View Full Version : Grand Prix
  1. P0171: LT fuel trim high but ST looks good
  2. P1404
  3. Key cylinder lock won’t release
  4. 89 grand prix turbo
  5. Hello again! Just dropping by....
  6. 2002 pontiac gp gt will not change from defroster mode?
  7. Regulator guide clips smash and grab
  8. Frustrated757
  9. 2004 Pontiac Grand Prix GTP Comp G Brakes
  10. 2004 Grand Prix - HELP ENGINE KNOCKING
  11. How to unclog a sunroof drain using water
  12. 96 Grand Prix Key Lock Cylinder
  13. 2002 pontiac grand prix abs+trac light on
  14. GP Pontiac 98
  15. Shifting without pressing brake pedal
  16. 2004 GTP 3.8L Not starting
  17. Vacuum Harness
  18. Heads up
  19. ABS harness
  20. water in oil
  21. I've reached a dead end.Engine overheating and radiator fans not kicking on. Problem with my wiring?
  22. Fog Light switch activates High Beams?
  23. Wheel Squeal
  24. 2005 grand prix gtp compG
  25. 2004 Grand Prix keyless option
  26. 1998 GP GT advice
  27. Non Start
  28. Grand Prix 2006 NA engine pinging
  29. Tracing a P0171 code
  30. 2002 pontiac gp 2 door coupe
  31. Code P1313 - 98 Pontiac Grand Prix GT 3.8
  32. Engine bay of Pontiac 3800 GT
  33. 2004 Pontiac Grand Prix GT2 Overheated & Won't Turn Over
  34. Fuel Gauge problem
  35. Need help with 2005 GP GXP
  36. ABS wiring
  37. 00 Grand Prix GTP intermittent noise.
  38. P0341 2004 grand prix gt
  39. programming key fob
  40. AC system not working properly
  41. 98 GTP: Leakage current
  42. Wires disconnected under brake master cylinder?
  43. 98 GTP: P0341, p0171, p0302
  44. HELP PLEASE!! 2004 Grand Prix GTP Supercharged
  45. 3.1 v6 to a 3.8 v6 supercharged
  46. Repaired rear strut towers, brace?
  47. In need of 71 grand Prix pass door
  48. '08 GP Stalled while driving, then no start, no spark
  49. moderators-please don't close old threads ?
  50. Beautiful 2004 grand prix gtp supercharged cpmp g
  51. Misfire? Head gasket?
  52. The end of an era
  53. 1997 pontiac grand prix 3.8l engine
  54. Lower Engine Mounts replacement
  55. Clogged Plenum EGR passage
  56. oil leak
  57. 99GTP: Transmission slipping, TCS Off, and multiple codes
  58. Brakes: lack of power assist
  59. ABS voltage at hub
  60. Power steering issue
  61. To change or not to change old trans fluid
  62. Security light flashing
  63. 97 - 03 Body Parts
  64. 99: A/C compressor failure
  65. 1998 Grand Prix GT alternator won‘t charge
  66. 08 Grand Prix Transmission problems
  67. A/C problem. Panel or actuator?
  68. 2002 GT blue smoke mid-day only.
  69. 2008 Grand Prix V6 135,000 miles
  70. 97gp front passenger side door locks
  71. 1997 pontiac gp horn fuse and relay?
  72. 2000 Grand Prix Steering Noise
  73. Transmission
  74. 3rd brake light wiring harness
  75. Broken seal? under car
  76. Electrical issue
  77. 1997 pontiac grand prix 3.8 car stalling at different speeds?
  78. coolant elbow remnant inside of serpentine tensioner
  79. How do you pull a supercharged 3800 motor?
  80. Temperature Rising on Pontiac Grand Prix 2002
  81. Torque Converter Clutch Solenoid Location
  82. 1997 pontiac gp gp axle shaft removal
  83. Left over bolt from lim replacement
  84. Starter trouble
  85. 1997 pontiac gp
  86. 04 grand prix chugging issue pls help
  87. 1997 pontiac grand prix 3.8 transmission trouble
  88. 2005 GTP bubble in heater core
  89. 99 GTP: Key cylinder replacement
  90. 2005 GP intermittent start issues
  91. Battery Tray
  92. I found some cut wiring under the hood...
  93. Transmission hard shifting and whine
  94. 99 GTP: Mystery fluid on floor
  95. Horn Issue
  96. Whiney sound
  97. Vapor Canister Vent Solenoid
  98. 1998 key problems
  99. Fuel injection fuse keeps blowing. 2004 comp g
  100. 2000 Grand Prix GTP P1629
  101. transmission time!!
  102. 2000 grand prix gt 3800 stalling issue
  103. 99 GTP: Bleeding brakes and ABS
  104. Stuck key and the BTSI
  105. ac blower and resitor issues
  106. 2004 Grand Prix PCM issues?
  107. 99 GTP: How to check oil pressure after rebuild?
  108. Non-working Temp Gauge!
  109. AC Compressor only works when jumped.
  110. '08 GP - Loud hum, slight vibration when turning left.
  111. 98 GTP trans issues
  112. Airflow or radiator problem?
  113. 2008 Pontiac Grand Prix clunk noise when turning
  114. Rear Strut Tower rusting out, might be the end of the era.
  115. '08 Base - Air Pump operation problem/question?
  116. Help!
  117. 1999 Grand Prix GTP - oil leak
  118. both bolts on the power steering pump have snapped off and I need to drill them out of the block, any suggestions?
  119. 01 grand prix se or 03 mitsubishi lancer es
  120. 1997 Grand Prix GTP fuel pump problem
  121. 99 GTP: Power steering pressure hose
  122. a/c compressor not engaging....
  123. A/C O-ring lube
  124. 99 GTP: How much PAG oil for new A/C?
  125. Car sounding like theres metal in the pistons (there isn't its something to do with the pullys) and the belts jumping off
  126. Code P0410 after replacing air pump several times
  127. 01 GP GTP hud not working
  128. Help would be greatly appreciated!
  129. 97 GP GT Transmission problem
  130. Help! Car wont start after lower/upper intake replacement-throttle control clicking
  131. 2000 gtp bogs when builds boost
  132. Rear Strut Towers
  133. HUD install questions
  134. 2000 Grand Prix GTP only moves when put in reverse
  135. 99 GTP: Replace piston rings?
  136. Bad cat
  137. Mr. Cynical and the case of the No-Start 99 GTP (197k)
  138. 99 GTP: How to lift/hoist engine out
  139. Car Shakes When Accelerating
  140. 98 GTP: P0171 and MAF
  141. Sluggish Acceleration & Little Power!
  142. P0304
  143. Leaking Fuel 97 gtp
  144. 99 GTP: Getting to evaporator core
  145. Would like to lower front seats in 2004 GP.
  146. Crashed my Grand Prix. Is it worth getting fixed?
  147. Headlights charge my battery; huh?
  148. Floor vents and vacumm control box
  149. **please help,she won't fire after lim replacement**
  150. Temp Guage: 1999 Pontiac Grand Prix
  151. grand=prix key won't turn to off
  152. 2004 Pontiac Grand Prix - Door Locks
  153. overheating but temp gauge says otherwise. 04 w/3800
  154. 1997 GP GT Hissing noise after turning engine off
  155. Rear brake caliper wont go in far enough
  156. 99 GTP: Benefits of upgrades
  157. 99 GTP: Advice on replacing head gaskets as PM
  158. Name This Pulley?
  159. 2002 GT Total Electrical Loss
  160. smelly ac??? 99 grand prix
  161. 2006 grandprix base 3.8
  162. Repairing a leaking power steering line
  163. audio issues
  164. Front popping then alignment off
  165. Aux accessory outlets dead
  166. Upgrade to Digital Climate Control - 99' Grand Prix
  167. 99 GTP air conditioner service port
  168. Fuel Issue on 2006 GP GT
  169. Need Assist...ASAP
  170. MAF sensor circuit A low
  171. No power to AC Relay, need help!
  172. car wont start
  173. Changed Fuel Pump...now AC controls don't work!
  174. So, how likely is my fuel pump bad?
  175. Po441
  176. 97 Grand Prix GTP Wheel Hub Bolt Sizes
  177. Need Help! Bad Idling
  178. 04 GP electrical problem Intermittent no start
  179. 2002 Pontiac Grand Prix - Weird instrument lights, gauges flipping, air bag light flashing, now it won't start
  180. ecbm
  181. 1997 pontiac gp water pump removal?
  182. 1997 gtp supercharger help
  183. mods
  184. ABS Pulsing too often
  185. 2001 Pontiac Grand Prix GTP Codes - P1571, P0463, P0300
  186. Front ABS brackets
  187. Motor mount write up?
  188. 2001 GTP Cracked Flexplate...again!
  189. Possible computer failure? 07 GP
  190. 1996 Alternator instal on 3.1 help
  191. 2002 grand prix gtp front struts
  192. Output shaft.
  193. Blown head gasket?
  194. Replacing entire bose system in 2000 GTP
  195. How to replace the wiper motor?
  196. 1997 GP GT Running extremely rich and pressure build up in the fuel tank
  197. Port & Polish LIM
  198. 1997 Grand Prix 3800 series II not super charged stalls when driving at low speeds
  199. Buying another GTP !!
  200. GTP Intake job
  201. '97 Grand Prix GTP, leaking fuel line in engine bay
  202. Doors bind with fenders
  203. 2001 Grand Prix GTP Wheel HUB OHM Numbers
  204. Theft deterent service light
  205. Wheel Noise after new tires/rotate and balance
  206. Coolant Leak
  207. Cooling fans a/c not sure where to troubleshoot from here.
  208. Hoping For Some Tips? If anyone could? CNS!
  209. Auto locking doors
  210. Rusting out under GT ground effects
  211. Blower Motor Issue
  212. Extremely High Idle After Throttle Body Removal
  213. New fuel pump won't run 2002 GP
  214. Need help with two GP's with same problem running.
  215. Fuel system problem
  216. door locks
  217. 2004 Grand Prix Brakes
  218. Wiring Question
  219. Bumper hardware
  220. Transmission problem??
  221. 2004 Pontiac Grand Prix Blower Motor
  222. Blender Door
  223. Replaced Thermostat in 3.1L now idles high around 3000rpm in park or neutral
  224. 98 GTP blower motor issues
  225. Boost control solenoid question (98 GTP)
  226. Trouble Shooting a Problem?
  227. ECT Cable for 2004 GTP
  228. @#$%! Valve cover bolt broke off in head (99 GTP)
  229. 04 Grand Prix GT 3.8L Intake Manifold Question
  230. 04 Grand Prix GT 3.8L Intake Manifold Question
  231. 04 Grand Prix GT 3.8L Intake Manifold Bolts
  232. 04 Grand Prix Tire Size
  233. 1997 pontiac gp oxygen sensor fuse?
  234. Anybody running challenger rims?
  235. Factory Remote Start Feature for '06 GP not working
  236. 98 GTP: Replace LIM and valve cover gaskets?
  237. 98 Grand Prix cranks but won't start
  238. Loud groaning noises from steering system
  239. 02 starts but stalls after PW switch replacement
  240. transmission interchange
  241. 2008 Prix - Does ignition key open driver door lock?
  242. 2002 Starting and Stalling Issue
  243. 99 GTP: Fuel pressure not maintained
  244. Time it takes to replace window motor in 97 grand prix ??
  245. 2000 GT 3.8 Electrical
  246. 2004 Grand Prix, Hand Brake Cable
  247. Remote Start issue
  248. 2001 GTP Trac Control / ABS Light
  249. Code p0411
  250. 2008 Grand Prix Heat Issue
