Ford
> Expedition
View Full Version :
Expedition
Pages :
1
2
3
4
5
99 Expedition Problem
98 expedition acting up
#3 coil bad
Just curious
2001 Ford Expedition idle problems
opinions of a 1998 expedition
2002 Eddie Bauer Expedition Rear air suspension flat
rear speaker box in a 03 EB
Tough Question.
2000 Freon Refill?
03 Expy Air Bag Light
How often does your Air Suspension Pump Run?
Repair manual for an '04
sensors and spark plugs
radio dies in gear, air/heater unit runs after off
conFUSEd
need help
2001 expedition
need help with my airbag light
My expy wont start
Ford Expy with air suspension problem. Please help!
03 Expedition issue
ROTORS I know I know. Please read.
2002 Expedition weird noise at start-up when shifting gears
98 EXP Clunk in my front end
'01 Exp. No Rear Shocks?
Silver Door Strips
Electrical problems with 98 Expedition - please help me
2000 Expedition shifts HARD
97 Expo; wanting to put in audio
p1408 on 98 expedition. HELP!!!
back window?
4x4 not working
PO352 ignition coil B primary/secondary malfunction
Door ajar/alarm question
4.6 code p401 problem
No Heat!
00 expedition EGR problems
Heater unit swap?
Heater unit swap?
2000 epedition wont start
2003 Exp. Hesitating .
Transmission Leak from Sensor
99 expo eb shutering on incline
99 Expedition Speakers
Misfire on acceleration
Can't a guy cross a river without causing engine misfire?
02 Expidition, Turn signal, making noise inside, works intermittant
Air bag light blinking. Computer shows no error!
Leaking moonroof
2001 Expedition P1131 Code
98 Expedition EB 4.6L
Ball Joints?
98 Expedition 4WD problem
Theft Light blinks and truck won't start.
door light wont go off
Can't puit my finger on it.
1999 Expedition Has No Fuse Diagram!
2004 Eddie Bauer 5.4L fuel filter
97 expy eb 5.4 hissing sound
97 Exp 4.6L Rough Idle
Changed Plugs,coil Packs And Injectors And Still Misfire #4
Help with cold air intake INSTALLATION 99 EXP
No rear heat after front heater core replacement on 99 Expedition
1999 Ford Expedition Door Locks
99 expedition air suspension issue
Wiring for a rearview camera power
2000 Expedition Battery Changed
throttle cable loose
03 Expediton
brakes on 2004 expedition 2 wheel drive
99 expedition ignition switch
spark plug blowed out
alternator problems
Continued
problem with rpm range
2000 4.6, Still can't find leak.
Question about Lifted Expeditions???
'00 Expendition -- Noisy Window Mechanism
fuel system fuse?
02 expedition moon roof stuck open
1998 Ford Expedition
2001 Factory Alarm, not able to start
2001 Expedition, Spark Plug 1
Gas Tank Vacuum Leak
loss of brakes
2003 Expedition stuck in LOW4WD
Ford Expedition 1998 Water Noises / Smell
Check Supension
Rough Acceleration
97 Expedition noises
Voltage Meter Keeps Spiking
hard start/horrible acceleration
gas smell
rear end whine vibration
clicking in door
oil type
99 EXPY Air suspension test
'99 Intermittent Starting issues - gas/spark?
noisey transfer case
Headlights not working
Position of Air goes from vent to defrost
97 Ford Epedcotion- Helpppppp!!
2003 Expedition Front Passenger Window
99 Expy XLT anyone with elec problems
Electric Trailer Brake Controller
need helpp
Help P1151 code
98 Expy has rough idle after warm
Loss of Power in hot weather/timing retarded
Front discs stuck!!
front end "sweek/wine"
New And NEED HELP... ALL LIGHTS FAIL !!!
Expedition code 420
A/C through the defroster vents only???
2000 EB EXP A/C not blowing in front
Do I have to discharge the AC to replace the Heater Core?
abs light
2003 Expo rear A/C problem....
2000 Expy Alternator Question...
05 Expedition XLS
expedition wheel upgrade
03 rust
97 Back Window Hinges just snapped
CE codes P0171 and P0174
Free Air Filter And Kits
Parking Lights will not turn off
2003 Expedition FX4
2007 Expedition
oil change
Spooky Radio
Suspension lift for Expedition...
Driver side mirror help
Previously Wrecked Expo
Flimsy Roof?
My water leak breakthrough -- 02 Expy EB
Electrical Issues: 2004 Eddie Bauer
Wouldn't start
99 Expedition Charging System Problem
Sun Roof Leak
total cost tune up
MPG? who's getting what?
air suspension
Warning Chimes
Question about ethanol
97' Alternator Replacement Hep!!!!
2003 Eddie Bauer Expedition - Help!
98 - 2001 Expedition - reviews
4-20" Ford F150 Expedition OEM Wheels/Rims
2002 expedition struggles to turn on
Welcome to March in Texas !
99 Navigator Slow Cranking up
2000 Exp. won't crank
factory amp???????????
-04 Exp. 4WD thump (light acceleration)
Check Engine Light
Replacement Rear Wheel Panel
99 Expedition Engine Light Code P0455?
Flowmaster exhaust advice
2003 expy factory install
Cutting Off Catalytic Converters
po171
97 expy eb gear selector problem
my 97's Interior light stays on
Interior Lights Dim When Braking
2001 Expedition stalls
New Expo Owner Needs Door Code
Thud in rear when stopping!
Looking at buying one for near $6000
Over head map lites
97 Ford Expedition CE light Large Evap leak
98 Expedition stuck in low
2003 expedition door locks
bank one location and problems
2003 Expedition problem....
01 Expedition Replacing Oil Pump?
'07 Order and Build Info!
heater blows cold air only
code list
2003 Expedition Front Brake Rotor Problem
01 Expedtion Oil Pressure Sensor????
raise and lower...ALL IN ONE!
How to engage A4WD or 4W-H
2003 Expedition Door Locks
New 2003 Expedition Owner
'98 with a squeaking front end
Wiper Motor Problems AGAIN!!!!
Engine Computer Module Frying out.
fuel filter replacement on 2002 ford expedition
98 E4OD vacuum modulator question
another bad coil?
battery light on
03 expedition dvd question
When were power folding mirrors available?
Air Suspension Problems
1997 expi and ecu code p1131
2007 Expedition unvaled...
Best plug to use for a 5.4L
overdrive switch problems
Need Info on Int Door Panel Removal 03 Expedition
1999 ford expedition
Smell of Anti-Freeze in cab
Driver side window is off in door!
Thinking of getting a used Expedition... Any advice?
Daytime Running Lamps
Rear Wiper Motor Removal
Differential Leak
Possessed windshield wipers?
Mechanic took our Expedition for a drive and seized the engine
hwy acceleration hesitation
refueling problem
4WD Selector Switch
Daytime and Fog lamps
2003 All Wheel drive Engagement Clunk Noise
Rain/Elect. Prob. Class-action anyone??
1997 Expediton 4wd problems
misfire Detected 98 ford Exp
windshield wiper loose on post
Find Keyed 12v Source
The Amazing Dead Battery!!! Help!
2004 Expedition Brakes
03 Expedition factory radio dead
98 Expedition - Air Bag warnign Light Blinking
keyless entry keypad
Engine noise
air suspension
Console CD Player
F/S F/T 97 expedition hydraulics bodykitted for stock 99+ expo
sub removal for 1999 Exp.
blown factory sub
1998 expedition rear wiper
Expedition running rough
Driverside window came off metal brackets
Starter / flywheel problem
overhead console, plug and play?
Oil Filter Stud?
Brake lights
2003 Expedition
stalling
Front end clunk - '99 Expedition
How do you let the 2nd row middlw seat down?
heat issue
Funny noise on cold start up.
Cheap price on rear door lock acuator
98 Expedition CE light
2000 Won't start...
Dies when let off the gas
Having trouble starting
Also have no heat!!
just turned 201k - 97 exped
