Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 09-08-2009, 06:45 AM   #1
redddogg60
2007 Suburban LTZ REAR END SLIP AND CLUNK at low speed.
My '07 Suburban with 55k miles has a "slip and grab" feeling coming from the rearend (when leaving a dead stop, rounding corners at low speed, and coming to a stop). Almost feels like a bad universal joint. The guy at the local axle shop tells me that this is common among GM trucks. He said that he has never seen one fail, but when I get sick of the feeling to have the rearend replaced. He said that it has something to due with the traction control "govenors". I will be taking the vehicle to a GM dealership (since this is drivetrain related and under the 100k warranty. I was wondering if anyone could clarify, deny or add to the "axle guys" claims. As I would like to be as specific as possible when talking to the dealership. Thanks in advance, for any help you may offer.
redddogg60 is offline   Reply With Quote
Old 09-08-2009, 09:14 AM   #2
MT-2500
AF - Advisor
MT-2500's Avatar
Re: 2007 Suburban LTZ REAR END SLIP AND CLUNK at low speed.
It should not be kicking in unless one wheel is spinning.
If it is under warranty let the dealer take care of it.
Let us know how it goes.
MT
MT-2500 is offline   Reply With Quote
Old 09-08-2009, 08:42 PM   #3
redddogg60
The Dealership claims that it is a worn yoke assembly. They are ordering the part and will replace it on Friday. They said that there is a service bulletin on this part/vehicle. I hope that it solves my problem...I'll let all of you know next week.
Old 09-08-2009, 08:59 PM   #4
j cAT
what rear diff is this ? open / locking ?
the locking diff requires the diff fluid to be replaced after 1000mi when the vehicle is to be used for towing or hauling..
the first 500mi the gears need to be hardened by easy driving.. the temperatures with these diff's will get very hot and many have had cracked broken teeth as the metal gets brittle and then cracks after a time..
if the rear end is in need of replacement break it in easy..
j cAT is offline   Reply With Quote
Old 10-24-2009, 01:26 AM   #5
slyder_
so is this a TSB?? If so can you post the TSB # for us
-Slyder
slyder_ is offline   Reply With Quote
Old 10-24-2009, 07:01 AM   #6
iroc343
I've noticed this on my 2005 silverado 2500hd. Occasionally, from a stop on bare pavement, it feels as if one wheel slips 1/8 turn. I have a hard time believing it is anything in the differential, and I,m wondering if it could be a sprag in the transmission slipping?
iroc343 is offline   Reply With Quote
Old 10-24-2009, 11:05 AM   #7
j cAT
its been awhile since you posted this ,,,how was this resolved ?
Old 11-08-2009, 11:12 PM   #8
redddogg60
They claim to have replaced the yoke. I didn't hear or feel anything for about 3 weeks. Now the same problem is happening again. I will be making another appointment with them soon.
....Slyder. I'm a novice...Please use english...what does the acronym TSB mean?
The Vehicle is an '07 Suburban LTZ with towing package, electronic "tow button", optional 2wd, 4wd, AWD. I hope this helps.
Old 11-10-2009, 10:26 AM   #9
j cAT
who is "THEY" ? I find it hard to believe on a 2007 anything is worn unless you had fluid loss...
I had a clunk issue on moving from a stop..it was just replacing the transfercase fluid...this was at the 30,000mi about 2 years old..dealer did it on warrantee...since then I replace transfercase fluid at 30,ooomi. no clunks...rear diff needs fluid replacement also ..
TSB means a technical service bulletin that GM puts out to all dealerships/tech's..
this info is not given to vehicle owners...you must lookup and using NHTSA find what TSB'S have been issued on your vehicle..then go to dealership with the TSB number to get the specific info...
Old 11-10-2009, 10:28 AM   #10
Siouxicide
Just sent you the PM but it looks like we have different issues. Do you have it set to "Auto" all the time? The clunking I had from accelerating after a stop lessened considerably when I set it to 2wd. I never had the problem through turns or stopping.
Siouxicide is offline   Reply With Quote
Old 11-10-2009, 10:33 AM   #11
Siouxicide
J cat, I had my transfer case crap out(due to worn parts no less). New parts, new fluids, same clunking. Probably somewhere else down the line.
Old 11-10-2009, 10:54 AM   #12
j cAT
if you have 2wd/4wd in your vehicle,it is important to know this is NOT full time 4WD...that is 4WD in any form is NOT to be used on dry solid pavement.
with any componet even with proper operation and care/maintenece ,failures may occur..
on your clunking with an older high mileage vehicle the yokes do wear..also the rear diff and U joints can also cause you noises..
this is why its hard to diagnose on the internet..
the rear diff ..many do not remove the cover on fluid replacement , this then means traped metal debris is allowed to remain and wear out parts in the rear diff..
many feel the diff is defective design ..they should have never put the drain plug in...
to speed up lube jobs they just suck out old fluid and replace ..more money in their pocket and you loose..
Old 11-10-2009, 11:16 AM   #13
Siouxicide
I'm aware failures can/do happen. I said what I did in response to your quote above. It's my understanding that transfer cases for this model are prone to wear and failure.
My system has the selector with 2HI, AUTO, 4HI, 4LOW(think it's pretty standard). The clunking was worse in AUTO.(There was ice all over, I had reason to have AUTO selected). I don't drive on dry pavement in 4HI and I do know the difference.
Old 11-10-2009, 11:25 AM   #14
j cAT
so how do the U joints look...since you appear to have the other issues that are common with this...covered....
Old 11-10-2009, 02:22 PM   #15
redddogg60
Yes, my wife drives this vehicle primarily, so we leave it in "AUTO" all the time as a safety feature. Could this have contributed to my current problem...? Is it possible that it is the transfer case? I hate going to the dealership "unarmed". I would like to bombard them with information. So please share.
