View Full Version : Windstar
- Ford windstar 1996 PS fluid shoots out
- Ford Windstar problems
- Odometer/Speedometer ABS
- 2000 Windstar turn signal
- Pulling off the rear bumper cover
- Replacing Vacuum Lines
- IMRCs close before reaching 3000 RPM
- coolant flush at heater hose
- 2002 windstar engine whistle
- 2000 Windstar coolant leak mystery
- 1996 Windstar misfire
- 2000 Windstar ABS light
- Anti-Freeze / Coolant smell from heater
- codes 98 windstar
- Battery Cables
- (2K Windstar 3.8)Misfires around 2k RPM and chokes on worm start
- IMRC'S and Rockauto.com
- Expensive misfire....
- Just a question regarding Vacuum
- Save a few $$$ on Double Platinum Plugs
- rear hatch support strut...?
- P0401 and P0402 codes
- Change turn signal bulb
- water pump squeel stalls
- 1998 Ford Windstar Transmission Problems
- 96 Winstar, 3 & 4 missfire
- Advice before I buy a Windstar or Monterey please
- Well, it's my time to join the club...!
- Windstar Alarm (Lights don't blink)
- 1995 3.8L P0305 Cylinder 5 misfire
- Can IAC fault cause emission warning light
- 2002 water pump replace
- Got a Freestar for the weekend
- can I get help with Synthetic oil?
- 99 Windstar - lost cruise control
- 99 Windstar SE - Rought starts (sometimes)
- Odd Overheat Issue 1995 WS
- 2001 Windstar IAT Sensor Location
- p0171 code now engine stalls
- Finished the Remote Starter Install....but blower doesn't work!!
- Reverse Sensing System
- What Kind Of Coolant?
- overdirve light sometimes flahses
- Cold starting in general and runs rough when cold starting
- ford
- 1995 Windstar Remote Start Schematics?
- IAC Valve Test?
- IMRC failure rate...
- New driveaxle is different than the old one??
- ODB Code P1538
- 98 Windstar sounds as if transmission may be slipping
- #1 DTC help
- P0174 Dilema
- Losing Coolant
- 2000 Windstar Engine Miss
- What year is this vehicle?
- IMRC'S on later models
- P171/P174 PCM Recalibration?
- How to clean the IAC?
- Goodbye, Windstar....
- Power Steering Flush Question
- Inner tie rod ends 2000 windstar
- 1999 Windstar - no intermittent wipers
- Just changed the Front cover gasket
- 96 - CEL & Code 174
- Right rear tire wont move
- P0145 02 Sensor Circuit Slow Resp? Help!
- Rear brake lights staying on.
- Is this a real issue????
- EGR Port Cleaning, new plugs 96 3.8
- P0171/P0174 - '96 3.8L - suspect vacuum leak
- 2000 windstar engine knock
- 1995 Winstar need remove & replace diagram
- 99 windstar won't start
- 1999 Windstar Won't Start 3.8L V6
- Codes P0303,P0316.2002 Windstar
- Door Ajar and Washer Fluid Lights Blink on/off
- 2000 Windstar radiator cap
- AC Htr Not Blowing Air
- 2001 ford windstar
- Heater box actuator arm broken - ARGG!
- 10W-30 in my 5W-20?
- IMRC'S....Be Careful
- 98 Windstar Speedo/Electric/Power
- EXTREMELY Squeaky pulley
- WindStar 99 Engine light is on
- 2001 Windstar Leaking purplish fluid
- 98 Ford Windstar shuts off after starting up
- Intermittent brake grinding noise on 2003 Windstar
- Transmission Problem Easy Fix! Please Read.
- 2000 Windstar SEL Heater blend actuator FIXED!!!
- Where is the overdrive sensor?
- Bypass Hose
- 95 tranny slippage.
- Need electrical help
- LED turn signals on side mirrors
- anyone install a spacer between strut mounting bracket and tower?
- Changing tranny fluid/filter..what's the REAL DEAL?
- 99 Windstar Tranny sounds like Pwr Str Pump
- front fan works on high only, 1998
- Mercon and Mercon V TSB from FORD
- Codes: P1537 and P0171
- '96 3.8L water pump
- Lower intake manifold gaskets
- '96 Windstar, is it worth repairing
- Loud Constant Whining Sound
- Poor Gas Mileage after Isolator Bolt repair
- 1998 Windstar P0171 & P0174 Codes
- Windstar cutting out @40mph and 55mph
- 2001 all interior lights on /all the time.?
- PO171/PO174 Diagnostic Code on a 2001 Windstar
- Electrical System Question
- While smoke at morning
- got codes for engine light at AUTOzone what do they mean? windstar 2002
- 1998 Windstar transmission no drive (AXODE)
- P0171/P0174 Codes and rough idle
- Call me Crazy!!
- P0171 Code Round Duex
- Need help Fixing my Heat
- 2001 Windstar heater problem (yes another one)...need HELP!!
- Ford Specifications
- Problems after Isolator bolt fix
- if you have engine knock and ping
- After replaced the head gasket
- 98 Winstar rpm hunting
- 03 windstar cruise control
- mods for windstar
- Lumbar support not working?
- '96 windstar,bumping noise
- Oil Dip Stick O ring change
- 1997 windstar, hesitation tranny bump
- instament panel light
- 2000 Windstar P171-P172
- Blackstone Labs
- Engine dies occassionaly when stopped
- brake light
- Are these engines easily interchangable?
- Rear heat on 99 - floor only?
- Power Steering
- Vacuum Readings
- help 96 windstar, oil in collant & heater
- MIL Lamp Output Fault Detected
- Windstar 2002: Can't get caliper over new brake pads....
- compresion and valves
- ABS and no Odometer reading
- Door and Heater Gremlins
- Calculated Engine Load with AutoEnginuity Scan Tool
- 1999 oil filter location
- hydraulic control unit
- 2000 Windstar no 12V @ OBD II Connector Pin 16
- Rock Auto discount code. first one get it
- PO171/174 Isolator Bolts Lathe Rework Done
- Premium gas
- windstar power steering pump problem
- Engine running rough
- 96 GL A/C issue
- 2 Windstar Problems
- 00 Windstar Radio removal
- How Do I change the Spark Plugs in my 2001 Windstar?
- Tranny leak...seal or vent tube?
- Brake Booster Problem
- Windstar steering shutters
- Power Steering Fluid Change
- Heater making a flapping noise
- Isolator Bolts: Latest consensus where to buy?
- Windstar woes
- Hello everyone :)
- 1537 / 1538 Codes & IMRC
- 95 3.8 190K miles: metal fatigue
- Code P0500 and flashing OD light fixed
- Helpful link
- Engine Cooling Fan Cycles Too Often
- DPFE sensor
- dash lights flashing
- 2000 Windstar - Key won't turn
- 98 Windstar P0306-Faulty Fuel Injector?
- Both Cooling remain on at ALL times??
- 2001 Rear Acc Heater and pipe wrap
- 96 No Tail Lights
- Engine Vibrations
- Tsb #0398
- Check Engine Light Refuses To Stay Off
- Motor oil in water system.
- brake light mystery
- De-carbonization
- 1998 Windstar ABS Light stays on
- little coolant leak on 95 windstar
- 3.8L 1995 Windstar Engine Struggling or Stumbling
- Anti Theft Problem
- Seafoam 96 3.8
- oil seepage problem?
- Mega codes
- Fuse #30 keeps blowing (speed control)
- Fast Idle 2003 Windstar
- 2000 Windstar Brake Rotors
- 2003 Ford Windstar Parking lights won't turn off
- 1998 Ford Windstar transmission shudders
- 2001 Power Steering 'puff' noise
- 2002 Windstar Lx Tranny
- New Engine vs. Rebuilt Engine
- 99 windstar trs?
- More Questions on tranny fluid filter change
- Exterior trim & bumpers fading
- heater core
- 2001 Windstar coolant flush, rear acc heat??
- Intake Tuner Purge Valve
- Putting a V8 engine in 1995 Windstar
- Primary and secondary coil resistance windstar
- TSB for bad intake bolts p104 etc...
- 95 windstar won't start
- CEL Can you get Codes without Scanner
- ABS Sensors - Part Number?
- More Brake Problems - Need HELP!
- 2001 Windstar climate control problem
- 2003 Windstar Intermittant Starting Problem
- 2000 Windstar Headlights on all the time
- Is there a detailed procedure for IMRC replacement?
- 99 tail light issue
- Brake problem
- Cruise Control
- Pinging and poor milage; no codes
- Headlights dimming...
- 98 Windstar GL 3.8 won't run
- bypassing abs on 96 windstar with a 3.0
- 97 Windstar Heater Core? Maybe?
- intyerior light take to long to extinguish
- 98 3.8 intake gasket
- 99 Windstar tranny
- 2002 Windstar LX Smokeing
- 98 3.8L IMRC Advice
- Regarding IMRC & Rear AC switch
- Experience with TransX or Trans Tune
- Considering donating a vehicle
- 2002 Windstar Heater Problem
- Carfax Request, Please
- code P1744
- Brake Light On - 95 Windstar
- 2001 windstar o/d won't disable
- 2001 windstar Water leak under the intake
- Oxygen Sensor Diagnostics and Specific complaint.
- Master cylinder resevoir filler cap
- are areostar and windstar engines the same?
- 2000 Windstar Stalling
- Hello fellow Ford owners
- 2000 winstar no high idle does not wantto run
- 99 windstar inner tie rod replacement
- 98 Winny, traction control light flashes??
- ABS 95 Windstar
- Irritating Turn signal issue on my 2001 Windstar
