View Full Version : Dakota
Pages : 1 2 3 4 5 [6] 7
  1. 2000 dakota Dash problems
  2. 2000 Interior Illumination
  3. 89' will not go faster then 70mph plz help!
  4. '88 4 speed tranny problems.
  5. 2001 Dodge Dakota Sport PROBLEM
  6. steering tierod adjustment sleeve
  7. UPGRADES performance,interior, eterior
  8. anti lock breaks light
  9. 94 dodge dakota engine swap
  10. Timing Chain Cover Water Leak
  11. 1998 Dodge Dakota Tow Capacity ????
  12. 00 4.7 quad, power steering loses power at low rpm
  13. 1993 v6 2wd won't start
  14. '92 Dakota stuttering at highway speeds
  15. Duel Exhast
  16. dakota upgrades?
  17. O2 P0141 & P0161 faults
  18. 2000 4.7 Dakota Stalls/Stumbles
  19. Dakota Sport engine miss when weather is cold
  20. 2000 Dakota Slipping 1st gear
  21. Fuel Probs
  22. 04 Radio wiring
  23. Water Leaking
  24. Dakota stalling after 15 min
  25. 97 Dakota 3.9 engine begin to stall
  26. '98 dakota rearend swap? Help
  27. 93 3.9 LE blower moter fuse or...?
  28. brakes?
  29. 98 hard shift into OD.
  30. 95 Dodge Dakota
  31. 1999 dodge dakoto sounds like a disel when idling
  32. 1999 dakota will not start
  33. '93 Heater Core
  34. 1989 Dakota V6 No Oil Pressure
  35. 1992 dodge dakota transmission
  36. how to clear engine codes
  37. 99 dakota intermittent 4-wheel drive
  38. leaky injectors on tbi
  39. 97 Dakota electrical problem
  40. Dads Dakota
  41. AC Bypass
  42. Dodge Dakota Starting Problems
  43. Oh no the tranny
  44. 92 Dakata with poor breaks
  45. 94 dakota 3.9 v-6
  46. FS:Dakota 97-04 Car Cover ClubCab
  47. 2002 RC Front Spoiler ?
  48. 2002 RC Front Spoiler ?
  49. 99 Dakota turn signal relay problem...
  50. 2002 window crank
  51. uh oh
  52. gotta luv lsd
  53. dodge dakota 97 water pump
  54. 1999 Dodge Dakota
  55. stereo removal
  56. No P/S to P/S
  57. 02 dakota, headlight out, a/c prob
  58. 1999 Dakota Sport
  59. Wiper motor
  60. thinking of buying
  61. 93 dakota 2.5L problems
  62. 2.2 for a 2.6 out of a minivan
  63. 92 Dakota, Runs rough when cold
  64. hard to start in morning
  65. Dakota Overheating V6
  66. Starter motor on '89...............
  67. Hard to Start
  68. Dakota Sport with a 5.9L engine? Why?
  69. cd player
  70. 99 Dakota 3.9 surging problem?
  71. Dodge Dakota wont start
  72. 87 Dakota quits running
  73. Exhaust "humming"
  74. 95 Dodge Dakota Won't start, Help!!!
  75. 94 Dakota electrical problem
  76. terrible brakes
  77. 4x4 doesn't respond
  78. Dakota Transmission squeel
  79. fuel guage malfunction
  80. 94 Dakota 3.9 Fuel problem
  81. 1999 3.9L Engine noise/Braking ?
  82. engine ticking , whining noise 2003 dodge dakota
  83. stampede
  84. timing belt diagram
  85. performance chip
  86. trouble code
  87. '92 Dakota won't start
  88. 96 3.9L Fuel Pump Problem
  89. 93 Dakota shakes!!! HELP
  90. 1994 dakota exaust manifold
  91. Steering problems
  92. auto shutdown relay
  93. I am in serious need of help
  94. how much can the dakota tow?
  95. Dodge Dakota 2003 4.7l v-8 - Where can I get an ECU upgrade?
  96. important question
  97. dodge dakota won't start
  98. 94 dodge
  99. Truck Tool Boxes
  100. 94ish model dakota
  101. Fuel Pressure Regulator for a 98 Dakota V6
  102. dodge daykota
  103. broken doors
  104. 3.9 rattle
  105. 2000 Dakota Bolt Problem
  106. 1989 dodge dakota heater/ a/c
  107. New Tires
  108. 94 dakota 2.5l truck doesnt start
  109. 01 quad cab - mysteriously quits at stop sign
  110. Ok, new to this forum
  111. no heat in 97 dakota
  112. 2001 Dakota Stuck In Low 4x4
  113. Help! Stranded broke college kid tryin to get home for Xmas '94.... oil problem.
  114. Service manuals
  115. 2000 Dakota won't start
  116. Power locks...location of actuators..Help
  117. ABS failure?
  118. 2001 heater core question
  119. First Dodge, looking for info 2002 stx
  120. Speaker Removal
  121. Dakota 200 wont start
  122. Damn you dakota bolt pattern...
  123. how much???
  124. Shaved tailgate and custom bumper
  125. how much?
  126. Ssrt?
  127. 5.2Lv8 Dodge dakota stalling in drive
  128. Thinking of buying
  129. 4 Hi Hesitates
  130. Lighting Problem
  131. Interior Lights
  132. Dakota + Ivan = Trouble
  133. Instrument panel backlight intermittent
  134. Dakota 3.9L...Looking for help
  135. 87 dakota bench to buckets????????????
  136. 98 Dakota idling problem solved - for now
  137. 2002 Dakota Blower Motor trouble
  138. Headlights go out...
  139. 92 dakota not starting
  140. 96 dakota tranny woes
  141. engine swap for 95 ?
  142. buzzing auto door locks
  143. 98 Dakota won't start
  144. 98 Codes
  145. '99 Dakota V6 Coolant/Heating Problems
  146. Changing spark plugs?????
  147. Heavily considering an 01/02 Dakota
  148. 2002 Dakota 2 questions
  149. HEEEEELLLPPP 93 Dakota 3.9 Magnum Can`t start it
  150. Battery slowly losing charge.....................
  151. Spark Knock - '94 Dakota
  152. Starter motor problem?..........
  153. 89 no start
  154. engine stalls when warm
  155. 2001 Dakota Central Timer Problem
  156. lookin for an R/T
  157. Transmission problem
  158. 2001 Dakota dropped dead
  159. Lights
  160. dakota no fuel
  161. dakota wont start need help asap please!!!!
  162. did dodge make a 4x4 5.9l dakota 97-04?
  163. exhaust
  164. 22" rims
  165. 91 Dakota
  166. i got a 90 dodge dakota i think i have trans problem
  167. 93 dakota problem
  168. fuel smell out of exhaust
  169. Tranny
  170. 1997 Dakota Possible Tranny problem?
  171. 1990 3.9L Motor Swap
  172. Differental fluid
  173. 2001 dakota comp help
  174. ac/heater control
  175. hard starting when cold
  176. power door locks
  177. ABS Control Mod: need help from the experts...
  178. turn signals
  179. Explain Sport +??
  180. 97 Dakota Wont start
  181. 93 5.2 computer ?
  182. '93 Dodge Dakota, 5.2 Magnum, Hard to start when hot.
  183. replaceing clutch
  184. looking for performance parts
  185. Any advice for getting to the factory deck
  186. 03 dakota cuts out at 95 mph
  187. 03 dakota with air bag light on
  188. Brake Rotors
  189. Idling Problems with 89 Dakota
  190. voltage regulator in 1989 3.9 V-6
  191. surging
  192. Keyless entry remotes
  193. 93' Dakota V6 Please Help
  194. 99 Dakota starts hard when it rains
  195. Grab this deal
  196. Can I use these tires on my 2002 Dakota?
  197. No or very little heat
  198. max speed for 02
  199. Coolant leaking from passenger compartment on '04 Dakota
  200. Rattle at 2000 RPM
  201. 2000 Dodge Dakota loses power and skips
  202. Driver Side Power Window Repair
  203. 2000 dakota abs light
  204. 93 dakota fan fell off!
  205. My Dodge dakota Review (2002 4.7 4x4 Club cab sport Plus)
  206. 5.2 Ignition timming
  207. Oil Change
  208. ground effects?
  209. '98 Dakota leaks in rain
  210. 93 Dakota V6 Running Hot
  211. Where can i get Valve covers for a 94 3.9L?
  212. 93 dakota 3.9 magnum wont start
  213. 99 dodge dakota 4x4 problem
  214. Engine Replacement
  215. 93 Dakota suddenly loud. Help!
  216. 95 4 cyl dakota flips out once a week, dunno
  217. My 92' Dakota dosen't get spark??? HELP!!!!!
  218. Magnaflow Exhaust is looking for a So Cal 2004 Dakota RC/SB for Prototyping
  219. Stalling hot - is mechanic right? Swap ECM?
  220. Dakota in Canada
  221. Spark Knock
  222. 93 dakota wont start
  223. Engine Pinging after backfire
  224. 95 3.9 wont start
  225. Rough Idel
  226. Leaking tranny fluid
  227. cabin air drops out when eccelerating whats the fix?
  228. Drivetrain noise
  229. Please Help!, Flashing Headlights
  230. Dakota Overheating
  231. what is a dakota?!
  232. 00' Dakota: Whats the best Air Intake?
  233. 95 Dakota A/C & cooling problem
  234. Dash Kit
  235. transmission line removal
  236. mysterious charging problem!!
  237. What to look for in buying a used R/T? and where can he go to talk to owners?
  238. peice of snap ring? found in transmission pan
  239. No Spark 94 2wd Dakota 3.9
  240. 2000 Dakota overheating
  241. Dakota Differential Need answer ASAP
  242. Cutting out
  243. looking for some chrome wheels for my 98 dakota
  244. '04 quad cab 4x4
  245. Oil Warning Light
  246. Manual to power seat upgrade
  247. over heating problem please help
  248. What do you think of this 01 sport
  249. blower motor not working
  250. sub box
