Go Back   Automotive Forums .com Car Chat > Ford > General Discussion
Old 04-29-2009, 10:02 PM   #1
kubira
Hydraulic Clutch
I have a 1993pc courier and need some assistance with the Hydraulic Clutch. I have owned it over 2 years, there is still the same clutch slippage (%) as there was when i bought it.
I was gong to have it replaced early on, however its never given me any real trouble, and 2 years later, its still hasn't gotten any worse.
I've not adjusted anything as it is hydraulic(not sure what can be adjusted), but im thinking, does bleeding the clutch assy. increase clutch dis engage, or engaged state?
If u ask me, over the 2 years i've had the car, it would be great to fix this very slight clutch problem, just a little bit more stick is all it needs. I know all the signs probly point to worn something or other, just seems strange that it has never gotten any worse
kubira is offline   Reply With Quote
Old 04-30-2009, 01:29 AM   #2
Davescort97
Escort guy
Re: Hydraulic Clutch
It probably won't make any difference, but I would bleed the system to make sure.
Davescort97 is offline   Reply With Quote
Old 05-02-2009, 06:06 PM   #3
MagicRat
Nothing scares me anymore
MagicRat's Avatar
Air in the hydraulic system will make no difference for a slipping clutch.
Eliminating air in the system results in a firmer pedal and makes clutch disengagement more efficient. However, the degree of clutch engagement will remain the same.
MagicRat is offline   Reply With Quote
