View Full Version : LeSabre
Pages :
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 [ 18]
19
- Heating and A/C problems on my '97 Lesabre Limited
- 92 Lasabre Starter interupt relay - where is it!!
- Spark Plugs-Brand & type
- 2001 LeSabre rear door panel removal
- 1996 Lesabre Bucking/stumble in overdrive
- Obnoxious Front End/LH/Steering Clunk 2000 LeSabre, How Loud Might A Bad CV Joint Be?
- 00 LeSabre Drivers Mirror Shakes At Highway Speeds
- 95 Lesabre Data Link Connector Wired Wrong
- A/c and electric windows still working after key is turned off.
- I need 1999 Healight info
- 1990 LeSabre with possible fuel problem...
- Code 26 QDM?
- 94 LeSabre Questions
- Scan tool for 1987 Lesabre (and others too)
- Hvac Blower Motor 97 Lesabre Limited
- Tool to remove door panel
- 1995 smokes, compression good ?
- 1975 buick lesabre important question
- 88 LeSabre headliner removal
- HVAC Blower Motor flaky
- 94 Lesabre acts like its running out of gas
- Charcoal Canister?
- Heat vs. Air conditioning problem
- Remote control front door locks won't open
- Crank Shaft Pulley Bolt
- 92 Lesabre Code 58 Fuel Enable problem
- radio,clock,horn
- Ignition Problem
- Leaking power steering fluid
- 1992 Lesabre fuel filter location
- 1994 Buick Lesabre battery won't keep a charge
- defective moisture sensor in windshield
- 97 LeSabre Climate Control Face is too dim
- 1995 Buick Cruise Control
- noisy th440 transmission
- Air Suspension problems
- A/C Question
- ENGINE STUMBLES WHEN COASTING (update)
- 91 LeSabre Door panel removal
- Interior lights will not go out
- Please help before warranty on 2001 expires!
- 89 lesabre ttype radio electrical problem and a/c problems
- 1994 Buick Lesabre - smoke
- 89 lesabre loses all power
- Bug/Hood Deflector
- A/C problem
- A/C conversion from R12 to R134a
- cruise module location 89 Park avenue
- GM plastic intake coolant leak on 3.8L
- HVAC blend door not working
- -=WANTED=- delco cd player for 1994 lesabre
- Power Window Problem
- how to check Catalytic Converter
- Need Help Heating and Cooling
- Rear bumper height
- 1986 LeSabre 3.8L - ignition timing
- 92 Buick LeSabre 3.8, where is EGR valve?
- 1996 Buick Lesabre
- 92 lesabre, pkave, vats/passkey
- 2000 LeSabre Cruise Control Switch
- Retro AC on 86 car
- 86 Climate Control Panel
- Wiring Diagrams for 86
- a/c freezing up
- Engine bucking in overdrive
- clock light stays on with ignition key off
- bad struts on 1998 lesabre
- Totaled 1996 Buick Lesabre
- leaking brake fluid
- '63 LeSabre - 401 need block plugs, where can I get them?
- whining from dash
- 2001 instrument lights
- Obd I
- 95 Buick Lesabre Intermittent Start
- 2002 Buick LeSabre air cond-heater problem
- 1990 Lesabre EGR Valve
- 1990 LeSabre
- '95 LeSabre Dies Without Warning
- 1995 LeSabre - Transaxle / TC Chatter or Rattle
- 87-88 lesabre
- Problem on windy days
- front spring makes noise when terning
- Brakes on 92 Buick
- Security disconnect, 1997 Buick LeSabre
- Engine Stumbles When Coasting
- When Shifting into drive...Car Dies!!!
- Removed Dash-Won't Start
- 2000 lesabre electrical problem
- Engine misfires on plug #6
- 1995 Lasabre air conditioning
- Clattering 85
- 1992 Buick LeSabre Won't start * HELP *
- 98 Lasabre PLASTIC INTAKE MANIFOLD FAILURE!
- installing a t-type gauge cluster in a standard lesabre
- 87 Lesabre transmission problems.
- What causes a 89 Buick Lesabre EGR Valve to melt?
- 2001 LeSabre not auto-shifting in the a.m.
- 1985 Seatbelt, Door Ajar and Headlight alarm
- 98 Lesabre should i buy?
- Radio installation
- Need Help From Master Tech.
- 86 LeSabre cruise control wires
- Hesitates going up hills
- 88 Lesabre motor mounts
- Cluster Swap
- 2001 LeSabre - failed to start in trip
- No sound!
- 2000 LeSabre Oil leak
- clearcoat
- 1989 LeSabre no spark HELP
- 86 LeSabre Dash removal (new front spks)
- radio removal 1999 LeSabre
- Airbag Troubles
- How to change front struts on a '87 LeSabre?
- Transmission Weird.....?
- need help "fast" !!
- 89 LeSabre poor air flow from vents
- Rear Spoiler on 2000 LeSabre
- data link connector
- New brakes in front sqeaking.
- 95 buick uses oil
- 90 LeSabre No Injector Signal to Cyl #1
- 1993 buick dynaride
- gm code site
- 94 Buick lesabre abs light blinking-wont come out of park!
- heater blower will not turn off ,key off
- water everywere
- My $600 Oil Change
- Turbocharging the LeSabre engine
- Buick woes
- Rear passenger side window
- transmission issues
- lesabre compared to park avenue
- wipers wont shut off and retract under hood
- Fuel Pressure Regulator
- 94 Lesabre - Water Leak into Passenger Compartment
- Lesabre Hard start after sitting a while!
- What fuel injector should I get?
- 2000 Lesabre window regulator
- Lesabre window track
- 94 LeSabre Intermittent Start
- 94 Buick Lesabre heater defrost / climate control
- 85 LeSabre heater core
- Quarter Panels
- CODE 34 from computer.
- 93 LeSabre Radio Swap......
- 94 LeSabre Security Light Problem
- 1995 Cruise Control problem
- Looking to buy 94 LeSabre Custom but......
- Noisey and chattering 3.8
- Error code pulled on my car what is it?
- Engine "smells" hot
- 3800 engine swap 2000 into 1997
- 94 BUick Lesabre
- 2000 lesabre 3.8....gas mileage is terrible
- Engine swap, 2000 3.8 into a 97 LeSabre
- Engine Knocks In 1992 LeSabre
- horn relay please help
- 1989 Lesabre fuse box?
- 94 3.8 LaSabre Fuel Starvation
- 1978 LeSabre Fuel Line Fire!
- 87 buick lesabre running rough and missing
- 1991 LeSabre Rear Defroster problem
- Fan likes to hang around...
- Camshaft sensor magnet
- 2000 lesabre....noise near exhaust..windows fogging up
- starving for fuel?
- 2000 LeSabre rough initial acceleration (new to AF)
- Where does gear shift indicator attach to?
- Engine swap from one GM to another GM
- A/C temp flashing...code -152
- 99 Intermitted Defroster Fan
- 93 lesabre ltd abs
- Gas leaking out exhaust manifold?
- 89 LeSabre Starter Location
- 91 lesabre heater blows cold air
- 91 lesabre engine surges when stopped
- Weird Electrical Gremlin?
- 1992 Buick LeSaber 3800 Dies in Traffic
- I Think I blew my MSC Module. HELP!!
- Climate Control Panel starting to die??
- is it possible
- tons of heating problems
- radio removal
- LeSabre starting problems
- any brake suggestions greatly appreciated
- 92 lesabre running bad after warming up, can only drive a little ways
- Heater Problems
- Coolant Leak???? Help Please
- Need '89 Lasabre Front clip interchange info
- i'm new and i have questions
- Occasional Misfire
- brake light/warning stays on
- 1993 Lesabre Buildout
- 91 Lesabre air conditioning problem
- interior lights, 1st post, please help!!
- '94 Olds 98 won't start
- tranny problem? please help
- A/C compressor anybody lost one on a 95
- 1997 LeSabre Climate Control shows incorrect temps
- 88 LeSabre won't start when cold
- '94 Engine randomly quits
- Cooling fan relay
- WOnt even turn over "HELP"
- Any mods done to the Buick ?
- Front wheel/cv joint/bearing noise
- Coolant system overpressure protection?
- 1994 LeSabre Limited VIN check - carfax
- Bypass A/C with belt or pully?
- 1994 Buick LeSabre won't move until warmed up
- Cruise Control Problems
- keyless remote programming for 95 leSabre
- '86 LeSabre stsrting problems
- Remote starter recommendation for '98?
- Check Tire Pressure
- Engine Mounts
- noisy engine
- 2000 Buick LeSabre Power Window Controlers
- 98 Buick Lesabre Security light on
- this pro needs advice
- 1990 LeSabre Anti-Theft Reset
- 1992 LeSabre Electrical Nightmare
- 93 Buick LeSabre cranks but won't start
- crank but no start
- Opening a hood w/o the hood release.
- 92 Buick Lesabre not start
- no fan blower
- Removing front dash cover...
- 89 Lesabre Bumper Removal
- LeSabre Padded Dash
- 97 buick lesabre no start security problem
- Surging blower motor
- looking for body parts
- 89 LeSabre Intermittently Running Rough, No Codes
- Ran Out Of Gas
- 90 LeSabre Intermittent Stalling, SEL, Temp Lights
- '89 Lababre w/3.8 AC pump noise
- 89 Lesabre blower problem
- '94 LeSabre with "issues"
- Replaceing Motor Mounts
- No Spark on a 1986 Buick Lasabre
- Lesabre oil leak
- Heater wont shut off
- is is junk???
- code 42
- LeSabre Air Vent Controls
- Power windows
- 00+ junk?
- 1989 LeSabre limited radio electrical problems
- 1988 buick lesabre won't start
