View Full Version : Dakota
- 1998 Dodge Dakota won't start in PARK, starts in REVERSE
- Location of ABS plugs in 1998 Dodge Dakota
- ABS scanner for a Dodge Dakota
- Does this repair cost seem reasonable?
- 4.7magnum
- fuel pump wiring issues '94
- Power steering leak question
- Dakota engine spit and sputter question
- 2001 Dakota 4.7 4x4 starter socket size
- '94 Dodge Dakota (4x4 pickup) wiper motor delay
- Cam shaft position sensor question
- Should I use dialectric grease in this situation
- Torque question
- Where is my oil going?
- Power Steering Fluid question
- 2010 D.D. extended cab 4x2 ST
- 2004 Dakota Parking Brake
- 92 Dodge Dakota No Fuel Pressure
- Doodge dacota 2003
- 2003 dodge Dakota 4.7 liter knocking/ticking
- Check Engine light question
- Loose steering in rack an pinion
- Headlights Flickering? Dome light flickering? It's the CTM
- electrical issues
- Engine code P0442 question
- Read brakes
- Dakota Purchase
- idle problum
- spark plug issue/difficult
- Dash lights flicker off and on
- Spare Tire Winch
- 92 Dakota Fuel Line Quick Disconnect
- power mirrors
- 1990 dakota 4cyl crankshaft timing belt sprocket removal
- 2001 4x4 dakota stop runnng
- 2000 dakota speakers
- 2004 Dodge Dakota Orifice Tube Location?
- 2001 Dakota Steering Gear
- lights flicker on my 2001 dodge dakota sport
- 45rfe solenoid pack
- 2002 4WD rear shackle removal??
- dodge dakota 2.5L exhaust manifolds cherry red
- 1992 Dakota Engine Shutdown
- Fog Lights not working 2002 Dodge Dakota SLT 4.7 L 2wd
- '93 3.9 Low Rumble from Engine
- REMOTE START question
- Oil pressure gauge question
- Fuel injection ticking sound
- Do I need to remove tranny fluid?
- Hesitant to change tranny fluid
- How do I access the license plate bulb
- Torx size question
- Can K&N air filters be cleaned and reused?
- 2001 Dakota Valve tapping noise
- Super clean 95 Dakota. Need your help deciding.
- 2001 Dodge Dakota Sport
- "87 Dakota headlight relay location
- Transmission problem
- 97 dodge dakota slt
- '97 Dakota Daytime Running Light issue
- 1991 Dakota 2.5 will not stay running
- '97 Dakota coolant leak search
- Object in the gas tank.
- Engine Idles at 2K RPM
- heater no air coming out
- '96 Dakota brake question.
- 2000 Dakota AC Locked Up
- Help!!! engine problems
- 2001 Dodge Dakota
- 2001 Dakota 3.9 ECT error P0118
- No Start Dakota
- voltage ? 95 Dakota
- 97 Dakota v6, intermittent skip
- 96 Dak. w/ 2.5 OHV idling poorly
- Bad rumble in right front
- 2 Problems with 2003 Dakota
- 5.9L fuel rail bleed valve
- looking for 1 98-02 Dakota RT Center Hub Cap
- 2005 Dodge Dakota SLT Squeaky Noise
- 2000 dakota check guages light = engine dies
- 02 Dakota R/T parts
- 4.7 Starting Issues
- turn signal problem
- 2000 Dakota, how do I remove the battery tray?
- 95 dakota 318 oil pressure guage?
- 2004 Dakota with 4.7
- 95 dakota 5.2l runs fine untill you put it in gear
- 98 dakota gas gauge
- Tune Up
- 1989 dakota Sport V6 Wont Start
- 1998 Dakota Engine Swap
- 2005 Pitman Arm
- 03 dakota, 3.9-v6, fast flashers
- 2000 4.7L V8 Overheating...again
- 2001 dodge dakota 4 cyl. overheating
- Gear Indicator
- 2003 Dodge Dakota 3.9-v6 loss of power
- 2001 dakota 4x4 4.7
- Dodge Dakota Towing Package
- 2001 dakota "lights flicker"
- Help With widow
- 2002 Dakota sport 3.9 IDLE issues
- strange knock 91 Dakota 2.5l
- Someone plz Help ran out of options
- 2003 Dakota check engine problem
- window track 2001
- 92 Dakota 3.9L auto
- 94 dakota 2.5L crank sensor
- 94 Dakota auto shift issues
- 97 dakota misfires surges and stalls
- Power steering pressure switch
- 01 dakota sport high beams do turn off
- Crack in rear housing
- Manual Steering Rack (90 Dakota)
- Torque Specs
- self bleeding clutch
- ac pulley bearings 4.7l 2002 Dodge Dakota
- Rub from the rear
- Bleeding brakes with scan tool
- A/C Issue - Vacuum?
- 2004 dodge dakota
- 96 dakota stuck in first
- head and brake lights
- Value of new motor
- First Post.....HELP!
- My ailing Dakota
- Air Conditioning issues
- 1989 With Automatic will not downshift!
- pdf manual
- Trouble installing head unit
- My Dakota
- Check out this Video Dakota RT Donut!!!
- overdrive problem help
- Air Conditioner Problems
- idea on what these parts cost??
- common problems
- Where is the OBD 1 connector??
- 1994 Dodge Dakota???
- 1994 Dodge Dakota Help???
- Dodge Dakota 2001 Misfire on Cylinder 1...
- 01 Dakota barely running
- Oil light On
- 95 dodge dakota reverse tail light
- How would one go about replacing the antenna cable?
- Burnt Plastic Smell?
- Is it a bad belt
- Transmision Issues
- '97 Dakota 3.9L problematic stalling issue
- 02 Dakota 42RE transmission
- Sliding rear window question
- what is biggest tire
- 98 Dakota single cylinder misfire following overheating
- 89 Dodge Dekota low end knock/oil pump!!!
- 2001 Dakota Temperature won't change
- 97 dakota heater issue
- 01, 02, 03 Dakota Brakes
- 2000 4.7 4x4 - Squealing sound when cold
- wow whata lemon! 93 dakota
- 2000 3.9L issues when cold
- 91 Dakota starts but quits, won't start until cool
- 94 Dakota 2.5 broken cam shafts????
- 93 Dakota stuck at 2000rpm
- 1998 5.2l p0320
- '97 Dakota 4x4 v-6 axle nut size?
- 97 dakota brake & abs lights only after heater core changed
- 97 Dakota rear end pivots up & down
- Check Engine Light Again
- 99 Dakota heater issue...
- Need help with 4.7L -2000 dak
- 90 dakota sport with 87 engine swap!!
- 87 dakota, from headache to hopeful
- 1997 Dodge Dakota Lights
- 2001 3.9 intake backfire
- 95 Dodge dakota, 3.9 V6 two weel drive, Failed NOX, to high
- 00 Dakota - MIL & Vibration
- 2001 dakota mpg?
- 1997 model goes from overdrive to neutral
- Dakota transmission won't budge
- Rearview Mirror
- dakota engine swap
- 91 dakota sport with 2.5
- 2000 dakota coolant flush
- 2003 Dodge Dakota Air Conditioner wire.
- 1993 dakota transmission
- 2003 Dakota 4.7L Quad electrical issues
- 2000 dodge smokes,antifreeze smell
- 1996 dakota /trans
- 2001 dakota rpm's surging
- Need serious help with Dodge Dakota
- MPG of 93 Dakota 5.2 Magnum w/MSD Ignition
- miles
- 93 dakota basic performance enhancements
- 2001 Dakota Power
- 95 Dak Sport blowing fuse
- Check Valve
- 1995 Dakota trouble code 12
- Please help Dakota driveshaft
- 95 Dakota hard starting when warm up
- 1998 dakota 4x4 3.9slt
- Couple or same issue 97 Dakota, hesitation when running
- 00 Dakota O2 sensor
- 2007 Dakota Engine cut out
- Please Help 1997 Dakota Engine wiring diagram
- transfer case swap
- Horsepower chips for 2000 Dakota
- 02 dakota trans problems
- 03 Dakoter coolant
- 93 Dakota needs throwout bearing.
- Eng light comes on,runs fine
- A/C cycles too much?
- 1989 Dakota Transmission issues (lockup/OD)
- flooding? acting odd
- 2000 AC Problems
- 2001 Headlight problem
- 99 Dakota 3.9 Posi Help
- 1991 Dakota won't crank
- dodge dakota 2002 4.7 auto
- 89 Dakota High intermittent Idle
- 1993 Dodge Dakota extended cab
- Dakota Fog Light No Power
- 2000 Dakota AC Problem
- 2005 Fuel Pump 4.7 eng
- 2002 dodge dakota 2wD 4.7 auto 130xxx miles
- new member 97 dakota wont start
- 92 dakota 2.5 no spark
- 99 dakota 5.2 swap help
- '97 Dakota crank sensor location
- 2004 dogde dakota
- ball joint or tie-rod end?
- door problem
- 93 dakota outo overdrive problems
- 95 dakota 4x4 stalling when stopping
- Engine knock when cold
- 93' dakota no start when cold
- 05 Dakota Wont Start Help
- Front End "Squeek" 07 quad cab V6
- Manual shift problem
- transmission fluid leak help??
- radiator transmission line fittings leaking.
- Truck spits, sputters, backfires
- 89 Dakota low oil pressure
- engine loud and knocks/pings after car wash
- Adding Power Steering
- 01 Dakota Remote Start Problem
- dakota breaks
- 2001 Dakota Quad Cab Check Engine Lighg
- 89 dakota no start
- Supercharger for 06 Dakota 3.7L
- '99 Dakota 4x engagement problem
- 1991 dodge dakota v6 HELP!!!!!!!!
