View Full Version : MY 01-06
- CV shaft broken
- Transmission solenoids
- '04 Santa Fe died while driving and won't start again
- 2005 Power antenna problem
- 02 santefe rack and pinion leaking
- is there a smaller serpentine belt 2001 v6 to bypass a/c compressor?
- Rough Running with 1,3,5 Misfires
- 2001 santa fe v6 AWD internal engine rattle
- 2001 2.7 v6 Santa fe o2 sensor code
- 2002 Hyundai Sante fe v6 ac wont Come on
- 2002 Sante Fe V6 Engine Drive Belt Noise
- Playing with the ECU in the Santa Fe
- 04 3.5 engine oil specs
- 03 2.7 ac problem
- 2002 Santa Fe Transmission shifting problem
- Air Conditioning Help
- 04 santa fe engine stopped during driving
- 02 Santa Fe Rear Rotors, replace 1 or both?
- Hyundai Santa Fe powersteering problem
- 2001 Sante Fe Heavy on Gas
- f4a51 harsh downshift every once in a while?
- 01 Sante Fe Converter
- 04' sante fe 4 cyl spark plugs
- 2001 hyundai sante fe v6 4wd
- 2004 Santa Fe Transmission Filter
- How much for new front bumper?
- Santa Fe Radio
- 2004 Santa Fe Heater/AC Fan blower switch
- Poor gas mileage, strong gas smell on startup
- 2002 Santy 4 cyl ard starting
- hyundai Sante Fe Alternator?
- Hyundai Sante Fe 2002 Problem update
- hyundai Santa Fe 2002 Problem
- Fuel Filter Location?
- hvac blower not running
- SPDELX Trim, and 70,000 miles
- New tranny needed my my 05
- What are common problems? 04, 2.7L, auto
- Simoniz Master Wax
- Some Quick ?'s about our 04 Santa Fe
- Looking at buying a Santa Fe-Questions for you owners!
- 03 Santa Fe is jerking, Help?
- Replacing factory single CD player with a 6 CD from a 05 Tucson
- Stuck in 1st gear
- Hyundais rrrr Junk
- Low Pitch Whining @ Rr Axle???
- New Look
- 05 Santa Fe Radio Replacement
- right rear pillar, a big issue?
- Warranty Restrictions if you live on a dirt road?
- Timing Belt
- O4 Sante Fe Cabin Air Filter?
- hesitates!!!!
- AC/Heat/Vent not blowing
- Severe Electrical Problems
- Airconditioner ?
- Code P0431
- engine light
- What is your gas mileage?
- '03 not cranking
- 04 Dash Pad Needed
- My Santy alarm stopped churping
- Help with CD Changer
- evaporating system?????? -
- 2002 brake vibration
- Back seats won't lift/go down
- clutch failure
- Key Codes
- 2003 Santa Fe Gas Tank Has Fuel But Shows As Empty
- '02 Santa Fe/Keyless Remote/Reprogram/Numbers
- Cabin Air filter replacement??
- Criss-crossed seat belts in back seat.
- Buying Sante Fe Parts
- Screeching sound at start-up...
- 2003 Santa Fe 60,000 mile maintenance
- 2003 vs. 2006
- SALE!!!! Sante Fe accessories.
- Almost burned my Santa Fe
- Please HELP with my alarm that keeps going off!
- New Wheels and Tires
- 2003 Santa Fe spark plugs
- I need Help!!!!!
- Odometer issue
- anyone have success complaining to American Hyundai?
- Problems w/ The Santa Fe; Can You Help?
- 2002 brake problems
- Santa Fe owner go see it....
- BG oil and fuel additives
- 2002 Santa Fe 2WD....clutch?
- Question
- Inertia Switch on 2002 Santa Fe
- My Santa Fe
- Adding Self-Dimming Mirror to 01
- Help I cant install a car seat
- CRDi shuts off while accelerating
- Santa Fe Carfax needed
- transmission sensor? brake vibration
- Adjusting Santa Fe Headlights??
- Transfer Case Oil
- P1167?
- how to change a timing belt please
- Cold Air Intake
- 2001 Sante Fe Crank Shaft Position Sensor... $765.00???
- A/C Temperature display
- Tell me about the Santa Fe
- 2001 santa fe keyless remote
- 2002 Santa Fe car fax needed
- My Driver Seat... Can I move it farther back??
- engine stalls
- Performance Air Filter for 05' 3.5L
- Problem -right front tire squeaks
- Blue/White headlights
- Rear Suspension
- 2005 Pricing
- 01 Sante Fe..ALL MINE!
- Oil Filter
- 700-1100.00 Timing Belt
- AC randomly cuts out!
- Mildew Smell With Airconditioning
- Incentives for 2005? Right now.
- loud ac
- Santa Fe O2 Sensor
- '02 Santa Fe Keyless Entry Yes or No?
- 2001 Sante Fe Fuel Door Lever will not open Fuel Door
- Poor acceleration, delayed shifting
- How to change spark plug?
- This sucks 2004 no switch to program keyless entry?!
- Sante Trouble
- Factory Fog lights
- Should I Buy This Santa Fe?
- Santa Fe? Pros / Cons? Opinions Please
- Bumper Tail Lights
- 2005 Santa Fe
- spark plugs quality
- 4 WD question
- Trailer Hitch
- thumping
- Shift tronic questions
- 2 questions A/C and gate....
- thinking of buying a santa fe
- Oil Light coming on
- Static shock problems?
- 2002 2.4l
- 2001 SF Clutch won't disengage
- Vibration/Shudder in 2003 3.5, 4WD??
- Battery - known problem?
- Lovin' it so far!
- Hello, im new here and have a few questions about voiding my warranty.
- Rust Covered?
- Repair costs out of line? $400 for PLUG WIRES?
- Any problems with the 2004's?
- santa fe alarm keeps going off
- 2004 4-cyl trans issue
- Cruise Control not working
- Transaxle not covered...
- warranty help..
- Transmission Leak
- weird clicking in engine
- Flame removal
- Call me Crazy...
- Deciding to Buy a Santa Fe
- Engine surges when maintaining speed.
- Santa Fe Maintenance (Fuel Filter)
- Hyundai News and Announcements
- 2004 Olympic Torch and the Santa Fe
- Whats with the taco?
- Engine shuts off while driving
- 2004 Sante Fe v. 2003 Saturn Vue
- 2003 Santa fe program Keyless remote
- 2003 Transmission Problems
- For Sale: SF woodgrain
- Automatic Transmission Gear Stuck
- Warranty issue & Maintenace costs....
- How do you like this SUV
- Sante Fe remote
- new board
- stoping the door chime from ringning
- how about adding extra things... what do you think??
- prospective buyer
- Programing a Santa Fe's remote
- Picuter This !
