View Full Version : Blazer
- 2001 Blazer console and stereo removal
- more tail trouble
- k&n
- Tranny Leak
- Jumping the pressure switch, is this correct?
- Code P0122 Throttle Position Sensor
- 95 Jimmy - Won't shift past 2nd...w/ other jerking issues
- Reset ECM - Now stalls at idle
- Power doorlocks out of control
- A little info about 96+ fuel systems
- speedometer guages
- ac problem on 95 s-10 blazer 4dr
- 2003 Blazer AC Problem...HELP!!
- Stuck Throttle/Accelerator on S-10 Blazer
- '93 S10 4dr 4x4 - Rear gate lock broken
- Updated my web page, what do you think?
- faster truck
- lights flashing!
- tail light help
- AC question
- Spark plugs
- Voltage meter (?)
- 1999 Blazer LS 167000 miles and still kickin
- Rattle noise 97 Blazer
- suggestion for main-seal tide-over fix?
- Its finally time... YEAH! The tranny is going
- Back Panel Removal
- Exhaust Pictures
- ? about popits & ABS codes
- "How to" for Torsion bars
- Need help on this funny sound.
- Air brakes
- Please Help. Stalled And Wont Start!
- XM Radio Installation Requirements
- 2001 Blazer - How Hot Does Yours Run?
- Bubbling noise...
- Buying S-10 Blazer Issues with vehicle
- Cannot find the EGR valve
- Battery or Starter??????????
- inlet/outlet
- Solution...
- ignition help
- Where can you find a "used" Trip Computer for Overhead console upgrade ?
- Check your Tire Pressure!
- Air conditioning problems after engine replacement
- 1998 Blazer Loud whining/howling sound
- Silly Question: Headlight Bulb Position
- Custom floor consoles/upgrades?
- Couple things
- My blazer turns on and then random shut offs.
- Rough Idle/Stall
- suspension
- wiring diagrams for 89 cougar xr7
- 89 mercury cougar xr7
- engine problems
- 1998 4x4 vortec 6. A/C Probs
- AC Drip???
- Quick Question
- Headlight issue
- canister purge solenoid
- temp sensor plug
- Rear Disc Calipers
- Issues with 1997 Chevy Blazer-Fuel Issues
- Rear brakes
- Major Problem
- Rearend problem & Transfer case Problem
- Another Overhead Console Wiring Question...
- A/C - heater blower motor
- Engine reluctant to catch, but then runs perfectly
- security system/passlock
- Stalling :(
- flash popups on this site. off topic
- Transmision slip error code 1870
- expensive Transmission noises!!!!
- bored out 4.3
- Blazer part
- wheel offset
- 98 Blazer LT
- steering column/ignition switch help
- Zr2
- 83 Blazer problems.....HELP!!
- Key stuck in ignition, seems totally dead
- Very Dark Oil
- Freeze plug replaced, not starting
- Brake rotor quality
- Instrument Panel Blowing with Brake!!!!
- '98 Jimmy Transmission Woes
- Water Pump test - 94 4.3 "w" newbie question
- 1997 bLAZER FRONT WHEEL CLICKING
- Awesome Seat Covers
- Power to fuel pump
- Thank You Veterans
- overhead console question
- fuel filter help
- 95 blazer ... can anyone help me ,idle, part idle and 4x4 issues
- Oil Smells Of Fuel
- Transmission woes....
- 1995 Blazer Power Lock
- 98 Blazer Overheating
- well cylinders
- What kind of scantool should I get?
- Question for BlazerLT????
- turn signal/hazzard switch trouble
- Disconnect EGR
- Vehicle surging, idling poorly
- K5 Question
- ravin muffler
- AC Pressure
- lumbar adj. non-pwr seat
- rear window supports
- Good Blazer Milage!
- Tranny Fluid Question
- Wacky temperature gage
- OBD for a 1993 Full Size Blazer
- two minor maintenance issues
- 96 Chevy Blazer Will Not Start
- Center console question...Need help!
- muffler sounds
- Antilock Brake light will not go off.
- Blazer A/C Problems -- Suggestions and Help Really Appreciated
- Wheezing sound in dash of my '92 S-10 Blazer
- brake pads
- smog pump super charger?
- Wheel Spacers
- Street Racing
- Totaled or not???
- 95 chevey blazer
- Advice on where to look next
- 99 LS Heater Squealing Sound
- rooftop cargo mpg
- New brakes/rotors squeel
- Forget The O2 Sensor!!!!!!!!!
- Evaporator shroud
- Anyone wanna take the credit???
- does anyone know where i can get.....
- AC recharge
- Error codes...
- Price Quote after crash
- Unable to bleed rear abs brakes.
- Just making sure
- 96 S-10 Blazer runs fine won't start
- My Blazer has another thing wrong
- Tbi Vs Carburetor
- Leaking Pumpkin
- turn signals all out ?
- Oil Pressure..
- Changing Gears
- Stereo Wiring Question
- I need help
- How do I remove the oil cooling lines from the radiator?
- 95 jimmy/blazer tranns?
- 'Scuse me govna...
- Revenge Of the Babysitter!!
- rear speaker access 97 blazer lt
- Who has the best parts?
- Electrocharger
- 1990 350 ECM code 42
- Stuck power window (2000 Blazer 2 door)
- 86 Blazer rough running and vibration
- will not stay running
- How do you treat your 4.3?
- Loud Engine
- Rear Disc Brakes on a 2000 4WD
- Crazy mods on Blazers
- 1996 blazer draining battery
- power seat
- 91 freeze plugs location?
- test wire help
- 1998 S-10 Blazer Problems
- 2000 LS Starting problem
- Whats the lowest you can go?
- Train goin down the tracks sound
- tranny shudder
- Lean To Passenger Side
- foreign versus American brands
- Programmers.. What is the difference?
- sun roof
- Big Clumsy Hands
- Intermittent Heat?
- Advance timing with this mod????
- A.C. problems
- Is there any way?
- low volatge at compressor
- Shuddering Start - Smell Gas
- won't rev as high as it should
- vibations
- under coating
- 95 S-10 Blazer 4.3 Vortec hard start
- How do I change the battery cable 1999
- code 0420
- 95 S10 Blazer self-installing hot tub
- Exteme style grille swap
- starter install
- 97 blazer runs like junk
- Removing the O2 sensors that are stuck?
- Air Conditioner problems...
- Having a rebuilt tranny put in my '97 cause...
- Antifreeze Disappearing
- HELP!! Knocking noise from passanger side
- fuel guage
- What year is the worst year for the Blazer ?
- starter
- clutch frozen to pressure plate
- Air Intake - Performance matters!
- oops!
- 95 jimmy/HVAC problem
- Where are you and your blazer?
- Washer Fluid Leak - 2002 Blazer
- Puttering and No Power
- 95' EGR valve
- blazer running rough
- Wierd noise when accelerating!
- midas
- 4x4 and vacuum line.
- 95 Blazer - How to replace antilock brake sensor???
- 95 Blazer - Vacuum Air Leak From Switch, Air Only Comes From Floor!
- What to clean and replace?
- Turn signal flasher location 94-98
- Heater Issue
- 96 blazer headlights
- Code 54...
- Have to get it up and running
- Water pump replacement.. and upper brake light/bar/LED replacement
- HELP Please Need a transmission>?
- keyless entry problems
- 1996 horn quit working need advice
- code 51
- Thermostat:180 deg. vs. 190/192 deg.
- 97 Ignition Switch Replacement
- 89 Blazer Issues.
- 93 blazer chugging
- 1995 Blazer - no air from vents
- Wheel Bearing
- SES Codes 0300, 0141 HELP Again PLease
- 2000 Blazer front end problems
- '95..fuel pump plus "assembly"
- vss
- Windshield Wiper Replacement
- Blazer Car alarm.
- Loss of power after 1000 rpm.
- Car Sounds like squeaking bed coils
- 95 4x4 auto "w" engine swap posibilities?
- Starting hard!?
- Hand Pump
- cruise control mod
- loc of oxygen sensor
- 350 in the blazer?
- rear end on 95
- 94 blazer 4.3 ...w CPI UNIT?
- 1997 s-10 blazer keys stuck in ignition help please
