View Full Version : Elantra | Avante
Pages : [1] 2 3 4
  1. Did I buy a lemon?
  2. Where can I find mods for a 2013 elantra?
  3. Wheel hub and bearing replacement
  4. 05 elantra code po456
  5. shaking elantra
  6. Irratic idle, car stalls, cel flickers, engine rough
  7. Do I need a new wheel bearing? If yes... which one is the best for my car?
  8. Starting problems
  9. 2013 Elantra, should I get a battery replacement or jump-boost?
  10. coolant drain and refill
  11. 2013 elantra accesories & supplies
  12. 2017 Elantra Vibrations on Cold Start (Start up)
  13. Near new Elantra wanders at higher speeds
  14. 2004 Hyundai Elantra trans problem???
  15. 2016 Hyundai won't keep charge
  16. Smashed front end now air bag light is on and seat belts won't retract
  17. 2008 Elantra interior vent problem
  18. possible transmission problem
  19. Elantra/Avante MD 2011
  20. 2014 Elantra idle adjustment?
  21. TBS and TCS lights stay on
  22. 2006 Elantra power steering pump
  23. Check Bulb wont turn off
  24. 2008 Elantra drivers side fender
  25. bunch of replacement at 19k miles
  26. Changing CV Axle
  27. Gas Cap - Check Engine Light
  28. 2006 Elantra Running Rough
  29. elantra coupe parts
  30. Pioneer Head Unit!
  31. Heat stays on while car turned off
  32. Black Elantra minor scratches appear white
  33. Mechanics clueless about engine misfire
  34. Pulley squeeling on '06
  35. Rear Drums Knocking after repair
  36. 2000 Elantra VSS
  37. '10 trans shifting funny/hard
  38. 2013 Elantra vs 2013 Sentra
  39. Transmission Fluid Level
  40. Elantra Oil Control Valve Removal
  41. 97 Elantra freeze plug heater
  42. 2001 Elantra drum brakes stuck
  43. 2007 elantra squeling
  44. 2007 Elantra Radio
  45. tranny woes 02elantra
  46. 2013 Elantra GT Radio Buzz and Reboot Bug
  47. 2001 Hyundai Elantra, window seal?
  48. Squealing Belt
  49. 2013 Elantra with no spare?
  50. 2003 Elantra engine bolt torques
  51. Engine Light Never Stays Off
  52. 2005 Elantra GT
  53. 2002 Elantra Trasmission Issue
  54. finding a roof spoiler!
  55. 2005 Elantra many codes
  56. What Parts do I need for the Tune Up?
  57. interchangable wheels
  58. 1998 elantra transmission "grabs" when at a stop
  59. Code P2251 and P2252
  60. 2013 Elantra GT wins 2012 UK Carbuyer Car of the Year
  61. How to Change Spark Plugs
  62. 2005 Elantra GLS Error Code p0010
  63. 2012 Elantra wins North American car of the Year
  64. 2006 Elantra Dashboard lights don't work
  65. Adding Fog Lights - 2006 Elantra
  66. 06 Elantra Weird Security Problem
  67. oil types
  68. Cleaning the Engine Block of my 2003 Elantra GLS 2.0L
  69. 2005 Elantra Brake rotors
  70. 1999 Elantra drive train grinding noises?
  71. New Tires causing more problems?
  72. Elantra Touring SE vs. GLS
  73. Clutch Problem on 2002 Elantra?
  74. Car has lost power going up hills
  75. 2011 Hyundai Elantra Touring
  76. Elantra 2006 transmission probs
  77. VIN question 2005 Elantra
  78. Electrical issues
  79. 01 Elantra GT Fuel Monitor Not Ready
  80. 07 rear suspension issues
  81. 01 Elantra Swerves when hitting pothole/uneven pavement
  82. 2011 Hyundai Elantra--Bluetooth problem!
  83. CV Axle replaced Left and Right
  84. 2004 Elantra leaking antifreeze (in a weird way)
  85. how to fix codes P0715, P0720, P0705
  86. subwoofer installation
  87. brakes
  88. Elantra slow fuel fill
  89. Jerking while picking up speed
  90. 2002 Elantra GT - Clutch pedal has no resistance
  91. 2001 Elantra, dies occaisionally but starts right up and goes ????
  92. 2000 Elantra Car Stalling Problem.
  93. 97 Hyun. Elantra - No 1st or reverse.
  94. 2010 Elantra unstable/veering on the highway
  95. clutch pedal gets stuck to the floor..please help
  96. Elantra/transmission vent
  97. 2000 Elantra -- AC blowing cool, not cold....Any help would be appreciated so much!
  98. Replace Air Coditioner clutch belt on 02 Elantra
  99. 2000 Elantra warning light question...
  100. 98 Elantra directional light problem
  101. thinking about getting an elantra...
  102. 01 clutch pedal will not press down
  103. 97 elantra miss at idle in gear
  104. Low coolant on 08 Elantra?
  105. My 07 Hyundai Elantra car alarm is going off indiscriminately today...
  106. 95 Hyundai Elantra Idle Speed Problems
  107. '01 pressing clutch & neutral make engine rev
  108. 2004 Elantra vibration from the front end
  109. 2001 Hyundai Elantra
  110. New to Hyundai Please Help !
  111. 2000 Elantra low speed stall
  112. 98 Elantra radiator
  113. 1999 Elantra Rear Defogger not working
  114. 97 Elantra Problems
  115. 2002 Elantra revs too high
  116. key wont come out
  117. Eating O2 Sensors
  118. 2000 Elantra hesitation and engine misfiring
  119. buying 2005 Elantra-pls help with these queries
  120. Check Engine Question
  121. 01 Elantra only goes 5MPH!!!!
  122. fixing OBD Code: PO441
  123. hyundai stays in 3rd gear
  124. '02 Elantra Head Lights dont work
  125. need help for keyless entry pad
  126. 2009 Hyundai Elantra Touring
  127. 07 Elantra rear wheel noise and rim heat
  128. idle speed
  129. Manual Transmission Torque Specs
  130. PPD Circuit Open air bag code B1462
  131. cooling fans on 1999 elantra still not working
  132. Car keeps dying with lots of codes..
  133. 97 elantra gls starting problems.
  134. timming belt
  135. 1999 Elantra Automatic Transmission Problem - No Movement - What to Check?
  136. check engine light comes on
  137. Transmission Problems
  138. po135 /po131
  139. power steering noise
  140. 2002 Elantra 1 & 4 cylinder backfire
  141. 08 Fuel Issue
  142. 2003 Elantra code P0140
  143. Outer cv joint removal dilemma
  144. 2004 Elantra audio wiring diagram
  145. misfire + random dieng at stops
  146. Loss of power after changing timing belt
  147. Replacing timing belt on 2005 Elantra
  148. 2004 Elantra VE audio
  149. 2000 Elantra electrical problem
  150. Need experience tech help with my car not getting spark or fuel
  151. Elantra timing belt
  152. Elantra Not Starting
  153. rough idle after fillup
  154. Check engine light problems fixed, not fixed?
  155. Manual Trans Fluid Replacement
  156. wierd power problem?
  157. 02 Elantra exhaust
  158. Frost buid-up inside of windows
  159. 2002 Elantra GT Shift Knob (manual trans)
  160. error code p0116 need help
  161. Front disc rotor
  162. 2005 Elantra Belts
  163. How to replace 2000 Alternator
  164. 1999 elantra with error codes
  165. no heat after installing new cd player
  166. ses light
  167. Heat/AC control problem
  168. '06 Elantra GT w/ 51K Miles What Should I Check Before Buying?
  169. How Can I Test a clutch for Slippage?
  170. 2002 Elantra Auto Tranny Noise
  171. clutch
  172. FYI-Notes On Clutch Replacement, Removal, or Remove
  173. 2007 Elantra timing belt
  174. Going to Buy '08 Elantra & Have Questions
  175. '06 Elantra: play in steering wheel with wind gusts
  176. wheel cover (Elantra 2004)
  177. Clutch Slipping Big Time
  178. Car won't Start in bad weather. (smell Gass)
  179. 2002 Elantra Cold Air Intake
  180. What can happen??? Potential project...
  181. Timming Belt
  182. Voluntary recall on Elantra Exhaust Manifold...
  183. brake Caliper Piston
  184. 2003 Hyundai Elantra GT engine light warning and car has acceleration problems
  185. Popping out of gear
  186. 01 Elantra P0105...P0705..Anyone??
  187. hyundai elantra hard to start
  188. Suspension?/Tires? Help!
  189. 2002 Elantra WIRING issue
  190. 2002 elantra problem
  191. Power Windows
  192. Key Fob for 2006 Elantra
  193. 2008 Elantra Tranny problem
  194. Need opinion on switching to an Elantra
  195. 2000 Elantra kicks out of overdrive when it doesn't need to
  196. thermostat issue
  197. What should I look out for
  198. 2005 elantra gls and servicing question
  199. Odd Power Loss
  200. Clunk in Friont End When Turning
  201. 01 Elantra fast idle problem
  202. 2002 Elantra No electrical working
  203. iPod noise issues
  204. How to replace the front wheel stud
  205. Seatbelt not retracting
  206. Wiper problem, ETACM
  207. 2000 Elantra transmission troubles?
  208. 97 air bag light
  209. Thinking about 2002 Elantra Gt
  210. Cant get Bell Housing off to replace clutch, why?
  211. 2005 elantra gls 4dr and brake issues
  212. Hyundai Elantra year 2000
  213. Timing chain replacement
  214. Oxygen Sensor
  215. 05 clutch howl when cold
  216. Car Alarm Goes Off
  217. Radiator
  218. Oxygen sensor for 02 Elantra
  219. Oil pressure sending unit thread
  220. 2003 Elantra Cam Positioning Sensor
  221. '05 Elantra Electrical Issues
  222. clutch slipping??
  223. 96 hyundai
  224. Replacing the rear bearings on an '02 Elantra
  225. By-pass filtration
  226. Parking Pawl Broken
  227. Car wont go into PARK
  228. HMA Service
  229. Speed Sensor
  230. Programe for 2006 Elantra fob
  231. steering wheel vibration
  232. car starts, nothing else works?
  233. Catalyst effeciency
  234. Output Speed Sensor
  235. General Info on '99 Elantra
  236. P0449 Code on 2003 Elantra
  237. Dash Lights
  238. 2005 elantra trans fluid
  239. Weird Elantra power loss
  240. Cabin air filter
  241. rear defogger relay
  242. 2001 Elantra Oil Drain Plug
  243. rear dwfogger
  244. Steering squeel
  245. Sun Visor
  246. Elantra shifting down hard! forcing to almost stop! maybe tranny issue?
  247. Power steering squeel
  248. Repair manual
  249. wont start
  250. front brake pad shim
