Go Back   Automotive Forums .com Car Chat > Toyota > GS300/GS400/GS430/Aristo
Old 02-27-2009, 04:26 AM   #1
kangoroti
Exclamation Aristo Gs 300 twin turbo overheating
Hi
i have a problem with myb engine, after going for 100 miles my engine starts overheating.
i have rememoved the heads,checked found ok, renewed the gaskets and still i have the same problem.what could be wrong?
kangoroti is offline   Reply With Quote
Old 02-27-2009, 10:53 AM   #2
Brian R.
Resident Chemist
Brian R.'s Avatar
Send a message via Yahoo to Brian R.
Re: Aristo Gs 300 twin turbo overheating
Low coolant level or air in system - needs replenishment or removal of air.
Lower radiator hose is soft on inside - collapsing under suction and needs to be replaced.
Thermostat not opening fully and needs to be replaced.
Radiator obstructed and needs flushing.
Block cooling passages obstructed and need flushing.
Water pump fins corroded and need to replace pump
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Brian R. is offline   Reply With Quote
