Mitsubishi
> Montero/Shogun/Pajero
View Full Version :
Pages :
1
2
programming remote for 97 montero sr
1998 Montero Sport - Oil Pan drain plug question
programming the keyless remote
Need the radio code for 1996 Montero.
Need information about the infinity sound system
Fan Clutch Breaks Loose
97 Montero Sport radio code
Brakelight 98 Montero Sport.
4 original montero rim caps--cheap
4 wheel drive light flashes
Truck Won't Start!
Diff ratios question...
2002 montero sport lowering springs?
hmmmmmm
Oil Light
95 montero
replacement rear heat pipe (montero2001)
99 Montero Sport repair manual
codes for Montero sport 1997
92 montero Leaking anifreez
2.5 intercooled turbo engine problems
98 montero sport doesn't spark
'95 Mits Montero alternator
01 Montero Tach Wire
need radio code for a 99 montero sport
Pajaro/shogun Mk1/ Mk2 question
Mitsibushi shogan headlights problem
Differential Question
Gen 1 vs Gen 2?
2000 Montero Sport Radio Code
Strange noise w/ Montero 95
1999 Montero sport car stereo decode
2002 montero sport brakes
Automatic Transmisssion what generally goes out first when driven low on oil?
Need help with automatic transmission....
dead speedometer
2000 Montero/ Pajero transfer case
General Q: About the Montero Sport
Montero-1992 or similar
Remote Programming for 2000 Montero Sport
Ralliart Pajero Blueprints
fender flare?
Montero vs Trooper vs Explorer-buying used
programming 2001 Montero keyless remote
help needed with 2 faults on shogun
Muffler
NEW BATTERY destroyed my Montero! HELP!
Noise when A/C is turned on
amp locale
Montero Sport Single Cd player for sale 98-up -See ad
Whining/Scrubbing type Noise Under Hood HELP!!!
coolant loss
could someone share the radio code # 98 Montero
Fuel Display Problems
Infinity amps preamp limits
License plate lights
Montero Sport License Plate lights
98 montero sport radio install
clicking noise and oil light
montero part out
prob w/ skipping @3k rpm in 96 Montero SR
Can U swap 3.0 liter into 3.5 liter Montero?
91 galant has a miss what is wrong
Looking for 84-91 Montero
Evap Emission control Leak
first post. need help with my 01 montero. possible differential problem
Alarm Problems - Montero Sport
86 montero lift ideas, deet's or sugest's !
lifting a montero
new 10-disc changer questions
Help with programming a keyless remote for 1998 Mitsubishi Montero. THanks
Whats wrong with my car?!?
How to Get Serial Number of Radio
montero smokes after being in idle?
1998 Montero Sport clicking noise from engine
98 Montero Sport Horn Problem
'95 Plenum vacuum loss issue
02 montero below dash auxilliary din removal
95 Montero Overdrive & stalls
After 5-10 min the car starves for fuel:(
Tachometer
1994 3.5 L. 6G74 Sensor Issue
Trouble starting - Possible fuse problem
RPM meter
Montero ticks
2001 montero limited 4x4 green light indicator
anyone interested in purchasing 95 montero LS
97 Montero Sport Airbag and Brake Light
Montero 3.0/3.5 Oil Consumption, etc...
No Brake Lights
2002 Montero Limited To Much Oil
Need Info.........1998 Montero Dakar
Help me, 95 montero starving of fuel
Loud and Annoying Door Actuator
95 Montero stalls
engine retrofit
Denver Area - Need a GOOD Montero Mechanic
89-91 parts????
Won't Shift out of 4H
What size tires fit 94' SR without lifting?
timing belt replacement
Starting problem - Pajero
1990 Montero engine rotates but not firing
2002 Montero Ltd-no start
Front Side marker/Turn Signal Lights
'93 and earlier question for potential owner
Hitch wanted 97-03 MTS
RPM too high!
ABS light is on
Running Board Lights
HELP! overheating!! plenty of coolant!!!
97 Montero -hold Light On
Factory service manual??
Looking for 94-96 DOHC bare block
transmission problems
Ignition Problem.
'95 leaks water between front door and frame
Front end question
platinum sprk plugs
GPS in a Montero Limited
MANY MANY 1995 Montero problems
Reset miles-to-empty for Montero Limited?
Remote entry for Montero Sport??
hood mirror
keyless remote programing-mitsubishi diamante 1993 wagon
OK to replace P-series with L-series tires on '89 montero?
wheels ?
Seat Covers
Electrical issue
Fuel Injector Replacement
antanna mast
burning the oil why??????
Hood Mirror From The Pajero..........
too many attemps.. stereo CODE
Montero Limited .. any input? =)
