View Full Version : Cavalier Problem Diagnosis
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19
  1. Cavalier head bolt torque specs
  2. 2003 Chevy Cav: Crazy Transmission Problem (I think)
  3. 2003 Cavalier Mysterious Engine Malfunction
  4. pontiac sunfire problem shooting
  5. Key does not work
  6. Sunfire 2000 2.4L Idle stays @ 4000rpm after replacing water outlet & coolant
  7. 2002 Cavalier 2.2 Sfi Idle problems/Missfire 105000 KMS on car
  8. 98 Cavalier won't start
  9. 05 Cavalier ECU swap, now have service theft sysem light on
  10. 1999 Cav z24 - Fuel/Evap Lines
  11. Electrical problem diagnosis
  12. Evap code p0442 cavalier 2005
  13. 02 2.2 ecotec stalling
  14. Sunfire 97 shifter cable location
  15. 04 AC Blows Warm
  16. Bad ignition switch locked tranny and key
  17. What to do...
  18. '96 Cav. Automatic Transmission Issues
  19. Cavalier won't turn over, good battery
  20. Chev Cavalier Possible Passlock Problem
  21. c101 wiring harness under battery tray
  22. 2000 Cavalier Intermittent Overheating
  23. Cavalier steering wheel horn switches
  24. Cavalier replacent power window motor doesn't work
  25. 96 Cavalier overheated now won't start
  26. 2003 Cavalier Power Window Problem
  27. Infamous Cavalier. cranks wont stay running
  28. Blower not getting power
  29. 97 Cavalier Low Beams are not working, please help!
  30. 98 Sunfire Brake pedal hits the floor
  31. PO340 code loosing my mind! Help!
  32. PCM reprogrammed?
  33. radio/wipers/blower all stopped working 98 Sunfire
  34. 98 Sunfire nightmare, soon to be scrapped!
  35. 05 Sunfire Manual Transmission CV Shaft seal problems.
  36. 93 Cavalier horn quit working
  37. Water leak coming in firewall 1993 Cavalier help?
  38. 96 Cavalier squealing noise
  39. 2004 cav trans indicater
  40. ABS light & Brakes
  41. 97 Pontiac Sunfire (NOT STARTING)
  42. Engine ticks allot when warm only
  43. motor mounts & flex pipe
  44. 1997 Chevy Cavalier 2.4 Automatic Idle Speed and Spark Plugs
  45. 02 chevy cavalier crank/no start
  46. 04 Cavalier Ecotec 2.2 DOHC ICM questions
  47. 1999 Sunfire "Bright White" looking for spray paint match
  48. Cavalier wont start. Help please!!!
  49. 2004 chevy cavalier coolant issue?
  50. no spark
  51. 2004 cavalier fuel pump
  52. 2004 Chevrolet Cavlier LS Electrical issue
  53. 89 cavalier cold/theft system
  54. '01 z24 Cavalier - Clutch Noise. Throw bearing?
  55. 02 Cavalier z24 Automatic, Idle Death
  56. 96 Cavalier, key stuck in ignition
  57. 2000 cav oil pressure switch oil leak
  58. 2002 cavalier Need help identifying problem please
  59. 01 Sunfire, 2.4 L, High RPM/Gear Change Problem
  60. 2001 cavalier annoying vibration
  61. Radiator Fan keeps blowing my cooling fan fuse. need help
  62. 99 Cav 2.4 Coil or Coil Housing Problem 3x in a row
  63. 2001 Sunfire, 2.4 L, Engine Shaking
  64. Need help with fuselink/fusible link 98 sunfire
  65. Diagnosis of problem with air conditioner / cooling fan
  66. Power loss 2.4L
  67. 03 Cavalier won't start
  68. 2005 Sunfire 2.2L Manual Transmission Won't Separate From Engine
  69. Security reset on 2002 Cavalier? Anyone know?
  70. '98 cavalier, runs ruff only in wet cond.
  71. Car will ONLY start while getting juice from another battery
  72. changed starter but still wont start!
  73. Knocking noise
  74. 2001 Rough idle, CEL and Trac light on
  75. '03 fuel pump?
  76. 200 sunfire - engine stalls out
  77. Sunfire sub frame
  78. Cavalier - ABS, Trac Off, and Service Wrench
  79. 1995 sunfire starting problem
  80. fuse
  81. 2002 cavalier ecotec overheating
  82. 1998 Pontiac Sunfire won't start!
  83. 03 Cavalier Theft System/Service lights and it now floods.
  84. 2005 Cavalier: New starter, new battery... No start!
  85. 02 cavalier coolant leak expansion tank
  86. 99 sunfire 2.2 Need to replace idler pulley
  87. battery Light on my sunfire manual 1995
  88. 2002 Sunfire: growling noises from transmission/axles
  89. 94 Cavalier RS 2.2 Reverse light problem
  90. 1994 Cavalier RS 3.1 MultiFunction
  91. 99 Sunfire - Transmission problem? Electrical problem?
  92. Z24 Ran out of gas and won't start
  93. 2001 chevy cavalier will not shift into 1st, 3rd, or 5th
  94. 2001 Cavalier
  95. 01 sunfire starter change
  96. 2002 Chevy Cavalier Coolant Bleeder Screw Broken
  97. 1998 cavalier 2.2 stalls @ stop
  98. 2002 Cavalier gets to high temp.
  99. 1996 sunfire 2.4L shifting problem 3rd to 4th gear
  100. Coolant escaping overflow tank
  101. 2003 Cavalier headlights very poor
  102. 2000 cavalier lose horsepower at +-40MPH
  103. 2002 2.2l OHV Coolant overflow?
  104. 2002 Z24 Cranks but won't start
  105. turn signal/reverse light fuse blows
  106. 2004 Pontiac Sunfire Airbag Light
  107. need some help with electrical problems
  108. 1999 2.2L emissions
  109. 96 Cavalier 2.2L - multiple issues
  110. 99 cavalier fuel filter replacement?
  111. 97 Sunfire 2.2 won't start after changing spark plug wires
  112. 2004 Sunfire wont shift into gear
  113. 2000 cavalier z24 fuel pump issues
  114. 98 Sunfire 2.2 won't start/has power/won't turn
  115. 89 Cavalier Cooling fans always on and eng wont start
  116. 99 Z24 5 Sp Problem! Help plz!!
  117. 2005 Cavalier Spraying Gas
  118. Ecotec 2.2 dead!
  119. Front wheel bearing replacement
  120. 96 tempature control hard to turn
  121. 2002 Cavalier leaking antifreeze from tube?
  122. 2.2 engine revs 1000-1500 rpm after plastic line poped off and replaced
  123. Oil pressure light and overheating
  124. Replaced tranny now air bag light stays on
  125. intermittent oil light
  126. Battery and/or Alternator problem diagnosis
  127. Pls help bleed a hydraulic clutch
  128. heater won't change
  129. 97 cav theft mode on cant get it off
  130. 04 cavalier stuck in reverse! PLEASE HELP ME!
  131. Old wagon Not running
  132. Sputtering issues
  133. Power loss after gas fill up and going through..
  134. Fan
  135. How can I tell if my 2001 Sunfire (Cavalier) has or had keyless entry?
  136. 2001 Z24 idle high
  137. 2000 cavalier
  138. 2000 cavalier idle problem
  139. My 96 Z2.4 all of a sudden sputters
  140. 92 Z24 power issue
  141. engine problems
  142. 98 sunfire 2.4 headlight switch got me stumped
  143. 2001 Cav 2.2 engine shaking issue
  144. 2005 starting issue
  145. Temp gauge works then quits
  146. Fuel pump relay
  147. '96 Cavalier Whining noise
  148. 98 cavalier 2.2 no power when accelerating and revs long through the gears.
  149. 86 Cavalier RS start & humming problems
  150. 02 Cavalier idle problem.
  151. Sweet toxic fumes (NOT coolant) - A/C condenser??
  152. 1997 Cavalier 2.2 Automatic No start & No power to ignition switch
  153. 97 2.2 theft system on and a bypass didnt work
  154. 2002 Cavalier Idle with air problem
  155. 2001 Cavalier: AC Problem
  156. 2001 Cavalier: Remote Keyless Entry Not Working
  157. 98 cavalier overheating
  158. 94 cav overheating
  159. sunfire stalls,no check engine light
  160. fuel problem
  161. '96 Sunfire 2.4 5sp will not start without starting fluid?
  162. 1997 Pontiac Sunfire 2.2 Automatic Fan will not come on.
  163. 1997 Pontiac Sunfire 2.2 Automatic
  164. 94 cavalier Idle problems
  165. 04 headrest removal still cant do it
  166. 04 door has play in it what do i do?
  167. 2003 chevy cavalier fuel pump
  168. 02 cavalier sputters and stalls
  169. Put SOME brake fluid in the power steering reservoir
  170. 97 cavalier, lost power while driving
  171. Could fuel filter be causing car to stall?
  172. 99 Cavalier wont start.. have tired everything
  173. Ignition Switch 94 Cavalier
  174. How to fix Exhaust Leak???
  175. 97 Theft System light on and i cant get off
  176. 97 2 new Cat's and still turning red hot. Help
  177. Fuel filter replacement on Chevy Cav 2.2L OHV
  178. Rarely starts, Gauges show zero - Please help!
  179. Vibration when braking
  180. 2002 SUNFIRE Firm Braking issue
  181. VSS Wire Location on a 98 Sunfire 2.4
  182. Cavalier clutch compatibility problem
  183. Popping sounds from front end
  184. 94 Cavalier RS 2.2 fuel to plugs problem>
  185. 99 2.2 3spd auto NO REVERSE
  186. Diagnosing A/C leak in 98 Cavalier
  187. A C sudden coolant discharge
  188. Overheating! Gah!!!
  189. 95 cavalier ran out of gas and now refuses to stay running unless you drive it as a manual
  190. 99 2.2 3spd auto. NO REVERSE GEAR
  191. 89 cavilier, dare ya to figure this out
  192. Squealing sound
  193. Headlight issue
  194. Slave cylinder leaking... again
  195. Speedometer stuck at 130 mph at all times after jump start
  196. O2 replacement - 2002 Cavalier
  197. Strange coolant leak..
  198. 92 Z24 timing troubles on crankshaft
  199. 2002 Cavalier finally running but with new problems. Please Help
  200. 02 cavalier will not start, passlock problem (disable?)
  201. 2002 Cavalier LS won't start
  202. 2002 Cavalier
  203. 97 cav idiot lights on
  204. Eletrical Problems
  205. 2000 Cavalier - ABS, Trac Off, and Service Wrench
  206. Z24 Fog Lamp not working
  207. Help, 1991 Chevy Cavalier doesn't start
  208. 05 sunfire oil leak
  209. Transmission problem + "ETS OFF" and "Check Engine" are ON
  210. 99 cavalier Drive axle question
  211. 1999 Cavalier Wheel bearing problem
  212. 97 2.2 Power steering line removal
  213. 2001 Shifting Problem
  214. 2001 2.2l cuts out with less 1/4 tank
  215. Intermitant wiper problems
  216. 89 cavalier bogging out and dying
  217. Valve adjustment
  218. installed a new radio and the theft system shutdown the car-
  219. '96 Z24 2.4 Is Eating Gas
  220. Changing fuel lines
  221. Cavalier Won't start?
  222. 2002 Cavalier 2.2 Low Coolant Light
  223. 2002 Cavalier 2.2 Low Coolant Light
  224. 2002 2.2 ecotec no start
  225. Oil light at idle when warm. Common in Cavalier & Sunfire
  226. RPM gauge shuttering
  227. 93 Cav 3.1 auto dies in gear
  228. 93 3.1L TCC Solinoid?
  229. Transmission Problem???! 94 Cavalier
  230. I think its an electrical problem? 93 cavalier
  231. hooking up starter motor on a 2.4L motor
  232. Keyless Remote Entry Replacement?
  233. 93 Cavalier RS Starting Trouble
  234. fuel & temp guages don't work
  235. 97 sunfire, stumbles at idle, then dies
  236. Timing Chain, or Spark plug or bad gas reason for no start?
  237. 97 sunfire 2.2L power loss and stall
  238. Electrical issue
  239. What needs to be replaced after a crash on 02 cavalier
  240. 99 cavalier flooding
  241. 2002 Cavalier Headlamp Problem
  242. 1999 Cav. 2.4 has miss or sumthin?
  243. 02 manual wont shift please help
  244. 1997 Cavalier, Are my brother's concerns legitimate?
  245. oil filler neck cap
  246. 2005 cavalier electrical issue
  247. 99 Cavalier Alternator
  248. 94 cav stalling under 30 mph
  249. 2003 cav stalling problems
  250. sputtering randomly while driving
