacement procedure
Cooling System Bypass Elbows for SII 3800 Engines
Wheel hub replacement on a 2002 GT
'04+ Aftermarket Radio Swap
Fix for headlight moisture
Remove your window tint with out damaging rear window defrost
changing supercharger oil
Arm Rest / Console Squeaky? Try THIS (Simple Fix)
fix for wipers that park in upright position
1997-2003 Grand Prix Analog to Digital DIC Conversion
Headlight Resurfacing (cloudiness/scratches/rock chips)
FAQ: Location of MAF, IAC & TPS Sensors SII 3800 Engine
Fuel pump install '97-'03
So your car is over-heating...Check here.
1996 Pontiac Grand Prix SE Transmission Modulator
Eaton M90 Gen3 Supercharger Snout Rebuild
Information on GM UIM Plenum and Aftermarket Plenums for SII 3800
L36 Composite Upper Intake Manifold Swap to L26 Aluminum UIM
Information on Aluminum Framed Lower Intake Manifold Gaskets for SII 3800
2000 and Up 3100 LIM Gasket Procedure
steering wheel radio control installation
Advisory for All '01-'02 Grand Prix with SII 3800 Engine Concerning CAT Convertor
L67 Supercharger Boost Bypass Valve Adjustment
Wheel Hub Replacement '97-'03
FAQ: Why do I need to run premium fuel in my L67 GTP?
Main Drive Belt Tensioner Removal Procedure and Bypass Elbows '99-'03
Front and Rear Speaker Color Coding and Polarity '97-'03
Radio Backlight Lamp Replacement '97-'03
Removal of Radio '97-'03
How to remove the front bumper '97 SE
Strut Replacement Procedure '97-'03
Fuel Pump Resistor Bypass '97-'00 GTP
Fuel Filter Location and Replacement '97-'03
AC Delco Platinum Spark Plug Heat Ranges for SII 3800 Engine
4T65E Autotransaxle Solenoids '97-'03 Grand Prix
Drive Belt, Pulley, and Tensioner System '97-'03 SII 3800 (L67)
How to Replace Ignition Switch '97-'03
How to do an Oil and Filter Change '97-'03 SII 3800
Guide for Thrasher CAI Installation '97-'03
Thermostat Replacement '97-'03 with SII 3800 Engine
Eaton M90 Gen3 Supercharger Snout Removal Coupler Replacement
Crankshaft Position Sensor Replacement '97-'03
Guidelines (Please Read)
Autolite Copper Core Spark Plug Heat Ranges
Remote Keyless Entry Programming '97
Power Steering Pump Replacement '97-'03 SII 3800
Welcome!
how to paint your dash
Supercharger for the GT Engine and L67 in the GT and SE.
