View Full Version : Montero/Shogun/Pajero
- gas smell from 2002 Mitsubishi Montero
- coil good but getting intermittent spark - delica
- 1986 mitsubishi montero
- Spark Plug Wire Routing
- 2001 Mitsubishi Montero Sport having issues. Please help before I put a Jihad on it.
- 1999 Montero 3.5L Timing Belt SVC now won't start,
- Timing with light?
- 2002 montero leaking water in valley! Help
- 2003 Montero Sport brake/tail light
- 03 Montero Limited 3.8L start-up tapping & misfires/stalls while driving
- Help!!
- 1996 Montero 4wd questions
- 2002 mitsubishi L200 TD airbag module
- 2002 Mitsubishi Montero XLS rushing water onto floorboard
- Mitsubishi Motors Starts Production Of Pajero Sport Midsize SUV
- A/C compressor clutch won't engage
- Montero sport radio problems
- Replace Exterior Door Handle,Passenger Side-98 Montero Sport
- pulsating lights
- Front wheels not engaging (fully) when switching to 4WD
- Manual brake indication light always on
- Big Daddy Got Punched :-(
- Mmsc
- Montero XLS 2001 ABS Grinding/Screeching Problem
- Moon Roof Window Motor
- problem mounting nerf bars
- 02 mits montero 4wd xls "tranny probs?"
- engine swap
- any recommendations on spark plugs for Montero?
- pajero timing chain and many buttons
- need a user manual pajero exceed 1997 auto
- Service Engine Soon light turn on (Montero 2002)
- Transmission Noise at Slow Speeds/While Slowing Down- 04 Pajero
- Montero 2002 Alarm module
- Montero General Info???
- Smell gear lube after using 4wd
- 2001 montero_back driver wheel part...need advice
- Montero Sport Roof Rail
- Montero Head Lamp ?
- 97 Monty SR 3.5 no fuel
- Auxilary power sockets.... fuse location?
- Need help with color of Montero
- Serivice Engine Soon? P0510? HELP PLEASE!
- Changing A/C compressor on 00 Montero LS
- 2001 montero runs hot
- Owners Manuel
- 2000 Montero Stalling after dead battery
- 2000 factory roof rack questions... Do you have simple answer?
- 93 montereo no spark
- 90 Montero burnt engine control computer
- HELP? where is the map sensor located on a 97 montero???
- Tire Upgrade for 97 Montero
- Headlights
- 1st gen monty parts?
- Transmission - Hard Shift ????
- 2002 Montero - 60/40 2nd Row Split Seat ?
- dashboard pics
- 2000 Montero transmission prob
- Does anyone know to find info on How to repair 1994 Pajero Clutch
- 2000 MonteSport... How to change fwd turn light?
- 1995 pajero owners manual
- blinkers not working
- wiring diagram ??
- 1987 Dodge Raider Shuts off after 5-6 minutes
- 95 Shogun cutting out problem
- High Pressure fuel pump filter
- No petrol to carbaretor
- Noise at start up
- radio removal montero
- 02 Montero Sport LMTD AWD / o2 Sensor?
- 4wd light
- Mont sport horn won't stop, had to pull fuse
- 1999 Pajero IO Questions
- Montero 3.0 DOHC leaking coolant
- slow acceleration at startup
- 1998 Montero Sport radio removal
- replaced alternator now it won't idle?
- Montero 4wd light????
- Custom Payment?
- Turn signal problem.98 sport
- MDS vs MAP
- Pajero io multicommunication system
- Timing belt question
- pajero atf hot light
- subwoofer replacement
- Anyone know how to change power antenna unit 2002 Montero Sport?
- Brake Light stays on
- 98 montero has no spark
- 2000 mitsubishi motero sport
- cam timing 3.2 Di d Pajero 2001
- Code For Sterio
- 2000 montero sport trany ?
- Changing Rear Brake Pads on a 2001 Montero Sport
- Radio code for Montero sport 2000
- smoking Montero
- Difference between headlamps 92-7 to 98-00 Montero
- 1998 Montero Sport Speedometer Problem
- Battery & Brake Warning Lights
- Back Door Panels
- power loss
- Parts
- need info parts general knowledge for my 94
- code help P0120
- Changing break pads on Pajero 1995
- 1998 montero sport
- 98 Montero compass reset
- The next 2008 motero sport (triton g-wagon)
- Diesel conversion for 94 3.0?
- looking to buy Montero Sport
- Pajero 3.5 SWB 1999model ABS light problem
- Pajero 99 3.5 emmision problem
- Tune Up?
- Pajero IO, MMCS just a blank screen help!!!!
- 97' Pajero 2.5TDi. Aircon prob.nEEd Help pls
- 89 Montero~ New owner ~ Having issues with rust & finding parts
- Montero Sport outside mirrors fuse
- Ex-Japan 2000 Pajero io, blank screen
- 94 Montero won't start / blown fuse
- Replaced alternator now what? bad idle sensor?
- 2000 montero jerking..
- p0455
- 99 montero sport fuse box
- Montero Sport - Canadian Specifications
- What side 02 sensor on 2000 Montero sport
- Does a Mitsubishi Montero have 3 catalytic converters?
- starter on Mitsibishi Montero sport
- does anyone know that name of this part?
- 95 torque convert wont seperate from flywheel
- Steering box fluid checking.
- dual mass flywheel
- Timing marks/questions, 1994 3.0L montero
- Electric seat problems
- Repair Manual Book For 98 Mits Montero
- Pajero Engine Valve Clearance
- Montero 96 Auto Trans
- 95 Montero SR w/3.5L ABS light always on
- Looking to put in a manual transmission
- Pajero transmission
- Shogun Wheels
- shogun auto 2.8 1993
- 2001 montero sport xls
- Windshield Wipers
- Montero Question
- Pajero Shogun ABS problems
- gen 1 monty hitch??
- Brake Problems
- mitsubishi shogun
- 2000 Montero Sport wheel problem
- 2006 Montero review
- 2000 Montero Sport Cruise Light
- A/C now it works now it doen't
- pajero io gdi
- 2000 MS Fuel filter
- Whining coming from ABS pump (2001 Montero)
- Turn signal brain teaser
- 2006 Sierra Challenge prerun pictures (large)
- Front Brake pads on 98 montero sport
- 02 Montero Antenna
- timing marks 97 montero sport
- factory offset 2001 montero limited??
- 98 montero warning lights
- 6 Cypress CA is on July 29! (large flyer pic)
- Brake Light/Turn Signal Problem
- glow plug problem
- Rotor/drum removal (E-brake shoe disengage) '01 Montero
- Where can I buy a Multi Communications System Data Disk (Pajero)
- Tempermental Shogun
- Radio code Mistubishi Montero Sport LS JULY 1998
- Shogun door mirror.
- 3L v6 panjero any1 know cylinder head settings
- radio code free!!!!!!!!!!
- looking for a part number
- 2002 Montero Sport with All-Wheel drive not starting
- 1997 Montero SR Spark Plug
- 1988 Montero
- Thining about buying new montero
- DIESEL 2.5 TURBO I/C TIMING BELT REPLACEMENT, shogun, montero, pajero
- Radio Code Wizard - Not! (I'm toast.....)
- Parking Break Montero
- 95 Montero Dash Light called A/T
- 2002 Montero Vibration / Rumbling
- Replacing an alternator on a pajero(the cables)
- O Rings
- 1995 montero
- 03 montero v6 questions
- Rumbling/Low Rattle Under Hood
- my 99 montero/sport
- IRS or SRS?????? Please help..............
- Pajero 3.2 Gdi 2000 Swb Engine Block Warning Light, Engine block warning + power loss
- Part time Power Door Locks
- Montero 2001 4WD Dash Light HELP
- Will starting in 2nd gear all the time kill my Montero?
- 2000 Montero Sport interior outlets cause horn to sound
- Installing 99 Montero Sport HEADLIGHT
- engine mounting
- 1999 Montero 4WD system
- high RPMs between 1st and 2nd Gear then Rough Shifting
- It was delivered this weekend
- Steps/Nerf Bars - Good ones?
- Pajero stalling
- timing chain diagram '84 nb pajero
- 4wd shifting
- swap diamante dbl overhead cam 3.5 to 95 3.5 montero
- 98 montero radio code need HELP me pl !!!!!!!!!!!!
- help me anyone. I need to unlock my volkswagen premium audio
- Performance modifications
- Winter blues?
- 98 Montero sport springs torque info needed
- 1997 Montero Sport Radio Code
- E-Brake light in 98 Mont. Sport
- 1998 Montero Sport smokes
- Need a part for 1995 Montero...any help?
- 98 sport springs
- i need some advice
- Please need radio code!!!!!
- Finding Lock Control Module to Program remote
- 98 Montero Sport check engine lt
- 98 montero, bad ABS sensor assembly
- Changing spark plugs looks too difficult
- Is it the alternator
- '99 montero seatbelt question
- 1998 Montero, resetting computer. How?
- I have a GREAT LOOKING '90 Montero for sale
- Air conditioning recharge port 98 Mont. Sport
- Immobilizer malfunction code,what's dat?
- 90 3.0 L Won't Idle
- help - need radio code for 2K Montero sport
- Ethanol Fuel
- Oil Pressure Warning Light when A/C on (Shogun)
- What does this dash light mean??
- if you own a Montero Sport
- adding indash cd to MS Limited?
- Transmission change problem
- Battery group size/CCA rating requirement
- How to remove radio to get serial # on 97 Montero LS
- accessory plug shorted out
- emissions
- montero 2000 blower
- has anyone
- bad smelling montero
- Montero Trans
- montero 2000 sport
- Unsure on which manual to purchase
- Pajero auto transmission problems
