View Full Version : CR-V
Pages : [1] 2 3
  1. lower gear on CVT[2] transmission
  2. Strange noise (2013 CR-V)
  3. 99 crv starting issues
  4. 2011 CRV Clank heard with shift from Park to Drive
  5. 2015 crv
  6. West Virginia Hybrid Penalty
  7. Electrical problem, no spark & computer issue
  8. 2003 Occasional, brief stumble on acceleration
  9. Honda CRV Slight Shudder/Hesitation under acceleration
  10. TPMS warning light comes on when I rotate tires and top off with air?
  11. 02 Crv problems again. Electrical issues??
  12. Window switch question.
  13. check disc message-2015 Honda CRV
  14. 2002 Honda CRV Electrical problems. Please Help.
  15. 2002 CR-V has random electrical issues after battery was recharged
  16. 98 cr-v overheating
  17. 2018 CRV-EXL no storage pocket behind drivers seat?
  18. 2016 - 2018 Crv Engine Oil Contamination
  19. dirty back window blues
  20. cant bluetooth pair
  21. 2015 antenna
  22. 2017 CRV battery dieing in one week
  23. 2010 crv alarm going off
  24. Whining When Turning
  25. 2003 CRV AWD Pulls to Right on Acceleration
  26. Oil Capacity
  27. 03 CR-V Clunking over bumps & right wheel hop Can't get firm brake pedal
  28. 2005 CR-V rough idle after head gasket replacement
  29. 2007 starter problem
  30. 2009 Honda CRV Engine Code P0843
  31. New to forum but happy to belong
  32. 2004 Crv idling too fast, coughing,sputtering..
  33. windshield
  34. A comprehensive review of Honda CR-V 2015
  35. Honda CR-V Suspension Issue. NEED HELP!
  36. 2001 CRV will not start below 25 degrees
  37. Helpless honda 1998
  38. Need help with 2004 CR-V Radio
  39. 2003 crv imrc (imtv?)
  40. Power window issues 2002 Honda CR-V
  41. 2003 Driver Door Lock/Air Bag Light
  42. 99 Honda CRV occasionally won't start
  43. 1998 CRV A/C not blowing colda
  44. 99 Honda CRV no reverse lights and other ??
  45. 1998 honda cr-v tensioner pulley on timing belt
  46. 2006 crv compressor removal...URGENT!
  47. 2007 CR-V Rear Door Speakers
  48. CR-V 2001 replacing front brakes and rear brake shoes
  49. 2002 Honda CR-V EX Factory Alarm not working
  50. 2006 crv weird engine/heater noise
  51. 2006 crv weird engine/heater noise
  52. 2003 CRV Intermittent Start Problem
  53. 2012 Gas Gauge
  54. 99 Honda CRV wont start?
  55. 2010 CR-V valve core part available ??
  56. how to change O2 sensor on 99 CRV
  57. 2000 CRV barely runs
  58. 05 CRV Shakes and Vibrates
  59. 2003 CRV A/C Blower Quit
  60. bad coil tested ok with ohmmeter
  61. 2003 Tilt Lock Lever
  62. Turn off Seat Belt Chime
  63. Instrument Panel lights blown out
  64. Radio Antenna issue - 2009
  65. what does a resonator do?
  66. 2002 honda crv sensor fail
  67. Need information please
  68. KYB or Monroe
  69. Crv chrome b pillar
  70. AC clutch front plate fell off
  71. 2010 CR-V First Time tire change
  72. maybe a stupid headlight question
  73. Duplicate key
  74. Air Condition Clutch won't engage - 2007 CRV
  75. 2003 crv
  76. 99 CRV anybody done rack and pinion seals?
  77. I Know Next To Nothing, Please Help.
  78. 2008 CRV TRansmission Service
  79. Cylinder Misfires of 2006 CR-V
  80. '07 CR-V Horn sounds on turning key
  81. 03 intermittent starting problem
  82. Need advice...
  83. vibration in auto trans 99 CRV
  84. Honda CRV Brake Change
  85. 97 CRV acts like it's flooded
  86. 2003 Honda CRV Air filter box
  87. 2003 CR-V remote keyless w/aftermarket remote
  88. 2007 crv door locks
  89. 1997 cr-v vibration when braking
  90. 99 crv "D" light out on dashboard gear indicator
  91. stuck drivers side window help
  92. can i get specs for wheel alignment
  93. Just Bought a 2011 CR-V EX-L
  94. 2004 CRV Headlight Warning Realy
  95. Need Timing Belt Replaced -Can I handle it?
  96. Does the ABS module on a 2000 CRV need programed?
  97. Programing a remote
  98. 99 CRV mnl rear grind--NOT the differential
  99. 2010 CRV winter tire question
  100. Valve Adjust / Clutch Creak
  101. ^^coolant spilling on crv!^^
  102. CRV chain or belt for cam drive.
  103. '99 CRV interference engine
  104. AC problem
  105. 2003 crv trouble code p1077
  106. 2007 Honda CR-V - Electric door lock issues
  107. 2007 Honda CR-V - OBD scanner issues
  108. 98 C-RV sometimes dies
  109. 2010
  110. 98 CRV window regulator
  111. Question about replacement fluids
  112. 99 CRV Interior Door Handle
  113. Trans Problem?
  114. My brake lights are JACKED!
  115. lower mpg with new michelins
  116. high oil consumption?
  117. 1998 Honda CRV AC High Pressure
  118. Alarm Malfunction
  119. wiring diagram for safety belt indicator
  120. Throttle Body / TPS
  121. emissions light
  122. Head rest/restraint issues on 2009. Any suggestions?
  123. Question about installing new stereo in '97 CRV
  124. 98 crv brakes?
  125. 98 crv sticking between gears
  126. 2002 CRV starts then dies
  127. 1998 CRV Valve Adjustment
  128. 2001 Crv wont move !
  129. How to adjust F.I. mixture in 1999 CR-V?
  130. Serpentine Belts
  131. 2004 CRV Vibration
  132. headlight comes on when blow horn
  133. 2006 CRV error code
  134. 2001 CR-V Exhaust Manifold
  135. 97 crv ball joints / brakes
  136. 2002 Cr-v 4 wheel disk brakes.. replacement
  137. 1998 CR-V Tranny Glitches
  138. 2001 Honda CR-V reverse lamp problem
  139. 1998 CR-V Overheating
  140. signal fuse keeps blowing!!! HELP!
  141. day time running lights
  142. 2002 crv 69000 kms
  143. 2001 CRV CEL flashing with no codes
  144. 2002 CRV - key lock alarm sound
  145. 2004 crv light code
  146. 2000 Honda Crv... Please Help!!!
  147. 1998 CRV Miss Fire
  148. how do i replace a control arm on a 97 honda cr-v?
  149. 2004 Cr-v Wont Go Over 45mph Cel Is On
  150. 2000 Honda CRV - Check Engine Light
  151. 97 CRV engine cuts out? help!!!
  152. When Do 2009 Honda CRV's come out?
  153. Honda CRV 2004 Instrument cluster light indicators
  154. 2004 CRV "D" light was out
  155. replacing windshield washer tank
  156. AC Compressor
  157. '98 CR-V Starting Problem
  158. all lights work but low beams???
  159. 2005 Cabin light and audible alarms
  160. onboard computer not responding
  161. 97 CRV check engne light ON
  162. 2004 CRV EX poor Gas mileage
  163. K24A1 to K24A4
  164. Fuel Filter
  165. Ignition switch testing
  166. '02 Engine "knock"?
  167. Looking at CRV
  168. Headlight warning ALARM stopped working
  169. '05 CR-V Instrument Cluster
  170. 1998 CRV Wont Start!
  171. Knocking in front
  172. Honda Crv Japan Import 1996
  173. 2003 CRV EX 4wd- vibration when turning.
  174. Surging After Sensor Change
  175. replacing spark plugs 03 CRV
  176. Transmission Fluid Capacity 01 Cr-V
  177. Question for those who change their own oil?
  178. Busted Front Lug Nut
  179. 99 wont start
  180. 99 wont start
  181. 99 wont start
  182. 2005 shaking when slow turning.
  183. Noise when turning over engine-01 CRV
  184. CRV 2005 A/T vibrates at idle
  185. Maintenance Req'd Warning Light
  186. 1998 CRV- Timing Belt Anyone?
  187. 32-35 MPH Shaking
  188. looking '04 CRV wiring diagram
  189. change speakers on crv 2004
  190. '04 CRV passenger side mirror
  191. rwd
  192. 2007 Crv
  193. Changing battery
  194. Brake fluid change
  195. 2002 CRV major thumping when turning at slow speeds
  196. Error Code 2647?
  197. 2007 Roof Rack Adjustment
  198. 99 CR-V is my mufler on backwards?
  199. Ignition timing of 1999 CR-V EX 5 speed manual
  200. CRV Keyless unlocking/locking problem
  201. 2006 CRV cabin air filter replacement how to?
  202. 2001 CRV Replacement Rearview Mirror
  203. 2003 CR-V starting problem
  204. B20Z to B20B
  205. 2007 Crv
  206. 99 CRV goes in Drive when put in Reverse.
  207. Nasty, foul mildew odor from vents
  208. Back Left Window Dead, plz Help
  209. E-Brake Adjustement?
  210. 97 radiator fan
  211. 2003 CR-V hesitation
  212. 99 crv noise
  213. Heat Shield unnecessary?
  214. 01 Performance Intake questions
  215. 2007 LX Cheap Seat Cloth
  216. 2007 CR-V Remote Starter
  217. 1998 CRV Check Engine light
  218. im not sure what happened
  219. 2003 CRV ignition problem
  220. 98 Crv Wont start
  221. Interior Scratch Fixing
  222. Make it Stop! Honda 1997 CR-V odd noise
  223. Bedding-in brake '02 CRV
  224. How do I put the torque converter in the trans on 2000 CRV?
  225. Should I jump at this CR-V opportunity??
  226. 04 CRV engine cuts out
  227. 2001 A/C Questions
  228. 2006 cr-v strange noise
  229. parts for a b20b/vtec
  230. 2001 Honda CR-V AC filter replacement help
  231. 2000 EX blower fan, A/C not working
  232. 98 CRV makess beeping noise, then dies, starts right back up and is OK. WHAT IS IT??
  233. Possible Loosing Fire While Driving
  234. acceleration sucks
  235. compatability with civic/teg?
  236. 1999 CRV stalling after tuneup
  237. another keyless entry issue
  238. CR-V Brake Question
  239. 05 CR-V Transmission Clunk On Acceleration
  240. 03 CRV temp control light out
  241. 03 CR-V oil leak bottom of timing chain cover
  242. 2002 Radio/disc Player Not Working
  243. 1997 crv shocks or struts?
  244. Clunk on acceleration in 2001 CRV Please Help
  245. How do i remove the radio from my 2004 CR-V?
  246. Installing a Sirius Radio - remove radio to get to the antenna wire
  247. '01 CRV Starting issue
  248. 2000 EX blower fan, a/c not working
  249. Remote for keyless entry
  250. I admit it; I hate the new '07 CR-V
