Honda
Civic | CRX
> '01-'05 Civic
View Full Version :
'01-'05 Civic
Pages :
1
2
3
Moving my car without towing it
Mysterious Battery Light PLEASE HELP
05 Civic COUPE Passenger Window Will not Go Down
Only starts when it is hot outside
'03 Civic takes time to start, runs and idles fine
2003 Civic will not start after battery change
2003 Civic EX Intermitten Stalling
'01 LX 1.7L > Cam Plug Replacement
2003 Civic LX A/C Compressor not working
Timing belt
no pressure in brakes after bleeding
Honda Civic 2005 BALL JOINTS
2001 Honda Civic Ferio steering problem
Team Honda
Screeching noise coming from engine bay
Clunk sound when turning and backing up
is this much engine movement normal?
2002 civic lx keyless entry?
civic si 2001 hardcore electric problem
How do I check my oxygen sensor???
A/c works fine at Lower speeds
oil leak name this part
Is this the sound of a dead battery?
2003 Honda Civic SI Coupe doesnt exist???
Deciding where to buy Air/Fuel Ratio Sensor
2004 honda civic lx
Wheel bearings noisey after only a year
2005 Honda Civic EX Special Edition Help
Honda Civic-NEED HELP
2005 Honda Civic Identification
Honda civic 93 Making it Look Good
Vibration damper bolt Stuck Help Suggestions needed
smoother gearshift
Car Damage
Radio fm modulator
My Civic is Sputtering
2004 Air Conditioner Compressor
a/c and power belts replaced
2001 Civic Brake indicator stays on
My Civic Won't Start
4-cylinder tuneup
Car only starts with OBD2 scanner attached???
04 Civic Rumble
Current dipping in car
03 civic no electrical power
A/C died
Halo projectors
Is the price reasonable for this 2004 Civic?
05 Civic Coolant flows to overflow, doesn't come back
Flashing Green Key Dash Light
02 civic transmission question
04 Civic - doesn't blow hot air unless its moving
transmission problems, please help!
DRL not working
Where to buy trunk lip spoiler?
2004 Honda Civic Vibration when starting to move
01 lx auto removing or disabling after market alarm?
Cruise Control Downhill 'bumping'
Glue for headliner cloth??
SRS light code 9-3 cheapo fix
01 Civic A/C Problems
AFT fluid in coolant issue
Buying a used 2004/2005 Honda Civic Coupe (Help?)
2005 Hybrid with recurrent engine/IMA lights
2003 Civic Intermittent High Idle???
battery problem. plz help!!!
Civic ferio 2004
Airbag light stays on
need help with seatbelts
Beyond frustration with sensor codes
apply brake u get great vibrations
k&n air intake filter cleaner?
2002 Civic Coupe Steering Problem
2002 Civic Very Strange Noise
newbie timing belt question
05' civic questions
2004 Honda Civic Ex Head light flicker problem
need 2001 civic engine removal walk thru
2001 civic turn signal problem
Flashing Green Key
2004 Civic LX alternator seized
Need new front brake pads and rotors
AC/Heater blower not working?
'04 Civic with head gasket issue
Problems with Acceleration and now Power Steering
01 Civic Automatic Transmission Shifts like...?
Srs
01 civic power locks
03 swap question
Soaked in the flood
Engine Block swap B17A2 and B17A1
2004 Civic EX wont' start
2002 Honda Civic Si 1.7L
What's that box BEFORE the Air Filter holder?
What's that Box BEFORE the Air-filter?
Blue Flashing LED on the left side of the dashboard
2nd gear pop-out issue
Is this used 2002 Civic a good deal?
2001 Civic EX Advice
03 ex overheating issues
cooling fans coming on only when A/C is turned on.
2003 civic si?????
01 ex
2002 civic hood latch won't release
Consistent surging
New Guy with a Civic
Shock/Strut 2002 Civic
The Best PM's for your Honda!
belt squeal 2001 2 door civic
2002 Civic sedan wiring diagram
2003 civic maintenance light
failed transmission survey HERE NOW!
repairs times 01 Honda Civic 1.7 MFI auto
common issues 01 Honda Civic 1.7 MFI auto
01 5-speed vs. 02 5-speed transmission
Brake Job
'04 civic ex shakes when shifting
Possible Fuel pump/Filter
Sound from brakes. My car is moaning.
My 2001 Honda Civic EX is making me sick
Headlight Issue!
01' LX Transmossion not shifting... P0730
manual trans bulletin from honda
04 Civic Dx replacing dash lights ??
01 Manual Trans Bearing Noise
2002 Honda Civic creaking noise
manual trans clutch removal instructions
HX and EX difference
03 Civic - clicking sound from passenger side engine transmission area
Repair manual?
Blew out a shock on a pothole.
transmission model
2003 Honda Civic
05 Civic disc brake pad removal problems
'01 Honda Civic 1.7L Intake Manifold
01 honda, help a lady out?
02 won't move
body kits for mk7 civic
Honda Civic New vs. Used
Figured out the problem, now I need the part
01 Civic LX 1000 RPM Drop at Highway Speeds
Removing RS symbol on 01 grill
05 Civic Ex, Camshaft Position Sensor
Need Help Finding Cps (camshaft Positioning Sensor)
ANZO Projector Headlight Help (2004 Civic Si)
installing a HOD or HHO system and need map sensor info
droping rpm
changing gear shift knob
OBD II Codes
Is it possible to overfill a gas tank??
Planning to get '04 Civic
honda civic 04 lx 2 door
Fuel Air Metering
2005 Honda Civic Stock Stereo sound goes in and out
01 Civic with no Dash / instrument lights
Transmission problems.. help
Door won't open from the outside
Thoughts On Car Bras
how do i reset timing
03 Hybrid clunk
p0301?
Advice/Information on Tachometer/Guages
04' Hybrid Gas Milage
03 Hybrid
Civic 4 Sale
01 Motor Mounts
H22 in a EM2
Manual shifter issues..
New to civics...
rear window shelf
shutting off randomly? power steering also...
pcv valve location
smelly stuff in cabin
Heating and A/C blower?
Feel dumb but can't find my block heater
03 Honda Civic EX
DRL relay noise.
[URGENT] - '01 Civic lost and Axel Seal and now...
new to imports
When to replace brakepads
Exhaust? Whats the diff between catback
wits end with 2004 honda civic 1.7 4 dr
2001 Honda Civiv EX Engine stalls
'03 Civic EX Coolant smell, Temp rising
Jdmes1civic
Civic autostart installation help
parts
SRS light reset
Help! How to replace 01 Civic coupe window glass driver side
Alternator/Battery/Gauge issues
2001 Honda Civic radiator fan motor
Heating...very odd....
AC/Blower Not Working =(
Replacing the a/c compressor on a 03 Honda Civic SI?
01 civic lx p1362 missfire
My old friends need help
with these tires fit?
HELP!! SRS light!!!
02 civic EX control arm
Civic radio code
04 Civic SI A/C Condenser location.
Help!!! How Do I install Halo Projector Lights on a 2001 Honda Civic?
Cherry Bomb?
Drums Won't Come Off
Loud drive?
Which is better
Is this road trip a good idea
2001 Civic HX won't pass emissions
Seeking Advice on "Recommendations" from the Dealer
Release for Gas Cover not working
Want your opinions
AC compressor
05 Civic tranny not shifting...
SES Light
V-tech Controllers Help
Keyless Help-'05 Civic
Flushing power steering fluid
'05 civic
'99 Civic SI rims -- Same bolt pattern as '01 Civic EX?
Door key wont turn
05-06 Civic Manual Vs 04 Impala Ls Auto
03 Civic Throttle Position Sensor
Help me out please
Help me out please
Anyone tried the Nitrod Performance Meter....
Intake Manifolds
civic question
Performance Chip
CAI/air by-pass valve/throttle spacer
i need to tune up my civic lx 2001
02 Civic Suspension
2003 Shift Light out
Crazy Problem... Shifting problems!
70k service for 2002 Si
01 DX quetions
Does anyone know of any good shops in Central Jersey?
Installing a turbo kit...
03 A/C install
full suspension swap DIY
Couple more noob ?'s
cold air intake
Noob has question about VTEC
Spark Plugs - Which Ones Do You Run/Like?
Steering problem w/'02 Civic HB SI
Please Help
Is this a good deal ('02 Civic Si Hatchback)
turbo, how many psi?
02 civic shop/mechanic problems
new underdrive pulley, what belt?
