View Full Version : Malibu
Pages :
1 2 [ 3]
4 5 6 7 8 9 10 11 12 13 14 15
- 99 Chevy Malibu Overheating PLZ HELP
- lookin at an 06 malibu
- 2005 Malibu V6 LS -- Pulls/Drifts to the left
- 99 Mailbu LS 3.1Intermittent Issues
- Degree of difficulty - Timing belt replacement
- Bad brakes or air in line
- Be Careful Replacing Wiper Blades on Chevy Malibu
- 1997 Malibu steering wheel don't lock
- Replacing wheel bearings in 97 malibu
- Possible Short
- 98 malibu turn signals flash wierd when headlights on
- Starter will not disengage
- 1999 Malibu 2.4 4cyl water pump replacement?
- my 2002 malibu clunk when changing gear from P/N to R or D.
- 2010 Malibu LTZ rims
- Has anyone tried replacing the HU without a wireharness? in a 2002 malibu.
- Need R&R help for 1998 Chevy Malibu starter?!!!
- 2003 Malibu I suspect passlock system
- 97 Malibu Noise
- 98 broken rear drivers metal brake line
- 04 Cluster
- 98 Malibu Starting/Electrical issues
- parking brake
- 1997 malibu replacing a steering
- total timing on a sbc 350
- No spark/start after water pump replacement
- 1998 Mailbu Rear Brake Problem
- 98 Malibu Crazy electrical problem
- 2002 Malibu Will Not start
- 03 malibu starts then dies right away
- Rack replacement
- 99 Malibu
- 00 Malibu Boiling over from Res Tube
- 1997 Heater
- 99 Malibu: aim headlights
- Factory SS stripes on a 2006???
- Gas leak
- 3.1 Engine Problems
- STUMPED! Heater Click - Braking Click
- Heads for 3.1
- Malibu temperature
- 97 malibu steer problem
- 2008 Brake Clicking
- crazy malibu
- Driveaxle retaining nut
- malibu blower motor
- am radio
- Fuel gauge either on FULL or EMPTY
- headlight problem 99 malibu
- Hvac blower
- Cigarette lighter fuse..
- Door lock, unlock switch on door Malibu 2005
- '05 Malibu w/100K+ miles. Proactive maintenance?
- malibu heater problem
- 2003 malibu key?
- scale 1-10 for 94-01 chevy malibu with 3100 motor
- Bad Knocking noise when driving 40mph and turn wheel 5 degrees to the left?
- 2000 malibu hvac blower not working on any speed.
- 2000 malibu hvac blower relay
- Dtc p0128
- crappy roadtrip
- Need help asap
- Blue tooth
- noise when I brake...After a tire blown out
- 1997 Malibu will not start when cold
- problems starting after installing new radio
- mass air sensor pin out
- Temperature and Fuel Gauge = Dead
- 2000 malibu lighter
- Engine for 01 malibu
- 98 Malibu gauge needles dont move
- Help with an 02 malibu
- Engine reduced power warining
- Fuel Gauge
- temp gauge woes
- 06 malibu
- 2003 Malibu heater doesn't warm the cabin
- air in steering system? Y
- Lose brakes when it rains.
- transmission slips when on highway going 65-70 MPH
- heater blower
- 2000 Malibu Coolant Leak
- 2006 heater control problem
- 03 malibu. new radio only works if dash lights on
- Anyone with a malibu please READ AND HELP
- 1999 Chevy Malibu 2.4
- 99 Malibu 2.4L 4 cyl., Surging/hesitation
- 06 Maxx - Remote Reprogram
- HELP! 99 malibu
- daytime running light question
- 2006 impala rims on 2000 malibu
- 1998 Malibu wheel size question
- 2000 Speedometer Problem
- forum login problems
- instrument panal light?
- 1999 waterpump?
- What the right coolant 1997 3.1 malibu
- Coolant under valve covers Malibu 2000
- What to do - Reverse went out in 98 Malibu
- 1999 Malibu - Best Intake Manifold Gasket
- Still smoking a lot after changing lower intake So frustrated
- 99 Malibu gas guage drops down
- After intake gasket problem... leaking radiator?
- 97 malibu stalled
- Brown sludgy coolant (oil in coolant?)
- Head gasket or Intake manifold Please Help Coolant in oil
- 99 malibu fuel mileage
- 99 malibu 3.1 not starting
- Keyless entry programming 2004 Malibu
- rsandstrom
- 99 malibu died on hwy, have spark, fuel pump buzz, but no fuel pres @ rail!?
- 06 Malibu Maxx, thump when steering turns
- intermittent no-start
- 1998 Malibu - check engine light
- Multifunction Switch
- Wouldn't you know it, now it's a P1404 code
- 98 Malibu will not start
- 98 Malibu runs rough/check engine light
- 05 malibu Maxx
- '98 Malibu broke cam 3.1
- 1997-2003 Malibu Control Arm Torque
- 02 malibu bad acceleration after warm up
- 2001 Malibu not wanting to start?
- smell and burning gas fatser
- What is this ?? see pic
- replacing ignition switch 2003 malibu
- 2002 chevy malibu door lock switch
- Gas filter blowing out on highway.
- malibu v6 3.1 and camaro v6 3.1
- 99 Malibu 3.1 logging in
- 05 malibu Maxx
- Rumbling Noise from wheels.
- 05 Malibu factory radio - adding MP3
- Cleaning the grease off the engine...
- 1998 malibu 3.1 trany leak
- Coolant smell, but no visible leak.
- Heater hose quick connect
- 99 malibu trans and abs
- 2007 Mailbu Drivers Side front end clicking
- 97' malibu
- Will a 1999 4 cylinder transmisson work in 1999 v6?
- 2000 Mailbu windshield defroster not working.
- 2003 Malibu High Idle Again
- 99 Malibu CVJoints
- 05 Malibu in glass antenna connection broke
- Is that possible to install in Malibu 05 radio from new Malibu(08+) or other GM car?
- 2001chevy malibu overheating
- 05' Malibu no heat?
- 1997 3.1 v6 broken cam
- 1997 malibu 2.4 head gasket
- Ticking from vents
- 98 Malibu Really excessive idle + more
- 99 malibu EGR insufficent flow code
- 3.1 Heads Shaved now no compression
- Electrical issue
- 2003 chevy malibu
- First Oil Change/Checking level
- How to replace power window switch?
- 1997 Malibu starts and runs then dies
- Malibu A/C Bypass Pulley?
- 2000 malibu Ac and heat not blowing
- 2004 malibu classic odo and speedo not workin.
- 04 classic/malibu Wont Start
- Ligher socket
- Help with yet another miss
- Location of EGR valve-2001 Malibu 3.1
- Gas Pump Problems?
- Will these rims fit?
- LIM replacement torque specs needed
- 1997 malibu car temp
- A/C kicks on and off intermittently
- Close to the end
- Car will crank; won't always run-- sometimes quits while driving
- 2006 Malibu 4-cyl 2.2L trouble
- 2000 Malibu ignition & shifter
- 2005 malibu classic
- 2003 Malibu wont start
- 2005 Malibu Maxx owners manual
- 2008 Malibu - 30,000 mile update
- Door lock switches
- help adding freon to 2004 malibu
- 2000 Malibu, Blinker keeps blinking
- Battery getting drained
- 2001 Malibu air conditioner Control Knob
- 06 steering linkage question
- Keyless entry?
- Will these fit?
- Block Coolant Drain Plug
- 09' malibu fails to scan
- No accessory power
- What years/models of 4T65-E work in a 99?
- 2005 Chevy Classic trouble starting after putting in gas
- 99 Malibu LS 3.1 107,000 miles: hi idle RPM
- 97 Malibu - should I keep it?
- 97 malibu power steering leak
- 2002 malibu
- ABS/brakes and more
- Rear Seat Back Removal
- 2003 Malibu starts but stalls immediatly?
- break peddle noisy
- Malibu maxx drag car
- A/C Light Flickers! Any Suggestions?
- 2006 Chevrolet Mlibu Maxx LT transmission cooler
- how do you check the transmission fluid level on a 97 malibu
- Go ahead and give me the dunce cap (2000 - Rear lateral rod bent)
- 2006 Malibu Maxx shifting hard
- 99 malibu, 3.1L wont take coolant
- Resistor or Blower Motor?
- Ignition Switch
- How to. Manual +/- shift not working and trans downshifts too easily.
- 2003 Chevy Malibu keyless entry
- sludge in antifreeze overflow tank 98-99 malibu
- My steering wheel is not able to steer
- 2007 Malibu, randomly jerks to left
- I am having steering problems
- 97 malibue intake-exhuast gasket - Need help!
- Cooling fan problems
- 2004 malibu ac
- malibu as project car?
- 00 Starter replacement 3.1 V6
- multifunction switch
- check oil light 1997 malibu
- After-market key FOB?
- 2000 Malibu Tranny issues
- CEL on, code 455 2007 Mal Maxx 3.5L
- tie rod torques 04 Z body
- Vibrating noise from DASH
- 2.2 Oil filter cap leaking oil
- malibu-2003 stops while driving
- 2001 malibu fuel pump
- Speed Controlled Volume
- Louder Music with Acceleration
- 2004 classic HVAC vent flow
- 2004 Malibu spark plug
- 2006 Malibu LS - Seat belt pretensioner & Air Bag light question
- Headlamps / DRL flickering
- 1998 Malibu PassLock Issue
- Engine light
- Door ajar
- ABS light constantly on
- Shocks or struts problem
- 06 Malibu Maxx LT--rear tail light question
- 1998 2.4 with 200,000 kms . to fix or not to fix ??
- 2000 Malibu axel wobbles - fixabel?
- Fuel pump on/off
- Passlock 2 bypass help
