Go Back   Automotive Forums .com Car Chat > Lincoln > Town Car
Old 08-30-2009, 05:57 PM   #1
tahoe03
95 tc trans trouble
Have a 95 town car signature series. To get it into drive you have to shift it to 2 on the column, after that you can shift it back to overdrive and it will stay in gear. To get it into reverse you have to shift it into park and neutral engages when it says its in reverse. Getting into park you have to slam the shifter into park hard or it will just go into reverse. I looked at the linkage and it looks fine and intact. Anyone have any ideas
tahoe03 is offline   Reply With Quote
Old 08-30-2009, 06:54 PM   #2
CL8
Re: 95 tc trans trouble
Get a new transmission!
That if thou shalt confess with thy mouth the Lord Jesus,
and shalt believe in thine heart that God hath raised him from the dead,
thou shalt be saved.
For with the heart man believeth unto righteousness;
and with the mouth confession is made unto salvation.
Romans 10:9-10
CL8 is offline   Reply With Quote
Old 08-30-2009, 11:42 PM   #3
Kitt1993
Kitt1993's Avatar
Don't listen to that idiot. I would look at the transmission Shifter Module for starters. Make sure it is in good shape by having it tested and or readjusted. Mine needed readjusting once and gave me a similar problem. Also Ford had a problem with these going out taking the Torque Converts with them. If you by a new or remaned tranny these days, you have to buy the UPDATED module otherwise they void the warranty. I would start there and see what happens. If I may ask, how does it shift when in gear?
b
Nick names for my Car....
Abe Lincoln, opcorn:
The President,
Lucky Number 5
Kitt1993 is offline   Reply With Quote
Old 08-31-2009, 04:41 PM   #4
tahoe03
Thank you for the info. That's going to be the first thing I do. When its in gear it shifts smoothly and you can feel the converter lock up and it not rough at all. One time a while ago the tranny shifted pretty hard but that was a few months ago and hasn't happened since. This past friday is when this issue started. ill let u know after i get it checked. thanks again
Old 09-04-2009, 02:28 PM   #5
pmpmrs@amigo.net
pmpmrs@amigo.net's Avatar
Wink Re: 95 tc trans trouble
Take it to COTTMAN transmission, and ask them to replace the black plastic box located on the drivers side of the tx about midway back on the housing, that the shift linkage bolts to. The module.
mike
pmpmrs@amigo.net is offline   Reply With Quote
Old 09-04-2009, 05:38 PM   #6
Kitt1993
Kitt1993's Avatar
mike
Thats what I told him to look at. Are you Mcgiver in disguise?
The President,
Lucky Number 5
Old 09-06-2009, 12:25 PM   #7
danielsatur
I gave my problem engine 95TC away, because of age & mileage!
I'am a little disappointed, because young man still didn't replace the engine.
Wow, could of got $4500 cash for clunker!
danielsatur is offline   Reply With Quote
Old 09-06-2009, 10:04 PM   #8
Kitt1993
Kitt1993's Avatar
Yup you would be a Liberal for that Cause.
The President,
Lucky Number 5
