Mitsubishi
> Eclipse 2000+
View Full Version :
Eclipse 2000+
Pages :
1
2
3
4
5
6
7
8
NEED HELP, Fuel pump not getting power
OEM HID to Halogen Rewire / Conversion or Part Source
Starts and runs fine with starting fluid
Crank sensor
my mitsubishi 2004 spider 2.4 wont start! HELP!
01 elclipse gt traction control abs issue
I found this in oil pan...can you tell me what is it?
2002 Mitsubishi Eclipse 4 cyl. ..how to remove counter balance shaft
2003 eclipse turbo options
2000 Eclipse GS 2.4L dies when engine heats up
My hood
2001 Eclipse 4 cylinder
Need Advice before going to dealership
overheating issue. 2001 eclipse convertible
Grounds
Engine Fuse
2002 Spyder 2.4 Eclipse Will not idle and dies
Water filling up Floorboard
2002 Eclipse leaking water
Window Problems
2015 Mitsubishi Eclipse R/SD Concept
Is 138k miles too much?
2000 eclipse
2000 eclipse
An Elegy to an Eclipse
2001 Eclispe Spyder 3.0 24Valve...running rough shutdown now won't start
Estimated Difficulty/Cost to Repair An Electric Door Lock In a 2008 Mitsubishi Eclipse SE?
01 eclipse shift knob HELP
Knock Sensor
HELP! Trouble Starting & Keeping Engine Running!
eclipse almost no heat from vents
Code p0456
How to replace coolant temperature sensor?
2002 Mitsubishi eclipse won't idle
Possible Hydrolock
02 Eclipse 3.0 distributor question
Crank Sensor Location
2002 Eclipse 3.0L O2 issues!
Pleash help
Possible EGR??
2006 eclipse GS (TURBOCHARGING!)
2002 stalls
Clicking Noise Before Starting car
several weird electrical problems and maybe a bad etac please help
02 Eclipse won't fire
2003 Engine Dying While Driving
Supposed PCM Problem
eclipse power problems. ~help~
eclipse oil problems ~help~!
Disabling factory antithef alarm on Mitsubishi 2000 GT
2000 GT Oil Leak
08 eclipse id this part?
2000 Mitsubishi Eclipse GS Alarm Problem
rims
2003 Spyder Convertible Eclipse Leak on the windows
2000 Eclipse GT - Problems
fuel evaporater
2002 Body Kits
advice on 2000 eclipse amplifier replacement
2001 Gs 2.4, Cam position sensor issue.
Shaking at 60+
wont let me pump gas
08 Eclipse Passenger Mirror Assembly
2000 Eclipse 3.0
Engine Interchange - car/engine combos?
supercharging my 2006 Eclipse
2000 GT Overfilled with Oil
2003 Eclipse OBD 2 Code
clock removal
really bad vibrations
rear end noise
00 Eclipse GT (115k mi) Clutch Question
02 eclipse wont turn
How does the transmission go back in?!?
03 gs flywheel/clutch
03 eclipse
2000-2004 eclipse-are good or bad?
Mid-engined 3g?
straight pipe eclipse?
2000 eclipse need help
Automatic Headlights not working
00 gs head removal
need help with 02 sensor
Manual transmission
2004 eclipse gts cylinder 3 misfire
transmission switch
2003 eclipse 2.4 cam crank codes check engine light
HELP!!! Transaxle removal (it's stuck in the car)
03 eclipse for sale
2003 GTS Spark Plugs
Transmission going into fail safe.....
I need some advice as to why my car wont pass inspection....
Upgrades that are sensible
A/C not cooling
Help!!!!!!
2001 Mitsubishi Eclipse Spyder Gt Automatic
HELP!!!! 02 Eclipse GT Wiring Issue
Overheating / Boiling over? So lost/fed up!
air condition condinsation inside car
How reliable are Eclipse's? Daily driver?
2001 rag top leak
mitsubishi eclipse gs 2008 headlight
Manual Transmission Oil - What to use
Couple questions about my Eclipse...
help stock radio issues
Issues with the electronics 2001 Eclipse Spyder
2000 - 2004 Eclipse info
2002 Eclipse GT Radio locked?
02 Eclipse GT Fuel gage inop.
eclipse GS 00 Racing
03 eclipse wont start
2001 eclipse v6 oil pan gasket
aftermarket headunit installed and running but speakers aren't working
Ok Some one Please Help
Programming Transponder Key
Running water behind the dash board
Racing chips? Real Deal?
Cheapest to make 2001 Eclipse RS faster?
whats wronge with the motor.
AC control light question
SES Light on 2003 Spyder GTS
2000 spyder
Part 2 the rest of the story
Part 1 of this story
2001 Mitsubishi Eclipse Spyder Spark Plugs
03 eclipse problems
2003 Mitsubishi Eclipse Universal Lighter
2003 GTS Spyder Maintenance
stock eclipse rims
Reverse light switch?
no 4th Gear 2000 Eclipse 4cyl Manual
2002 Eclipse GT...starts, rough idle & dies when put in gear
WTF Electrical problem
Eclipse 2001 gs Infinity Head Unit
2000 Mitsubushi Eclipse Headlight Fuses?
Undercooling problem
Driving myself nuts
Help!
2001 eclipse gt v6 transmission problem!!! plz help
Bypassing Factory Amp
Lambo Door Brands
P1610 code on 2000 eclipse
will 2000 galant v-6 fit my 2003 eclipse gts
PLEASE HELP!!! I need advice on why my 2001 eclipse is overheating when idling?
What's your longest roadtrip?
Headlight Sockets
a/c intermittent
factory amp
Hood and moonroof
Car heats up when going fast?
Thermostat Replacement
2002 Eclipse Headlight Problem
Needs A Rear Bumper Cover Black 2006-2009
Needs a Rear Bumper 2006-2009
Eclispse a hatchback or coupe?
My new Eclipse
Help Can I Cap off the Egr tube with headers
Getting 98' or 99' Eclipse
I'm looking at maybe getting a 2000-2003 Eclipse GT/GTS
Rattling in a 2008 Mitsubishi Eclipse
ignition wire sets includes #1 and #3, buy #2 and #4 separately?
help!!!!!
RRE Rear Strut Brace / Road Race Engineering
repair manual
Trans problem
turbo kit?
2000 Eclipse GT stalls at stop signs & signals when normal operating state is reached
Need help with tachometer install!
cali spec headers??
3.0 litre v6
2001 Eclipse GT won't start
2003 Eclipse making Grinding noise
Paddle Shift Kits
Rear Interior Panels
rear suspension noisy
stereo code
2002 eclipse electrical problems!
2002 Eclipse dented frame
03 Eclipse rs wont start
03 Eclipse rear end wanderers on slippery roads???
need to locate the crank sensor
fried infinity amp...any way to use an aftermarket one?
gauges
How to gain more hores power
Questions regarding insurance claim.
Passenger side Clicking Noise
For Sale
HELP!!! headers install
2000 eclipse gauges
need help finding a turbo manifold
maxing out speed without swapping motors.
Maybe getting a 3g or 4g...
Help With My 2000 Eclipse!!
Ball Joint Blues? 2006 Eclipse GT
eclipse gt vs celica gt
Running rich?
2003 GTS How do I remove driver door panel?
2008 sunroof leak
finding grill inset 2008 black eclipse se
I am looking for a good cold air intake for my Mitsubishi Spyder GTS
help
Slight vibration with right turns...
00-05 eclipse parts for sale come take a look
Tire size for 18x7 on a 2001 GT
heater problems
thermostat location
the dash clock
belt
Help Changing Water Pump On 2003 Eclipse
Eclipse o1 Gs
Intake
flywheel problem
headers
headers
Help
2000 eclipse gs
engine swap
2000 eclipse gt auto trans question
PARTING OUT 2004 eclipse! see what u need
back seat
fog lights
turbo wrap
cv half shaft won't go into transmission!
ECLIPSE CV boot/half shaft/ transaxle replacement help!
choice of headers?
'01 Mitz Eclipse
2001 mitsubishi eclipse gt spyder 3.0L v6 sputtering
Octane?
Turbo or supercharger
01 eclipse vibration problem ((HELP!!!))
my 2000 eclipse won't go into reverse
2001 Eclipse no start, code 1610
Help engine ideling wanting to turn off when a/c is on
01 GT, Running Fog Lights w/o head lights being on??????
Are they reliable, and what would I expect to pay?
Transmission problem
Dim Headlights
Whats the diffrence
turbo?
5 speed swap
2000 eclipse
01 eclipse brake job help needed
sell my 01 Eclipse GT
fan problem/online manual
Racing the eclipse
3000gt motor?
Custom Door Panels (interior)
multiple misfire
