Chevrolet
Cavalier
> Cavalier Problem Diagnosis
View Full Version :
Pages :
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
Dim Headlights, Check Engine Light On
96 cavalier 2.2 weird no start problem
96 cavalier-no start/theft light still on?
left headlight
cav accelerates after releasing gas!
damn cavis
2004 Cavalier Shaking
2004 Cavalier Doesn't Like Gas
What The Hell?!!?!?!?
2003 Chevy Cavalier Error Codes
Transmission problem
odd stall out
96 Cavalier, problem with stalling, specific to warmer weather
Help with oil leak please
O2 sensor fix
no power steering!!!
2000 Sunfire service engine light come on.
Slight Auto-Transmission Leak
ECM problem - need help
Is it the gas
help with p0118 and p0335
Cavalier Transmission problem
2002 Chevrolet Cavalier Z24 oil leak
Engine Swap
Engine Swap
dark spark plugs
Re-doing headliner?
whistleing sound or whining sounds
engin knocking last night but now its not
98 Sunfire GT only has running lights!
Mystery sound
Noisy lifter?
Cavalier Evaporator
2002 Suifire P0300 misfire
03 Cavalier passenger side cv shaft problems
2001 cavalier wont start
'93 Cavalier with a sudden onset of running problems
Need help for ETS off light on in dash
Lower Control arm/Castle Nut Problem
'97 sunfire crank but no start
Diagram for fuse box on a 93 Cavalier
Assistance Needed (Heating)
99 Cavailer shakes and idles rough
Fogging Problem
Problems In The Brakes..help!!
93 2.2 with some problems
my pcm wiring harness got cut and corroded.
96 cavalier no start/theft light on
97 chevy cavalier transmission
Cavalier 2002 how to access headlamp socket?
Front end wobble
Helicoil failure
2004 Sunfire stumbles while throttling
Dash Cluster-Instrument panel -Guages
96 cavalier wiper issues...can't drive while squeegeeing..thanks
help adding subs to a monsoon system
2004 Cavalier Clicking from under dash
2002 Cavalier No Start/Run
Hard start stumble at idle
coolant leak
Cpmputer replacement.
Radio Swap
97 cavalier 2.2L tranny fluid leak
Removing the Catalytic Converter...
2004 Cavalier Fuel and RPM Gauges problem
Bad Altenator? NEED HELP!!!!
Theft System,can't get key out.
rear defrost problem
rpm and speed on dash not working
96 cav 2.4
HELP! with ABS
92 cavalier died
98 2.2 crank sensor wire (s)
2001 Cavalier - left front headlight problem/running light problem
Chevy blazer 2000
1994 cavalier wont start
SDM 2005 Cavalier
Daytime Running Lamps
91 chevy cavalier - engine siezed
Automatic Transmission-Couple Questions
burnt heat
95 Sunfire Parking Brake Light ..
04 cavalier driver side dim headlight
96 sunfire problems
96 sunfire problems
~HELP!!! 2000 2.2 cavalier oil pan removal????
Help!!!!!!!! Overheating 99 Cavalier!!!
Theft System Problem, new Radio 98 Sunfire
no heat and its freezing!
96 Sunfire Engine Light Is ON Will Drive but sometimes just stops!
hard braking
96 cav wont start
Need Help Asap
Need Help Asap
1996 -3t40 wire question
Rough Idle, ETC
2003 cavalier oil leak Helpppppppppp
98 sunfire evaporator core
Check Engine Light with code P1870
I need some help... Please everyone
Headlight Dimmed.
95 Cavalier DRL (Daytime Running Light) problem
ERLS Fuse Blowing - Caused by sound system?
My 97 baby is dying. Whats wrong with her?
Weird Strut Noise?
2.2L stumbles after warmup
2001 Pontiac sunfire body control module help
Washer Fluid Hose Size?
where's my horn located
2001 sunfire tranny troubles
Sound System...car being funky
91 Cav power steering hoses
99 Cavalier hesitating
How to replace ECM ?
2003 Cavalier, keyless entry problem
Electrical Problems Galore
Aftermarket radio
1998 Cavalier blower motor,A/C ,Rear Def. not working anymore.Help.
Service Light?
94 cavy idles rough when cold
p1133 code for a cavalier
96 cavalier wipers and radio wont work
97 cavalier z24- heater fan?
loss of power brakes and abs????
97 cavalier overheated and won't start
97 cav motor mounts
Bent A frame
replacing fuel injector in 1997 cavalier
1999 Cavalier 2.2l Power Steering Bypass?
Sunfire cranks no start
Thermostat Cavalier 2004
New tires, now a bad wobble in front end
no oil pressure
I need some help with my 98 Cavalier...
Power loss
Changing spark plug wires
Low beam out on driver's side
Cool Air Blows Out When I Idle
97 Cavalier, will not start. PLEASE HELP!
97 Cav 2.2 stumble - rough idle
Have No Dash Lights! Please Help.
99 cav. can't get the dash board off
oil pump balance shaft
Stalling again!!!
99 Cavalier, 2.2 Valve Cover Gasket
97 Sunfire, Will NOT move!
gas tank/ door problem
2000 cavalier - A/C seized
04 cavalier grinding on pass front
Coil pack
2000 Cavalier dash prob
engine hesitation
'03 Sunfire Headlight Problem Solution
1997 Sunfire 2.2L OHV starting problems
Trac Off Light
1996cav/2000sunfire
90 Cavalier Dies when warm Please read
Please help! problem connecting to obd2 port on 1995 cavalier
99 Cavalier, broken Fuel filter Quck-Disconnect
Please Help. Ets Off Problem No One Can Fix!!
wiper problem
Problem with my car..Pls Help
98 Intake Removal
Looking for help with trunk (and another Q)
94 cavalier problem help me
97 Cavalier Speed Sensor
misfire question
Running Lean?
2002 Chevrolet Cavalier drivers side headlight bulb problem
Unknown Dash light
Ahhhh!! Wind Noise! So Annoying!
sunfire heater fan problem
2003 Cavalier Instrument Panel Failing
no fire and no spark seems like when the theft system light is on
Blown tranny or broken axle???
2002 Chevrolet Cavalier drivers side Headlamp problem
Sunfire 2000 Keyless entry faillure
98 cavalier transmission
tempture gauge
2001 cavalier tranny or clutch problem??
Crank Sensor 1999 Cavalier???
1997 2.4 (T) rebuild priming
E-Brake n Center council help please!!!
Dash Lights And Blinkers Won't Work
interesting sound on J-Body
1999 sunfire how to remove power steering pump
Autostart install?!?!?!
Brakes Lock Up, I can't figure it out!
2002 manual won't accept gas
1997 Cavalier manual, stuck in 3rd???
Alternator??? Desperate Help!
Door Locks Don't Work in the Cold
Mis-Fire
clock in radio stays on
IAT sensor- clunk while shifting
cavalier hub bearing
starting problem
97 2.4L Bad idle Need enlightenment
cooling
steering wheel bearing
2002 Chevrolet Cavalier Headlamp Assembly bulb replacement
98 z24 my thermostat doesnt fit
2003 weird no start problem
How do i pull trouble codes for '95 cavalier?
97 sunfire ac problem
I have a 96 Chevy Cavalier that is overheating.
please help this mechanic 2.2 p0300
please help mechanic 97 2.2 p0300
2004 cav stick coupe
HELP-DESPERATE - Used 1996 Cavalier
1997 Cavalier 2.2L P300 - random Multiple Cylinder misfire
rad doesn't get warm
Stupid Cavalier
odometer not lighting up
1996 2.2 Cavalier How to set the gears back in time on the timing chain
temp guage extreme right 2003 Cavalier Z24
Help with Cavalier Transmission
Help!!!
How do you get a shift cable out?
Wiper in Up Position
Anyone needing to pull Cv Shafts ( check here)
03 cavalier won't start
'97 Sunfire Stalling on accel (w/ fault codes)
2004 Cavalier P0455 code - engine revving
01 automatic transmission shifting problems
96' Cavalier A/c runs slow at stop but then speeds up when driving?
Problem with Check Engine Light
Spark Plugs?
oil pressure is at 550
headlights dim
92 cavilier problem
no drl, no low beams, ticking noise fuse box
Weird problem, need some help!
cavalier please help
2000 2.4L problem!!!
Please help ME!!!!!
Help with '96 Cavalier DRL relay
96 z24 cavalier with no head lights
Windshield Wiper Woes
97 Cavalier idle problem
94 cav won't start
nuetral safety switch on a 92 cavy
Whats wrong??
coil packs
New clutch won't engage
2003 engine reving.rpm/ sputtering problems
Help with failed emissions
Fuel gauge
98 Cavalier 2.2L overcooling
