View Full Version : Avenger
- No Start/ Head Gasket Replacement
- stripped caliper slide pin
- Avenger SXT+ overheating issue
- Desperately need help with Parasitic drain in 2008 Dodge Avenger
- My battery light is on.
- Electrical problems!
- 08 Avenger throwing codes
- The thermostat housing 2012 Dodge Avenger
- PLS advise trouble my '11 over-heated
- Loud squeel from pulleys
- Severe rash from seats
- 2011 Dodge Avenger Crankshaft Pos Sensor
- 2013 2.4 No Heat!!
- Help..
- Avenger motor swap no start
- Drivetrain swap
- Air bag light
- 09 avenger AC BLOWING HOT AIR ON DRIVERS SIDE AND COLD ON PASSENGERS SIDE
- 2012 dodge avenger
- 1998 dodge avenger rims
- Compatable seats for a 1996 Avenger?
- Water Leak
- 2010 Dodge Avenger p0700 code
- Dodge Avenger Strut replacement
- Get The Most Horsepower For Your Money
- Painting Calipers
- Howto pick heavy object?
- Avenger Key Fob
- 2008 Avenger stuck in park
- Damage to rear bumper, replace?
- 2000 dodge avenger
- Dodge Avenger Video Test Drive
- 1995 Dodge Avenger OBD Code Reader
- alternator 2008 avenger
- Is it hard to lower a 2008 dodge avenger?
- Blinker stuck on
- 1998 Avenger 2.0 reman engine
- alternator removal
- 2000 Avenger p1768 code tranny
- 98 Dodge Avenger 2.5 auto Will not stay running
- No compression
- 2008 avenger noises
- my friend put 10 qrts of oil in my car now its knockin fast ?
- 98 dodge avenger es vaccum problem?
- 2008 Avenger Door Panels
- Any Car Compatible with Avenger?
- Dodge Avenger
- 08 Avenger aftermarket headunit installation
- service engine egr code
- 1999 Avenger drive train question.
- 1998 Dodge Avenger 4 cyl not starting
- Can it be a gas fuse?
- Pictures?
- 99 2.5 aveng. belts
- 98 avenger parts compatible with eclipse?
- 1998 Avenger Problems, Transmission perhaps?
- 1997 Dodge Avenger with front end vibration
- not gettin and spark
- fuel pump in 1999 dodge avenger
- Avenger VS Eclipse 420a Exhaust?
- Radio Issues
- HP chip
- 2008 Avenger
- 98 avenger, 2.5, bad hesitation, poor cold starts,
- Engine revs when clutch pushed in
- New Avenger Parts For Sale
- Cabin filter
- Dot3 or Dot4?
- 96 avenger 5 speed trans
- Avenger 98 trasmission
- 96 Dodge Avenger Times for common repairs
- 96 dodge avenger what are some COMMON ISSUES
- 96 Avenger stalls after sitting
- Need help with my 1995 avenger.
- car has lil heat
- 97 avenger m/t stuck in gear...shift linkage?
- 2 issues with 96 avenger turbo
- powerwindow not working
- losing sleep
- Right turn signal stuck on
- 97 Avenger ES
- Radio quit working
- How do you remove 'change oil' light?
- 1995 Avenger emergency brake shoes
- youtube clip of my 08 2.4L engine noise, tell me what you think
- 08 2.4l Avenger .Need Some Help
- 99' Avenger "help"
- 95 avenger tranny removal
- 97 avenger 2.0 runs good till i drive 30 miles
- 97 Avenger relays
- Car from hell!
- 95 fit a 98?
- timing belt settings 4 1997 dodge avenger
- Tranny problems with 95 dodge avenger
- 2008 Dodge Avenger
- 96 Avenger Dies at 50mph
- F.s 2000 dodge avenger CT
- 1998 Avenger 2.5
- starter question
- 97 avenger cranks but wont start
- cold start problems
- 99 Avenger-#1 fuse keeps blowing-fried computer-help
- 08 avenger aftermarket radio issue
- 97 vs 99 Avenger ES
- hey
- 2.slow engine swap??
- Electrical?
- Check Engine Light On Won't Shift
- neon ligh install help
- Avenger tranny troubles.
- button question
- 98 won't start, has spark
- 95 avenger es undercharging...
- water out muffler
- Crank pully and Crank gear 97 2.5....Help
- Pics of intake manifold to head
- '95 Avenger ES Tranny Swap?
- looking for a 96 or 95 avenger
- Please Help Me??
- Looking for parts for 95 avenger 2.5
- 96 Avenger
- Cold air vs. Short ram air
- clutch replacement
- 2008 Avenger
- Head swap with a 98 Eclipse GS
- 99 avenger audio system
- flasher? can't find it
- 97' avenger 2.0 liter Head Gasket Reapair
- Looking for used Avenger or Eclipse
- 1998 Dodge Avenger 2.0L DOHC 420a Head
- Just bought a 95 Avenger 2.5 ES. I replaced
- 1996 Dodge Avenger
- 96 Avenger stalls and won't start when hot
- 95 Avenger for sale
- rust on brakes/suspension
- Car stalls...?
- Need help with fault code PO300
- Car boggs down for first minute or so of driving,
- 2000 Avenger 2.5L 6cyl, will not start
- I'm getting really bad gas mileage!
- interior light dimming system
- '00 Avenger 2.5L No Spark
- Automatic Tranny issues
- ECM 96 avenger
- Problem with ABS
- avenger stalls out
- Interchangeable parts
- 96 avenger starts & runs fine for 5 miles
- Avenger turbo?
- Bad gas mileage? or what
- Thinking of selling my Avenger....
- looking for a tranny
- Viper hood and LOW MILE trans for sale....for avengers duh lol
- Po731 Po740 Po4o3
- 95 avenger se wiring schematic
- 1997 Avenger is turnin over but doesnt spark?!?!
- Power Door Lock Problem
- avenger egr probs
- Help!!!!
- can someone with a v6 avenger do me a favor
- 97 Tansmission help
- 95 avenger rattling
- Tire size's on a avenger...
- Any one have a turbo'd 95 avenger 5 speed?
- Looking to Invest...
- can't get out of the park position.
- 95 black avenger for sale
- 2008 Dodge Avenger?
- AfterMarket Exhaust??????
- trany question
- Distributer and wires
- Taking apart the head?!!!!
- dash speakers
- Help me!
- speed
- Problem with the accelerator
- once again my car will not start
- 3.0L 6G72 Turbo Manifold w/ 2.5L 6G73
- custom exhaust piping shop?
- Fuel return kit!??
- Rotors
- What are the signs of a bent valve? please help
- timing belt cover
- Electrical Problems
- Traction bars!!!
- how to increase traction on dodge avenger!!!?!!!
- 95 Dodge Avenger 4wd conversion?
- do i need to replace. . .
- couple of q's bout turbo and timing belt
- 2.5L V6 (6G73) and 3.0L V6 (6G72) comparison question
- 95 dodge avenger, snap/pop noise when turning
- 95 Dodge Avenger 5Spd RPM truble help!
- Question for the V6 Auto
- Help For 96 Dodge Avenger
- Avenger V6 charge pipes?
- $1,800.00 Later...!
- Turbo the Stock V6 2.5L 24-Valve Avenger
- Please Help
- i am stumped...engine running terrible
- Uuggg ! Transmission Smission !!!
- 1997 Transmition Problems
- all wheel drive conversion?
- Transmission question
- Dodge Avenger Wagon
- avenger stereo wiring colors
- Steering wheel jiggles 96 avenger.
- Ugh!!!!
- Need Help Please
- question about turbocharging a 2.5
- Question About Shift kits
- Fluctuating Oil Pressure
- Clear Lights
- Oil Filter Mount & O2 Sensors
- Now my car seems fine
- What's wrong with my car?
- Help With Code 44??? 95 avenger
- body kits
- CD Player keeps resetting
- i need transmission help!!!!
- 98 Avenger EGR code
- I am stumped
- Is my Trans Shot
- 1998 avenger hard to start.
- Shift Kits
- Torque Converters
- brakes, are they special
- Question
- How good is a 98 Dodge Avenger
- engine
- Problem pulling the head
- 98 avenger no start
- Battery? Alternator? Both?
- knock in motor, but not sure were.
- 96 avenger smoking
- new motor
- intakes....
- looking to mabe get a dondge avenger
- Changing the front brake pads?
- avenger headlights 97' fit 96'
- Squeaking when I turn the wheel.
- Noise in the dash
- Water Pump
- 1995 Air Bag Cover
- Confused about my venge..
- Water Pump?
