Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 06-28-2009, 10:59 PM   #1
zimdars84
Question Rear A/C won't turn off
I have a '99 suburban and had the front A/C turned on max. The A/C button works but doesn't light up. When I put the rear A/C on High it worked great. Now I turned it Low and it stayed on High. I even turned it off while the suburban was still running and nothing. I then turned the truck off and when I turned it back on the A/C in the rear kicked right back on High.
Any solutions?
zimdars84 is offline   Reply With Quote
Old 06-29-2009, 08:52 AM   #2
Cusser
Cusser's Avatar
Re: Rear A/C won't turn off
Are you trying to control the rear AC from the front, or from the rear panel? On my '94 there's a switch up front that either turns off the controls for the rear or allows those in the rear to be able to control their own choices. Apparently rear controls are for the case where it's "too tough" for 2nd seat passengers to converse with the driver....thanks GM, keep giving us more complexity !!!
Cusser is offline   Reply With Quote
Old 06-29-2009, 10:24 AM   #3
zimdars84
I tried having the front control it and set it to rear contols. Still running. Is there a fuse that is just for the rear A/C that I could pull and reset?
Old 06-30-2009, 12:27 AM   #4
777stickman
This is for the Old Body Style Sub. If you have a New Body Style it is probably different.
Sounds like you have a relay stuck. In the I/P fuse block is RR HVAC fuse #5 10a. You can try pulling it but I don't think it's going to do anything since it's hot with the key in the RUN position only. In the Underhood fuse block is BLOWER fuse #3 50a. This fuse is hot at all times. Pulling this fuse would disable the front blower also. Relays for the rear blower are located behind the right rear wheel well inside the trim panel.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
777stickman is offline   Reply With Quote
Tags
a/c , air , condition , control , electrical
