View Full Version : Windstar
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29
  1. 95 Posessed lock switches? FYI
  2. 96 Windstar
  3. Magnaflow Ypipe part# 23353 - Anyone installed?
  4. Won't start, nothing obvious wrong, any suggestions?
  5. WTF?? videi ADS????
  6. 95 with a busted sway bar
  7. Windstar 98-2000 Transmission?
  8. yellow shift cable terminal lock
  9. 2000 Windstar suspension still mushy
  10. slightly OT - tech tip
  11. If your shopping for a GPS
  12. 2000 windstar power mirrior switch
  13. bottom rad hose 2000 3.8
  14. weak start
  15. field report: quickstrut,LCA,inner/outer tie rods, sway bar links
  16. 01 windstar "howling" noise (air)
  17. Drives itself up to 20mph until warm
  18. no spark for my windstar
  19. Defrost airflow door/diverter
  20. time quote for full suspension renew?
  21. Tranny slipping, long trip tomorrow-help!
  22. My p0420 code
  23. Shuddering on '01 Winstar with 90K miles
  24. Speedometer cable noise. Help please
  25. Code 171/174 question
  26. Code scanners/readers
  27. Rear Air on 01
  28. doing quickstruts Thursday, camber plate needed??
  29. Need Help replacing oil pump 03 windstar
  30. 1999 Windstar Camber alignment
  31. Sorry if I missed this......
  32. 2002 windstar hesitation-solved
  33. Cooling System Question
  34. 98 windstar 3.8l upper intake
  35. vacuum reading at intake manifold??
  36. ABS Brake Issue
  37. 5% Rock Auto discount....
  38. another coolant question 3.8 l
  39. Windstar Upper Engine - Photo Labled
  40. Belt Routing 2000 3.8 v-6
  41. Horrible Squeek and Missing Coolant
  42. bad vibration/shudder on takeoffs
  43. can i patch a hole in my cooling system?
  44. How do I change the head gasket on my 3.8L
  45. defrost, vent and floor vents stuck on vent
  46. 2001 Windstar Sport Transmission Questions
  47. Tranny slipping
  48. Oil Leaks - Help Please...
  49. Time to part it out
  50. 2000 Windstar Window molding
  51. 95 Windstar Is tranny shot?
  52. 2001 O/D button issue
  53. trans scanner tool?
  54. Exhaust Options - Catalytic Converter Ypipe and Exhaust pipe/muffler etc..
  55. holy crap, ABS Codes...........
  56. Difference in F78 and F88 tranny's
  57. A new problem, leaking somewhere
  58. 2002 winstar taillight problem
  59. Cleaning Upper & Lower Intake manifolds
  60. Cleaning lower & upper intake manifolds
  61. Try beat the infamous gasket again
  62. Windstar noise when moving from cold.
  63. Emissions Return Tube Part #
  64. Basic P1518 IMRC Questions - 1999 Windstar
  65. field report - ps flush 2000 3.8
  66. 2000 squeek/squall and stall...
  67. 1998 Ford Windstar IMRC - how many?
  68. Intermitten passenger side power sliding door
  69. Windstar Brake, ABS, and Trac Off Warning Light
  70. P0743 on 98 Windstar
  71. Winstar Vacuum Hiss / IMRC Question
  72. 99 windstar Shifting 4th problem TCC Help
  73. Code 171 Repair - Parts Question
  74. Transmission getting replaced
  75. spark knock....
  76. 98 windstar SEL lamp HELP!!
  77. Why are the door labels missing?
  78. Hesitation/Loss of Power
  79. teflon on brake pressure switch?
  80. How many 1995 Windstar folks out there?
  81. 98 Windstar Loss of Power / Hesitation
  82. need clarification
  83. trasmission fluid change
  84. Replace Dashboard Lamps
  85. Power Socket Fuses 96 Windstar
  86. Tranny or torque converter issues
  87. 1996 Ford Taurus LX Sedan 4D
  88. diy temporary alignment?
  89. steering problem
  90. possible parasitic drain source?
  91. help with vacuum line please
  92. code 1405
  93. Bad cat or not?
  94. traction control on sharp right tuns
  95. Where is homologation number on 2001 Windstar?
  96. need help with front end noise
  97. dashboard light bulb in a 1996 Ford Windstar GL?
  98. Rough Idle on Restart
  99. Moving Temp Guage and other problem?? Need Help!
  100. P0102- Bad MAF?!?!
  101. Intermittent Problem Starting
  102. best ball joint lub grease?
  103. Oh Crap!
  104. 2000 front caliper pins
  105. Shattered back glass-driving down hwy!
  106. Won't start after car wash! Fuse?
  107. 2000 3.8 Crank Position Problem???
  108. code po720
  109. 1997 to 2000 Windstar tranny
  110. Rack and Pinion replacement
  111. 96 Windstar engine miss under load
  112. Brake Pressure switch recall
  113. Ford Windstar Blown head gasket
  114. Did the P171/174 fix now rough idle
  115. Winding down noise
  116. 1998 Wheel bearing removal
  117. Problem with reverse
  118. Replacing turn signal/highbeam/wiper stick or lever
  119. Bell Housing Dowel-Pins
  120. P0301 – hesitation during rain - 2001
  121. Reman tranny & Rebuilt Engine Replacement.
  122. Rear main seal leak
  123. Anyone know what code 403 means?
  124. Rack- pressure valve,fluid questions
  125. tie rod boot clamps
  126. 2002 windstar loosing oil
  127. anyone use this scan/pc tool?
  128. tranny slipping..............????
  129. fuel pump problem
  130. New head gasket install
  131. Engine tries to stall after cooling fan cuts off
  132. 1998 Windstar Oil/Water in Throttle Body and Air Duct Hose
  133. Coolant Leak above Thermostat
  134. OBDII and FSM
  135. 2001 intermittent front wipers
  136. 95 Windstar oil leak.
  137. 2000 Front wheel bearing & hub - My Experience
  138. another "new bolt" thread
  139. 2002 Windstar hesitation during load
  140. Trans problem
  141. Battery Light Flashing at times.
  142. 96' Ford Windstar help needed!
  143. 95 Windstar temp gauge help
  144. speedo ?
  145. Convert water into fuel
  146. ABS Sensor compatibility
  147. headlight problem
  148. P0161 Downstream Oxygen sensor bank 2 HEATER circuit malfuntion
  149. is this the brake pressure switch?
  150. Electric Blend Door Actuator replacement
  151. 2000 gear shifter problem
  152. tranny cooler
  153. lower control arm - is my thinking ok?
  154. alarm lights
  155. Lots of work on my 2003
  156. Clunking Noise ??
  157. something better than alldatadiy.com?
  158. Rear Windshield Wiper Problems
  159. 2000 windstar defrost problems
  160. Performance Chip for Windstar?
  161. Intermittent Horn Failure
  162. windstar drum brakes
  163. 95 windstar waterpump
  164. FORD TSB for Spark Knock on Light Load / Acceleration
  165. Is this a blend door issue?
  166. EGR and IMRC
  167. doesnt overheat but temperature fluctuates radically
  168. 1995 Windstar won`t start
  169. New bolts necessary on 2000 hub assembly replacement?
  170. 2000 Axle / Spindle nut size 30mm or 29mm or 1-1/8?
  171. anyone replaced an inner tie rod?
  172. 2000 Ford Windstar 157K miles - 2000 to 2003 engine swap!!!
  173. anyone got pictures of trans drain plug?
  174. Broken hood latch cable
  175. P0302 cylinde #2 miss fire?????
  176. Brake Pressure Switch, What Now?
  177. 2001 Windstar Blend Door Access
  178. P/S Hose Blows off on '98 Windstar
  179. 1995 windstar fan problems
  180. front suspension suggestions needed
  181. A/C Clutch coil
  182. Brake Lights
  183. left front hub bearing
  184. please help me diagnose the ABS+Traction Control problem
  185. 98 Windstar no horn no cruise control
  186. Roarrr!!!!
  187. Strange Transmission problem -98 3.0
  188. Windstar fuse #9 and #16
  189. P1518 IMRC open
  190. Rough Idle when Cold
  191. tie rod - lower ball joint testing
  192. 2003 windstar rear liftgate problem
  193. 2001 Windstar-cooling system freeze out plug leaking
  194. Car starts but stops itself
  195. jerky, hesitation
  196. replacing oil and trans pan
  197. tranny not grabbin?
  198. 97 3.8l blew fuse #21
  199. 97 front blower relay
  200. Wet Weather Rough Idle
  201. Please help 95 3.8 Windstar coolant leak
  202. ABS light
  203. Problem with Remote Programming...
  204. Need help programing the keyless entry number pad located on the driver door.
  205. 2001 Windstar steering wheel stops turning 1/2 way through a turn.
  206. Please Help! 2001 Windstar Makes Clunking Noise
  207. 2001 Windstar (Deathstar) Rear Windsheild Wiper problems
  208. 2001 Windstar (Deathstar) No Front Heat, Rear Heat Working
  209. Help me pin point this rought idle...!
  210. Please Help!! Replaced Transmission and won't shift into OD
  211. Is this a hole?
  212. Performed p171/p174 code TSB but broke cruise control
  213. Brake pressure switch - '01 Windstar
  214. Replacing the cats
  215. 2001 SE - Outside Temp Going Crazy
  216. Power steering pump bad???
  217. Would like to say goobye to my good bye
  218. 2000 windstar deep engine knock
  219. engine misses only when loaded down
  220. oil change
  221. Rear Defrost Broken - Help Please
  222. 2001 Winstar - Valve Job?
  223. 2000 3.8, here's what I've had to do. You?
  224. Miss All Speeds
  225. electrical haywire and other problems
  226. missfiring engine
  227. noise when turning wheel
  228. Head Gasket blown, head cracked on 97 Windstar?
  229. Trouble identifying road noise
  230. Rear Climate control.. How dumb of me
  231. TRS Replacment 1995 Windstar
  232. 2000 Windstar hesitates on startup.
  233. My 2000 Tensioner & Idler pulley experience
  234. Cruise control
  235. 95 Windstar ABS Problem
  236. NO HEAT! 2000 Windstar with no front heat
  237. 96 o2 sensors can't get out
  238. 2002 Windstar Power Steering Pressure Switch
  239. Ford OD Transmission Maintenance & Auxiliary Cooler Installation
  240. Anyone rebuilt their 1999 or newer 3.8 Engine - Looking for a good rebuild kit
  241. 2002 Windstar Power Steering Switch
  242. 2001 windstar speedometer and abs light prob
  243. Finding heater core hoses on '98 windstar
  244. Code P0455 along with 171/174 Help please
  245. tire pressure
  246. 99 winstar tranny slippage
  247. Power steering leak 1997 windstar
  248. how to remove the vehicle speed sensor from a 2000 ford windstar
  249. clunk/jerk when shift the lever
  250. left head light
